POV-Ray : Newsgroups : povray.binaries.images : Another point of view Server Time
16 Mar 2026 09:30:23 EDT (-0400)
  Another point of view (Message 13 to 22 of 82)
Subject: Re: Another point of view
Date: 5 Nov 2009 02:25:01
Message: <web.4af27cbf234deab6da6353d60@news.povray.org>
> please, do. This rocks too much!
> Good to see HDR in povray too, though I have no clue how to use the latest
> features being implemented at all...
Sorry, to tired to day ;)
Well actually there is no HDR in the scene - just a tga-file. I'm using MegaPov
0.6 for the texture, I like the blurry reflection. It does not support HDR.
Holger :)
Date: 6 Nov 2009 00:00:00
Message: <web.4af3ac9a234deab67c88d19c0@news.povray.org>
I see.
and thanks for the heads-up, clipka.
Date: 6 Nov 2009 13:30:01
Message: <web.4af4699b234deab6da6353d60@news.povray.org>
I didn't finished this part because I'm not sure if I like it.
Also it will make a lot of trouble, when it has to being animated.
If someone have an idea, just draw it roughly. When its good, I will use it.
Holger
Download 'hand5.jpg' (71 KB)
Preview of image 'hand5.jpg'
Date: 6 Nov 2009 15:55:00
Message: <web.4af48cca234deab629dd4f5a0@news.povray.org>
A more detail picture - OK, there are no details at the moment ;)
Download 'hand5.jpg' (40 KB)
Date: 7 Nov 2009 12:45:02
Message: <web.4af5b1a5234deab6da6353d60@news.povray.org>
OK, I trough it away. Here a new concept with a round element. More like a
motor.
Holger
Download 'hand6.jpg' (71 KB)
Preview of image 'hand6.jpg'
Date: 8 Nov 2009 06:15:01
Message: <web.4af6a7bd234deab6da6353d60@news.povray.org>
And one more detailed
Holger
Download 'hand7.jpg' (81 KB)
Preview of image 'hand7.jpg'
Date: 8 Nov 2009 07:29:34
Message: <4af6b9ae@news.povray.org>
> Holger
hex object, on the pipe work, is for. If it is a connector it should
look something like the one I just threw together, attached below.
Best Regards,
Download 'connector.jpg' (21 KB)
Preview of image 'connector.jpg'
Date: 8 Nov 2009 10:20:59
Message: <4af6e1db$1@news.povray.org>
>> Holger
There ARE real one piece, solid, connectors just like those. I personaly
saw a soem on actual working machinery. The thread is normal for one
half, and inverted for the other. You insert both pipes and just screw it.
It's the kind that you sugest that I have seen the less.
Date: 8 Nov 2009 12:03:40
Message: <4af6f9ec$1@news.povray.org>
Yes there are but you would only use them for straight runs or ones with
you would use a compression fitting. Any Instrument Tech worth his salt
would be able to bend those pipes without a join even I could do it.
Well, I did spend a few years working on pneumatic and hydraulic systems.
Best Regards,
Date: 8 Nov 2009 23:55:00
Message: <web.4af79fed234deab6cac4259f0@news.povray.org>
I've seen it where pipe thread was used -and- the rotation/orientation mattered.
Charles
