POV-Ray : Newsgroups : povray.binaries.images : Anaglyph (red/cyan), Tool set Server Time
30 Sep 2024 12:13:49 EDT (-0400)
  Anaglyph (red/cyan), Tool set (Message 1 to 7 of 7)
Subject: Anaglyph (red/cyan), Tool set
Date: 1 Aug 2009 17:30:01
Message: <web.4a74b2d9623c3b524ffbed590@news.povray.org>
Top quaility Persistent brand tools.
I would like to have more pronounced photons, currently the setting are:
  photons {
    spacing           0.050
    gather            20,100
    media             0,1.000
    jitter            0.400
    max_trace_level   5
    expand_thresholds 0.200,40.000
    autostop          0.500
    radius            0.000,1.000,0.000,1.000
Suggestions?
Stephen S
Download 'tool_set_3dpair_c.png' (767 KB)
Preview of image 'tool_set_3dpair_c.png'
Subject: Re: Anaglyph (red/cyan), Tool set
Date: 1 Aug 2009 22:23:47
Message: <4a74f8b3$1@news.povray.org>
A quote I got from a mechanic:
"I can't afford to get tools that are not of the highest quality!"
>   photons {
>     spacing           0.050
>     gather            20,100
>     media             0,1.000
>     jitter            0.400
>     max_trace_level   5
>     autostop          0.500
> Suggestions?
> Stephen S
The caustics from convexe shapes are inherently faint. The reflected
light get dispersed, not concentrated.
Making them stronger would be unrealistic.
What you can do if you want to:
Increase the reflection value to a value larger than 1 and make the
light_source fainter and the background darker.
Increase the diffuse value of the ground to a value larger than 1, and
use a negative ambient value. This will make the shadows absolutely black.
Ether way, the result will be unrealistic.
Date: 2 Aug 2009 07:30:01
Message: <web.4a7578a7dba9e34e3a66837d0@news.povray.org>
Now that you mention it, when I've forced a photon scene I've used concave
shapes. Oh well.
Stephen S
Date: 3 Aug 2009 11:30:01
Message: <web.4a7701f7dba9e34ea107abcd0@news.povray.org>
>   photons {
>     spacing           0.050
>     gather            20,100
>     media             0,1.000
>     jitter            0.400
>     max_trace_level   5
>     autostop          0.500
> Suggestions?
Crank up the light source??
No, seriously: I guess they're realistic. Reflective caustics are much more
prominent with concave surfaces. To emphasize the effect, you'd need to place
other parts so that some of the caustics fall into another tool's shadow.
Something like that.
I don't think there's a parameter in POV-Ray to artistically over-exaggerate
photon caustics.
(BTW, I just notice that my anaglyph shades don't seem to be that bad after all;
they just didn't work too well with AlphaQuad's solar systems and their
bright-on-black setting.)
Date: 6 Aug 2009 22:04:35
Message: <4a7b8bb3$1@news.povray.org>
>>   photons {
>>     spacing           0.050
>>     gather            20,100
>>     media             0,1.000
>>     jitter            0.400
>>     max_trace_level   5
>>     autostop          0.500
>> Suggestions?
> photon caustics.
One thing you can do to exagerate the effect of your photons:
Use a two pass render.
On the first pass, chank up your light by a factor of 5 to 50 our more,
and use a plain white ground plane. Save your photons.
On the second pass, bring back your light to a normal level. Use your
textured ground. Load the photons.
It won't be realistic, but the photons effect will get stronger,
possibly MUCH stronger.
Date: 6 Aug 2009 23:49:47
Message: <4a7ba45b@news.povray.org>
Gee - and once again POV-Ray is more powerful than I had imagined...
Date: 9 Aug 2009 14:05:00
Message: <web.4a7f0f1fdba9e34e56aaf08d0@news.povray.org>
> Alain
Useing a two pass render.
I changed my light from 1 to 10, somewhere less is what I was looking for.
Stephen S
Download 'tool_set_extra_photons.png' (256 KB)
Preview of image 'tool_set_extra_photons.png'
