POV-Ray : Newsgroups : povray.binaries.images : An upside-down CPU Server Time
17 Mar 2026 06:36:39 EDT (-0400)
  An upside-down CPU (Message 1 to 10 of 10)
Subject: An upside-down CPU
Date: 29 Jul 2009 12:05:01
Message: <web.4a707268b41801728f9faa460@news.povray.org>
Focal blur and global illumination makes any mundane image look fairly decent!
Download 'cpu.jpg' (156 KB)
Preview of image 'cpu.jpg'
Subject: Re: An upside-down CPU
Date: 29 Jul 2009 12:25:00
Message: <web.4a7076ff53621dd1edb9d8df0@news.povray.org>
Nice one.
Round off the pin ends for better effect. Also, I think adding some normals
distortion to the pin "roots" would be appropriate, tough I'm not sure whether
that is some kind of solder or a straightforward machined part of the pin
itself.
Date: 29 Jul 2009 12:45:00
Message: <web.4a707c5953621dd18f9faa460@news.povray.org>
Thanks. The pins are rounded, perhaps not enough. And the pin roots have
normals, also perhaps not enough.
> Nice one.
> itself.
Date: 29 Jul 2009 15:44:10
Message: <4a70a68a$1@news.povray.org>
It did actually prompt me to fetch my original Pentium 66MHz CPU
(including floating point bug) which I never exchanged and which
is now enjoying retirement in my living room's display cabinet ;)
If it's any reference I think your pins should be slightly thinner
and the root a bit flatter. But what do I know of modern CPUs ...
Date: 30 Jul 2009 04:45:30
Message: <4a715daa$1@news.povray.org>
  I don't know... This is the exact type of image which looks like it
doesn't really benefit all that much from radiosity. Did you try without
radiosity (and possibley with properly-placed additional light sources)?
Date: 31 Jul 2009 12:35:01
Message: <web.4a731c8d53621dd18f9faa460@news.povray.org>
Yes, I'm not quite able to place regular lights in such a way as to get as good
results with radiosity.
Date: 31 Jul 2009 14:58:22
Message: <4a733ece$1@news.povray.org>
  How are you trying? See some tips here:
http://warp.povusers.org/povtips/
Date: 3 Aug 2009 09:55:01
Message: <web.4a76ebcc53621dd18f9faa460@news.povray.org>
Slight update, with more underside (non-potato) chips.
Download 'cpu.jpg' (171 KB)
Date: 3 Aug 2009 15:40:00
Message: <web.4a773c9f53621dd1a107abcd0@news.povray.org>
Hmm... no, those chips they definitely need more work on their pins.
Date: 3 Aug 2009 23:50:58
Message: <4a77b022$1@news.povray.org>
I agree - they seem like DIP (solder-through) while they should be TSSOP
(SMD, surface mount) oslt.
-Aero
