POV-Ray : Newsgroups : povray.binaries.images : Anaglyph (red/cyan), Outside micrometer Server Time
22 Apr 2026 23:17:32 EDT (-0400)
  Anaglyph (red/cyan), Outside micrometer (Message 11 to 14 of 14)
Subject: Re: Anaglyph (red/cyan), Outside micrometer
Date: 4 Oct 2009 23:03:35
Message: <4ac96207$1@news.povray.org>
Stephen wrote:
> On Sun,  4 Oct 2009 14:01:15 EDT, "StephenS" <nomail@nomail> wrote:
>> Comments welcome.
> How about some normals on the anvil and spindle <ducks and runs> ;)
> As Alain said something to be reflected, maybe the kitchen HDI probe. I think
> that you need an extra scale on the vernier to get the accuracy you advertise.
> Other than that the micrometer is just too clean/new looking. So a patina of oil
> or some dirt and scratches.
Um, nope.  The satin chrome of the barrel and thimble isn't quite right,
but my thoughts would be more work on the lighting.  The color of the
micrometer frame, depends on maker.  No name on it, I'll assume chinese.
  My Starrets, the frame was a gloss black when they were new. now a
beat up gloss black in places.  the vernier for the ten thousandths is
correct as shown.
The satin chrome will vary depending on manufacturer and age, I have
older Starrett and Lufkin with the chrome polished to a high shine, from
use.  The spindle is always ground and polished, tool steel, not
stainless steel.  The carbide anvils always have a grayish appearance,
this from the manufacturing process, not highly reflective.
The only thing I see that looks really odd is the sharp, dark shadow
where the thimble meets the barrel, I've never seen that even with new
micrometers.  (Diffusion from the satin chrome, probably?)
Otherwise, beautiful job.
Rich  (retired machinist/gage technician/toolmaker.)
Date: 5 Oct 2009 06:35:00
Message: <web.4ac9cb9558acf73cc34216ae0@news.povray.org>
> correct as shown.
Thank you.
Your comments are right on, apparently there's no fooling you. The
thimble/barrel shadow is my lack of a global illumination solution. The frame is
suposed to be a slight blue colour.
Stephen S
Date: 5 Oct 2009 07:33:57
Message: <b9mjc5lm206tvdnch8u7e84lng0gpnnhj3@4ax.com>
>Yes I'm still trying to narrow down the ballance :-)
I think that the balance is looking ok. You could try stretching the normals
along the long axis.
>I think I going for something that can be printed large, but more as a studio
>type of image... still exploring.
Go for it :)
Regards
Date: 5 Oct 2009 07:35:59
Message: <remjc5tmr3t8ne8c6cfr1brvjuoakicqqu@4ax.com>
On Sun,  4 Oct 2009 20:29:50 EDT, "StephenS" <nomail@nomail> wrote:
>Stephen <mcavoysAT@aolDOTcom> wrote:
>> I think
>The following image would be read:
>0.2, past the 2 on the major scale
>+ 0.025, one line past the 2
>+ 0.001, one line past the 0 on the rotating scale
>+ 0.0005, lining up the fixed scale going into the shadow with best match from
>the lines on the rotating scale(going into the shadow).
>..2265 :-)
>Ok the fixed scale is still in shadow because the spacing is still not correct.
>Need to adjust for using a pigment object with cylindrical warp.
It has been so long since I used a vernier that I should keep quiet ;)
Regards
