On Tue, 14 Apr 2009 16:23:42 +0200, "Thomas de Groot"
<tDOTdegroot@interDOTnlANOTHERDOTnet> wrote:
>The morph tool? yes, indeed. Although I think that for small local changes
>that is more appropriate than the magnets. Growing horns on Jame's forehead
>is really fun for instance and easy to do. Mirroring the changes afterwards
>is the finishing touch. Personally, except for the built-in morphs, I rarely
>use the morph tool, and practically never the magnets. However, I must say
>that I did not (yet) have the need/incentive to use them. That might
>change....
I'm with you on that Thomas but then I've not had the need to use those tools.
My models are not as friendly as Christoph's and seldom even touch.
Clipka, do you know about UV Mapper? You can use it to remap bump and
displacement maps on your Poser models.
Regards
The thing is that whatever I do with the tool, whatever settings I use, whatever
mouse buttons I press etc, I *always* seem to be growing horns with it :P
Well, to be honest, it's actually not even horns - it seems to invariably result
in the very same undesired transformation that doesn't seem to make any sense at
all. I really don't have the *slightest* clue how to gain *any* control over
that tool.
Maybe it's just that my computer is too slow? I also have problems using any of
the other "tampering" tools like, say, rotation: I pull some body part a bit
with the mouse, and here I have James with his arm twisted by 720 degrees
(Celsius, not Fahrenheid ;))
So as of now, I usually work with only the sliders.
Doesn't ring a bell, no.
UVMapper classic (free) http://www.uvmapper.com/downloads.html
Is a utility which can map or remap an image to a mesh. I don't know about Daz
but Poser can use displacement maps where the mesh can be modified like adding a
heightfield. Or so I understand.
To be honest, it is the sort of program that I think should be useful but have
seldom used.
Regards
Well, the main point would probably be whether *PoseRay* can make any use of
them... 'cause POV-Ray cannot, that's for sure.
Yes, displacement works with PoseRay. You will find it in the groups tab,
sub-tab displacement.
A quick experiment with a sphere did not require UVMapper to be used. So if your
model has a bump map for normals you could modify that for displacement.
Regards
"clipka" <nomail@nomail> schreef in bericht
news:web.49e4a7ea55da85cff06ce2830@news.povray.org...
> whatever
A useful thing is to select Use Limits in the Figure drop-down box.
Generally speaking, you should select Show All Tools, in the Window
drop-down box.
The important thing to be aware of is that you can (and often should) tweak
the sensitivity of the different tools. For the transformation tools you
mentioned , you can restrict the amount of change, or in-/decrease the
sensitivity in the Properties box: click on the black arrow following the
different transformations and click on Settings... then change the
Sensitivity and/or the Limits. However, for the basic transformations, I
always use the sliders as I find them easier to use than pulling an arm in
3D space so to speak :-)
For the Morphing Tool, you can in-/decrease the Exageration Min/Max sliders
in the Tool's box, under Combine, and the Magnitude under Create, where you
can also select the different morphing tools (Push; Pull; Smooth; Restore).
Not bad at all. They both lack a bit of healthy color (skin), and the
fingers lack the typical wrinkles at the finger joints, that would look then
much better.
But it is a great job. I wouldn't know anyone who has a problem by seeing
the hands of two friends holding together.
Sven
"He" has nice skin texture. "She" on the other hand ;-) looks like plastic.
Nice height field.
I don't think she'd look too pretty with such hairy arms :P
(Just kidding; I know what you mean of course. I'm not sure though whether I
have any better texture for her in my collection; probably not: Good skin
textures cost a bit, and it's actually a surprise how good "his" texture looks
even this close.)
