"Dre" <and### [at] gmail com> wrote:
> "fdecomite" <nomail@nomail> wrote in message
> news:web.49ac621db93a08e66cbe8e7e0@news.povray.org...
> >> news:web.49ac5b0df60280a86cbe8e7e0@news.povray.org...
> >> > other povray images can be seen there :
> >> > http://www.flickr.com/photos/fdecomite/sets/72157607332628259/
> >> > http://www.flickr.com/photos/fdecomite/sets/72157603744943695/
> >> > http://www.flickr.com/photos/fdecomite/sets/72157604088439156/
> >> > http://www.flickr.com/photos/fdecomite/sets/72157604984910048/
> >> Awesome! I'd love to know how you worked out that spiral, I've been
> >> doing
> >> my head in ever since I saw your image!
> >> Cheers Dre
> > Some codes are archived here :
> > http://code.google.com/p/spirals/source/browse/#svn/pearls/scene
> > but the all repository is a little bit messy
> Hi again, sorry to be a pain, but I've looked into that repository and have
> found a doyle.pov file (the first attached pic is called doyle.pov) but it
> doesn't have the actual code in it. That code is stored in:
> #include"../../../ij/outdoyle.txt"
> which I cant find.
> Any ideas?
> Cheers Andreas
Now the difficult part begins :
sphere positions are generated with a java program you can find there :
http://code.google.com/p/gjhp/source/browse/#svn/ij (look for doyle9_.java)
This program itself (and all the programs in this repository) must be run in
ImageJ, as a plugin
news:web.49ac6f27b93a08e66cbe8e7e0@news.povray.org...
>> >> doing
>> >> Cheers Dre
>> have
>> it
>> which I cant find.
>> Any ideas?
>> Cheers Andreas
> doyle9_.java)
> in
> ImageJ, as a plugin
Aha! Thanks for the info!
Cheers Dre
That is so friggin' beautiful and skillful. Why were you hiding away from us
for so long? :)
> > Awesome! I'd love to know how you worked out that spiral, I've been doing
> > Cheers Dre
But this is a photo, or not? Wow!
http://www.flickr.com/photos/fdecomite/2415398843/in/set-72157603744943695/
(So much cholesterol?) :-D
Carlo
> > > Cheers Dre
> Carlo
Yes, this is a photo. Povray images are usually tagged with the 'povray'
keyword.
Not only source code is messy...
Terrific set!
bravo!
> keyword.
Ok, there was a little doubt. :-)
Carlo
Heh, nice one!
> for so long? :)
From the look of it, he just *MUST* have been too busy *making* all those
shots...!!
In "Water drops arranged in Menger Sponge Shape"
(http://www.flickr.com/photos/fdecomite/2292916215/in/set-72157604984910048/),
the structure seems awfully dark for an object made of water droplets. (Well,
thunderheads are dark, too, but they're a lot bigger.) Did you use light
attenuation of any kind? What max_trace_level did you use?
Well, the light comes from the inside, and is very much atenuated by repeatedely
pasing through individual droplets (with refraction, too).
No special light attenuation.
max_trace_level should have been at its max, as I usually do.
