POV-Ray : Newsgroups : povray.binaries.images : Different Results Between Versions Server Time
17 Aug 2025 10:58:08 EDT (-0400)
  Different Results Between Versions (Message 1 to 6 of 6)
Subject: Different Results Between Versions
Date: 7 Aug 2009 09:00:01
Message: <web.4a7c246da399eaf3df22a6900@news.povray.org>
Hello everyone,
Maybe this is already a documented issue, but if not here are two images
rendered from the exact same scene file, one rendered with v3.6.1a and the
other rendered with 3.6.2.
Dave Blandston
Download 'temp.png' (22 KB)
Preview of image 'temp.png'
Subject: Re: Different Results Between Versions
Date: 7 Aug 2009 09:32:45
Message: <4a7c2cfd$1@news.povray.org>
Dave Blandston schrieb:
> Hello everyone,
It *might* be helpful if you also disclosed the scene source code :P
Date: 7 Aug 2009 15:26:18
Message: <4a7c7fda$1@news.povray.org>
> Hello everyone,
> Regards,
> Dave Blandston
Where is the source scene file?
Date: 7 Aug 2009 16:15:00
Message: <web.4a7c8b382bb66eecdf22a6900@news.povray.org>
> Alain
I'll post the source in POV-Ray Text Files - scene-files.
Dave Blandston
Date: 7 Aug 2009 18:47:01
Message: <4a7caee5$1@news.povray.org>
>> Alain
After having boiled down the scene to about 60 lines, I found that the
only fault of POV-Ray 3.6.2 and 3.7 (but probably also of POV-Ray 3.6.1)
is that they don't warn you about pathological cylinders (and similarly
pathological tori) you're building in the BeveledCylinder macro; try the
following change:
#macro BeveledCylinder (Top, Bottom, Radius, EdgeRadius)
    union {
       cylinder {<Top.x, Top.y, Top.z + EdgeRadius>, Bottom, Radius}
->    #if (Radius > EdgeRadius)
          cylinder {Top, Bottom, Radius - EdgeRadius}
          torus {
             Radius - EdgeRadius, EdgeRadius
             rotate 90 * x
             translate <Top.x, Top.y, Top.z + EdgeRadius>
             sturm
          } //torus
->    #else
->       sphere {<Top.x, Top.y, Top.z + EdgeRadius>, EdgeRadius}
->    #end
    } //union
#end //#macro BeveledCylinder
POV-Ray 3.6.2 and 3.7 do indeed behave strange in such a case
(apparently creating an object which, when intersected with another one,
gets *bigger*), but what do you expect when working with infinitely thin
cylinders ;-)
Date: 10 Aug 2009 09:10:01
Message: <web.4a801c242bb66eecdf22a6900@news.povray.org>
> following change:
>     union {
>           torus {
>              rotate 90 * x
>              sturm
>           } //torus
> ->    #else
> ->    #end
>     } //union
> cylinders ;-)
Yes, that was the problem - thanks! That's a very interesting situation.
Dave Blandston
