POV-Ray : Newsgroups : povray.binaries.images : More polyhedra Server Time
23 Apr 2026 02:35:40 EDT (-0400)
  More polyhedra (Message 11 to 20 of 25)
<<< Previous 10 Messages Goto Latest 10 Messages Next 5 Messages >>>
Subject: Re: More polyhedra
Date: 25 Jun 2009 07:00:00
Message: <web.4a43589dd12045c46dd25f0b0@news.povray.org>
>   I think a simple plane with a proper normal block would have resulted
> in a practically identical image but much faster.
Would the shading due to the caustics still be correct?
In any case, using an isosurface instead of a plane didn't slow it down that
much. And I just can't help thinking of normals as 'cheating' ;-)
Date: 25 Jun 2009 07:26:28
Message: <4a435ee4$1@news.povray.org>
  Why wouldn't it?
  Everything is "cheating" in rendering. It's just smart to use the
cheats which will produce the same results faster.
Date: 25 Jun 2009 07:55:21
Message: <4a4365a9$1@news.povray.org>
> Bit quiet on p.b.i. at the moment, so here's some shiny things.
> These are the Platonic, Archimedean and Catalan solids. How many can you name
> without resorting to wikipedia or wolfram? :-)
Really nice, as usual ;-)
Date: 25 Jun 2009 08:15:00
Message: <web.4a436916d12045c46dd25f0b0@news.povray.org>
>   Why wouldn't it?
Well, if my isosurface were more deeply ridged, there'd be shadowed areas in the
photon maps that normals wouldn't produce. But this probably isn't happening
here, I ended up with very shallow features.
Aside from that, I just assumed that the normal block wouldn't be used when
applying photon maps to surfaces. For no good reason, other than that normals
aren't used in radiosity unless specified. I can't find any mention of it in
the docs. I'll try it later, then I'll know... :)
True. At least (in general) cheating with actual geometry is a little closer to
reality. But I agree it would seem to make little or no difference in this
case.
Date: 25 Jun 2009 10:38:32
Message: <4a438be8@news.povray.org>
> Ooooooo!  A spaaaarkly!
LOL
~Mike
Date: 25 Jun 2009 18:50:00
Message: <web.4a43fed6d12045c44f9d72ce0@news.povray.org>
Very, very beautiful! Especially the lighting and the colored shadows. I tried
something similar with a simple glass sphere and photons a few weeks ago, but
the shadow was much too dark. Maybe the "count" was too low. I'm not so
experienced with glass like objects, because I have frustrating results most of
the time and therefore don't really dare to raytrace them often ...
But now with this proof, that they can look really good, I will try again
sometime in the future.
.... dodecahedron, icosahedron ... uhm ...
Date: 26 Jun 2009 01:33:46
Message: <4a445dba$1@news.povray.org>
Shiny!  I like the textures & colours.... :-)
Reminds me a lot of the polyhedral dice I have around ehre somewhere.
Jim
Date: 26 Jun 2009 05:10:01
Message: <web.4a448f91d12045c46dd25f0b0@news.povray.org>
Thank you!
> I tried
The shadows are bright in my image because I used radiosity with a bright
environment, so there are no completely shadowed areas. However, if you have a
sphere and a single light source, a largely dark shadow with a single bright
spot is to be expected. It only looks odd because you don't often get that
lighting setup in reality.
Having said that, count does need to be fairly high to get good results. I
typically use at least 1e6, but 1e4-1e5 could be sufficient for something
really simple like a sphere.
> I'm not so
Sometimes, the knowledge that something can be done is all the motivation you
need to work out how to do it. :)
Bill
Date: 27 Jun 2009 11:38:36
Message: <4a463cfc$1@news.povray.org>
When tracing a sphere with photons, it's normal to get a (very) dark
shadow with a bright spot in the center. If the sphere is to far away
from the surface receiving the shadow, the photons will have converged
to the focal point and spread again, possibly to an area much larger
than the sphere.
Glass objects, as well as metallic ones, need some environment to look
good. You also need something to get some light in the shadowed areas.
It can be a shadowless light source set to NOT cast photons, or it can
be radiosity.
Photons block for a fill light:
photons{refraction off reflection off}
Date: 27 Jun 2009 15:30:26
Message: <4a467352$1@news.povray.org>
> be radiosity.
  Or simply use multiple light sources. A single light source,
especially in "interior" scenes, tends to look a bit dull (although it
can be used effectively as well).
