POV-Ray : Newsgroups : povray.binaries.images : Ruins WIP #3 Server Time
23 Apr 2026 07:13:05 EDT (-0400)
  Ruins WIP #3 (Message 12 to 21 of 21)
Subject: Re: Ruins WIP #3
Date: 15 Mar 2009 07:20:00
Message: <web.49bce367a53135e3219167190@news.povray.org>
> One thing more: the column bases should be sunk *below* the flagstone upper
> surfaces! They appear to float above ground now.  :-)
Yes, this was bothering me too. It's because the weathering lowers the surfaces
slightly. I'd better lower the column bases a little. In which case, the
flagstones should really be arranged so that the column bases exactly fit in
with the flagstone grid... *mutters and starts scrawling sums on a bit of
paper*
Date: 15 Mar 2009 09:45:00
Message: <web.49bd0592a53135e3ac7b5ac70@news.povray.org>
> A good suggestion, Thomas. I have implemented a first attempt at what you
> describe, attached here. I think it does look better, although that's partly
> because I now have more crevices in which to grow the grass! :-)
The gaps between the floor and the feet of the pillars are way too wide, and
most of all way too deep; if they'd have formed at all (hey, how much weight is
resting on the things?), I fancy they should be filled with dirt.
Looks like you tried to have the floor "sink" a bit, as someone suggested
earlier, but think about why that should happen:
Abrasion from sand being blown through the building.
Abrasion from tourist feet.
Whatever you come up with, it can't possibly have affected those parts of the
floor covered by pillars carrying tons and tons of weight.
Date: 15 Mar 2009 10:55:00
Message: <web.49bd163aa53135e3219167190@news.povray.org>
See previous post. A remedy is currently underway.
You missed one: because it was built that way.
Honestly, physical erosion never occurred to me, and certainly wasn't the look I
was going for. I don't understand how it could happen that way, either - the
edges of the inner courtyard floor are far too sharp for a slow erosion. I
think this is clearly a deliberately raised, paved gallery around a bare inner
floor, which might even be the unmodified floor level from before the building
was put up.
Date: 15 Mar 2009 11:30:00
Message: <web.49bd1e3aa53135e3ac7b5ac70@news.povray.org>
Um - sorry, we're talking about two totally different things here. Consider this
a misunderstanding on my side.
Date: 15 Mar 2009 13:53:16
Message: <49bd408c$1@news.povray.org>
wow, the floor adds a remarkable amount to the realism
Date: 16 Mar 2009 04:10:42
Message: <49be0982$1@news.povray.org>
news:web.49bd163aa53135e3219167190@news.povray.org...
> look I
> the
> inner
> building
> was put up.
There are a couple of interesting developments here.
1) the lowered courtyard (or raised gallery if you wish) is often created
for a simple practical reason: rainfall. If you do not want the gallery to
be flooded, just raise it above the court yard level. This is also true for
regions with little rainfall (but huge quantities of rain at once).
2) What Clipka suggests (abrasion by tourist feet) would be nice to pursue.
Between the columns, the flagstones should indeed be hollowed out by years
of use.
Date: 16 Mar 2009 05:20:00
Message: <web.49be1971a53135e36dd25f0b0@news.povray.org>
Good point. However, I wish you hadn't mentioned this, bacause now I feel that
maybe I should put some drains and guttering into the gallery floor! Argh! ;-)
> of use.
Indeed. While this would be an interesting challenge, I shan't be pursuing it in
this scene, because a) I think it will be very difficult :P and b) I'm after an
abandoned look, untouched by tourism.
Bill
Date: 16 Mar 2009 05:32:32
Message: <49be1cb0$1@news.povray.org>
news:web.49be1971a53135e36dd25f0b0@news.povray.org...
>> to
>> for
> that
Life is hard...
>> pursue.
>> years
>> of use.
> it in
> after an
Good. However, even with tourists thrown out (they have no business here
anyway I believe) the building has been in use for many years in the past, I
assume. That would also wear the stones down... Let us say that this is some
future aspect to tackle :-)
Date: 16 Mar 2009 06:15:00
Message: <web.49be2668a53135e36dd25f0b0@news.povray.org>
....but no... this building has apparently been abandoned since shortly after
construction, just like the rest of the civilisation that built it... there are
no human remains, very few artifacts, strange shapes in the grass, and the
parrots all fly upside down... what happened here...? who knows...
*spooky noises*
Date: 17 Mar 2009 04:14:26
Message: <49bf5be2$1@news.povray.org>
news:web.49be2668a53135e36dd25f0b0@news.povray.org...
> after
> there are
> *spooky noises*
"Curiouser and curiouser!"
