Trevor G Quayle wrote:
> Whether a newsreader can be used or not is irrelevant to the fact that the web
> interface is currently broken.
Whoooosh!
> Is there anyone that can actually figure out and fix what is wrong with the web
> interface?
Sounds like the mime.types file isn't being found, but that's just a guess
from what I'm reading here.
"alphaQuad" <alp### [at] earthlink net> wrote:
> "Trevor G Quayle" <Tin### [at] hotmail com> wrote:
> > clipka <ano### [at] anonymous org> wrote:
> > > gonzo schrieb:
> > > > Why do all the recent images have ".dat" on them?
> > > > Or has M$ upgraded Windows again so as to make it even more unusable?
> > > That appears to be some issue with the web interface. Something broke
> > > with the recent update?
> > Does anyone know what has happened and if it will be able to be repaired.
> > I use the web interface at both home and work (work I don't have access to
> > newsservers) and the result is the same for both, a .dat extension on every
> > image (also for any other attachment type).
> > It appears to just be appending the extra extension, not actually changing the
> > file. DLing it and simply removing the extension makes it viewable.
> > -tgq
> really, so which dweeb is responsible for this BS. Everyone sucks except for the
> ones that dont. TGQ you rock and dont suck. But I'm outta here because of the
> mentally challenged ones who run things around here.
> clipka youre just a jealous dork,
> Warp, you fair no better,
> and Jim Henderson AKA John Dense Rim, youre the biggest dense rim ever!
> The fact that this stupid crap wasnt fixed the same day, speaks volumes about
> these pathetic turds.
> Later. I'll always remember Trevor tho, anyone lucky enough to work with Trevor,
> should thank their lucky stars.
> oh and that dork using MSBS to compile povray 3.7, learn something foo.
anarchists can call the President of Iran a "loon", a man clearly concerned for
every good person, on national airtime, then the right to freedom of speech
belongs to everyone.
windows stereo version can be found.
Known bugs:
Win98SE
Single stereo image using, Post_Frame_Command or Post_Scene_Command:
Toggle closed message window: alt-m
Stereo movie: no bugs, message window can remain open.
Vista
Crashes, execute batch file manually. Maybe closing msg window is the fix, but
*CORRECTLY* compiled with mingw version 3.6.3
http://home.earthlink.net/~povraytrace/
Use #version 3.63;
Includes glow, motionBlur, and date megapov patches
All good people will be together soon, leaving the dorks and dweebs to their
nightmare .. tick tock,
aQ
> aQ
Bye, aQ. Don't let the door get you on your way out, watch that first
step, it's a doozy. Don't go away angry, just go away.
Rich.
It appears that the libmagick++ function used to detect image types
broke during the updates; hence, the program we use to pick up the
binaries from the news server and put them into the database was not
able to determine when an attachment was an image. It should be working
now for new posts. I will repair the old ones shortly (I'll have to
write some code to hit the DB and re-detect the type for the messages
already in there).
-- Chris
> already in there).
> -- Chris
Thank you for avoiding the pointless bickering and solving the problem.
-tgq
By the way, I have noticed that messages posted in the web interface lack
the end boundary marker when read through NNTP. It seems that the web
interface creates all messages as "multipart/mixed" -- and the start
boundary marker is always present -- but the end marker is omitted when
there is only one part (i.e. no attachment).
This is not something caused by the server upgrade; I see it in messages
from 2005 (which is as far back as my archive goes). I only noticed it
recently because Opera 10 points it out when earlier versions did not.
FE
> already in there).
> -- Chris
Appears as if it may be working again. Thanks for fixing if indeed you did
Chris. (Or whomever was responsible)
-tgq
> interface? Looking at the image digest, it appears that the last valid images
> were posted:
> by Mike Raiford on 16 Sep 2009 17:19:20
> in 'Re: make_gemstone macro, old fashioned 8-cut'
Are you inferring I broke the web interface? :)
~Mike
> > were posted:
> ~Mike
Blame needs to be cast if you are volunteering.
It appears to be fixed now, plus the images from the time it broke to when it
got fixed are all there now, so you should get off with a light sentence: 100
reflective spheres on a checkered plane.
-tgq
You forgot the "ego te absolvo" :-P
