POV-Ray : Newsgroups : povray.binaries.images : ink diffusion rendering for suggestions. Server Time
8 Oct 2024 00:35:05 EDT (-0400)
  ink diffusion rendering for suggestions. (Message 1 to 10 of 16)
Subject: ink diffusion rendering for suggestions.
Date: 13 Oct 2009 06:55:01
Message: <web.4ad45c1d4c643aec1524ae1d0@news.povray.org>
Hi, all.
Attached is a rendering image of ink drop dropped into a water tank.
I got the mesh(mesh2) for the water surface and the density(0~1.) of the ink(df3
file).
But I do not have good knowledge in the media rendering.
I am wondering if somebody can give me some suggestions on this or some other
media parameter examples and resources.
The ink can be black, dark blue, red or any other dark colors.
Any advices will be appreciated.
Thank you very much.
Paean
Download 'drops082.png' (201 KB)
Preview of image 'drops082.png'
Subject: Re: ink diffusion rendering for suggestions.
Date: 13 Oct 2009 22:41:56
Message: <4ad53a74$1@news.povray.org>
> Hi, all.
> file).
> Regards,
> Paean
Looking OK.
The default sampling is method 3. With that, the defaults are:
intervals 1 (you should leave it alone, increasing it will cause a huge
rendering slowdown, it may produce artefacts)
samples 3 (MINIMUM value! Increase as needed)
There is NO second samples value. If you provide one, it will be totaly
ignored.
"samples 100" is way faster than "intervals 10 samples 10".
Date: 14 Oct 2009 04:00:01
Message: <web.4ad583d3edf569a01524ae1d0@news.povray.org>
Alain <aze### [at] qwertyorg> wrote:
> > Hi, all.
> > file).
> > Regards,
> > Paean
> Looking OK.
> ignored.
> Alain
Hi, Alain,
Can you help me to adjust the parameters? I can give you all the stuff including
the pov file, the mesh file and df3 file (about several Mbs in total).  My Email
is PaeanBall (AT) gmail.com.
Anyone else that can do me a favor will be very appreciated too.
Best Regards,
Paean
Date: 14 Oct 2009 05:15:00
Message: <web.4ad5961dedf569a01524ae1d0@news.povray.org>
> > > Hi, all.
> > > file).
> > > Regards,
> > > Paean
> > Looking OK.
> > ignored.
> > Alain
> Hi, Alain,
> Best Regards,
> Paean
I want the results to be similar with this.
http://area.autodesk.com/blogs/duncan/ink_in_water_using_maya_fluids
But I am not sure whether POVRay can handle this.  I think no multiple
scattering are provided in POVRay.
Paean
Date: 14 Oct 2009 15:13:53
Message: <4ad622f1@news.povray.org>
My suggestion would be make the ink df3 available for
download somewhere and post a link here. Someone might
just feel the itch to try tinkering with it without
the pressure of *having* to produce a result ;)
Date: 14 Oct 2009 21:40:02
Message: <web.4ad67ce3edf569a01524ae1d0@news.povray.org>
Hi, Christian,
Good Suggestion.
I have attached the files required(it is much smaller than i think after
compression).
Uncompress the tar.gz and then povray mesh2.ini.
Anyone can do me a favor to adjust the media parameters will be very
appreciated. I am learning the media rendering too, but I do not have much
rendering experience and it seems hard to make the media look like you want.
Paean
Download 'povrayink.tar.gz' (1429 KB)
Date: 16 Oct 2009 11:00:39
Message: <4ad88a97@news.povray.org>
> other
I had a bit of a tinker with your code, and looked at those videos you
posted.
IMO the ink in those videos is a little unrealistic, as the under side of
the ink is too dark (it would be getting lit from the plane below the tank).
Or maybe I just can't figure out how to copy that effect in POV :-)
Anyway, I'm no expert, but the adjusted media block I came up is below.  I
also turned off photons and made the light a bit brighter.  (For test
renders you can reduce "samples" to 5 or so to speed up rendering)
Basically I got rid of the emission, and cranked up the scattering and
absorption.  I think it certainly looks more "3D" than before.
media {
                absorption 60*<1, 1, 1>
                intervals 1
                samples 20
                method 3
                scattering{ 4,<0.2,0.2,0.8>*50 }
                density{  density_file df3 densFileName
                              interpolate 2
                              scale <1,2,1>
                              translate <-0.5, -1.5, -0.5>
                    color_map {
                    [0.00 rgb 0.0] // density at the border of the media
                    [0.05 rgb 0.2]
                    [1.00 rgb 1.0] // densitiy at the center of the media*/
Download 'phot_met_glass.jpg' (43 KB)
Preview of image 'phot_met_glass.jpg'
Date: 16 Oct 2009 13:20:01
Message: <web.4ad8aadcedf569a01524ae1d0@news.povray.org>
Hi, Scott,
Thank you very much for your help.
The results are indeed much better. However, i think it is some thick and gloom,
not so bright and wispy. I think the density_map need to be adjusted.
I am sorry for the vague expression since it is really hard to express my
thought very accurately. I am not a native English speaker.
I upload two new data files with higher resolution. They are much bigger, and I
have to upload them one by one. The usage of these data file is the same of the
previous ones.
There is some artifacts in the 2.30 mesh file, just ignore them.
And also, I upload two images from the two new data files and the previous pov
file expect  the samples modified to 20.  With the higher resolution data file,
the results seems better, while not good enough.
I am still learning and  working hard to improve the rendering.  Any suggestions
and help will be very appreciated.
Paean
> > other
> posted.
> media {
>                 intervals 1
>                 samples 20
>                 method 3
>                               interpolate 2
>                               scale <1,2,1>
>                     color_map {
>                     [0.05 rgb 0.2]
Download 'drops_2.76.png' (223 KB)
Preview of image 'drops_2.76.png'
Date: 16 Oct 2009 13:20:05
Message: <web.4ad8ab13edf569a01524ae1d0@news.povray.org>
2.76 mesh file
Download 'watermesh-2.76.pov.gz' (3784 KB)
Date: 16 Oct 2009 13:25:05
Message: <web.4ad8ab47edf569a01524ae1d0@news.povray.org>
2.76 df3 file
Download 'tracer-2.76.df3.gz' (3565 KB)
