POV-Ray : Newsgroups : povray.binaries.images : Another Cloud Scene Server Time
11 Apr 2026 16:28:44 EDT (-0400)
  Another Cloud Scene (Message 1 to 3 of 3)
Subject: Another Cloud Scene
Date: 30 Apr 2009 02:15:01
Message: <web.49f9418a2b08e069472ff940@news.povray.org>
Another cloud scene using blobs.  The idea of layered media is not original to
me; it was used in a pov-ray media tutorial someplace I've forgotten.
I think the clouds look relatively nuanced and natural and the scene renders
quickly.  I'm posting my convuluted code for the scene in the hope that someone
more knowledgeable can improve it and maybe use it in a macro.
#include "functions.inc"
#declare Cloud=
#declare SD=seed(11235);
blob {
 threshold 13.9106
 #declare index=0;
 #while(index<17)
  sphere {<rand(SD),1.7*rand(SD),.5*rand(SD)>,4*rand(sin (radians
(SD*2)))*2,2+sin(radians(SD))
translate <-1.36,1.1,.5>  rotate 4*sin(radians (index*SD))    }
  #declare index=index+1.34;
hollow no_shadow
  texture { pigment { rgbt 1 } }
  interior {
    media { emission 8 method 3 samples 30,30 intervals 1
      density { spherical
        warp { turbulence .75*.3+.05 lambda 2.75 }
        density_map {
          [1-.99*.75 rgb <0,0,0>]
          [1-.99*.77 rgb <max(0,1-.75*1.5),max(0,1-.75*4.5),max(0,1-.75*6)>]
          [1 rgb <.55,.55,.50>] }
    media { absorption 2 method 3 samples 30,30 intervals 1
      density { spherical
        density_map {
          [1-.99*.75 rgb <max(0,1-.75*1.5),max(0,1-.75*4.5),max(0,1-.75*6)>]
          [1 rgb <.75,.25,0>] }
      }           density {gradient z}
    media { scattering { 5 .25 eccentricity .5 extinction .8} method 3 samples
30,30 intervals 1
      density { spherical
        warp { turbulence.75*.3+.05 lambda 2.75 omega 4 }
        density_map {
          [1-.99*.75 rgbt 0]
          [1-.99*.75 rgbt 1]
          [1-.49*.75 rgbt 1]
          [1-.49*.75 rgb 0]
      }   density {gradient z  scale 1.6}
    media { absorption 3 method 3 samples 30,30 intervals 1
      density { spherical
        density_map {
          [1-.99*.75 rgb 0 ]
          [1-.99*.75 rgb  1]
          [1-.49*.75 rgb  1]
          [1-.49*.75 rgb 0 ]
      }         density {gradient z scale 13 translate <5,1,-25>}        density
{spherical scale 6.9  translate -5*z}
#declare Cloud2=
object {Cloud scale 1.7*z scale 1.4*y scale 1*x}
object {Cloud2 scale <3.5,2.2,2.3>*1.3 rotate -15.5 rotate -26*x rotate -5*z
translate <-.16,-1.3,-.2> }
object {Cloud2 scale <3,2.4,2.4>*1.3 rotate -18 rotate -21*x rotate 6*y rotate
0*z translate <2.7,-1.7,-.2>}
//Ocean
#include "glass.inc"
 #declare Sea = texture
  pigment
    colour rgbft<0.198,1.355,1.296,1.8,.01>*.2
  normal
    waves 0.2
      frequency 1000
      scale 6000 scale 2.02*y
  finish {
    diffuse 0.62
    brilliance 1.5
    specular 0.66    roughness 0.04
    phong 0.2    phong_size 175
    reflection .45
    ambient <0,2,.7>*.2
    refraction 1    ior 1.333
plane { y, -5.3
      texture { Sea }
rotate 182*y
light_source {
  0*x
  color rgb <1,1,1>
  translate <-20, 40, -20>
  location <0,0,-5>
  look_at <0,0,0>
sky_sphere {
  bumps    scale 2
   // gradient y
    color_map {
      [0.0 color rgb<0.8, 1.0, 1.0>*.5]
        [.6 color rgb<0.0, 0.5, 1.0>*.85]
      [1.0 color rgb<0.0, 0.5, 1.0>*.85]
   pigment { bozo turbulence 0.35 octaves 6 omega 0.7 lambda 2
   color_map {
   [0.0 0.1 color rgb <0.85, 0.85, 0.85>  color rgb <0.75, 0.75, 0.75>]
   [0.1 0.5 color rgb <0.75, 0.75, 0.75>  color rgbt <1, 1, 1, 1>]
   [0.5 1.0 color rgbt <1, 1, 1, 1>  color rgbt <1, 1, 1, 1>] }
   scale <0.6, 0.5, .2>  } rotate 35*x }
Download 'two nice clouds.png' (290 KB)
Preview of image 'two nice clouds.png'
Subject: Re: Another Cloud Scene
Date: 30 Apr 2009 03:49:39
Message: <49f95813@news.povray.org>
"FlaPovFan" <nomail@nomail> schreef in bericht
news:web.49f9418a2b08e069472ff940@news.povray.org...
As you use method 3 (default) with intervals 1, samples after the comma are
not read; samples 30 suffices.
Nice clouds by the way.
Date: 30 Apr 2009 04:15:52
Message: <49f95e38$1@news.povray.org>
FlaPovFan wrote:
> sky_sphere {
>   pigment {
>   bumps    scale 2
>    // gradient y
>     color_map {
  Regardless of what the documentation mistakenly implies, sky_sphere is
*not* intended to be used for cloud textures. It just doesn't look good
(because it's physically completely incorrect; the camera is not at the
center of the Earth).
  Just use sky_sphere for a color gradient from light blue (at the
horizon) to dark blue (at the zenith).
