POV-Ray : Newsgroups : povray.binaries.images : Ruins WIP Server Time
23 Apr 2026 08:54:43 EDT (-0400)
  Ruins WIP (Message 11 to 14 of 14)
Subject: Re: Ruins WIP
Date: 25 Feb 2009 06:15:00
Message: <web.49a527c9fa6cf65cbdc576310@news.povray.org>
> "P Brewer" <pbj### [at] wowwaycom> wrote:
> > Very nice... I can't wait to see the final scene. Are you using straight
> > isosurfaces?
> 100% meshes, macro-built in SDL. This rendered in 12 minutes on an ageing
> Mac. It renders in under a minute without the radiosity... no way I could get
> that performance out of isosurfaces!
Hum... sounds like I should definitely give your macros a try for my bricks. I
fancy it would also give me more freedom how to erode them. My own blob-based
approach is rather limited in this respect.
Do I need to start with an isosurface, or will any shape do?
Date: 25 Feb 2009 06:50:01
Message: <web.49a52f6dfa6cf65c6dd25f0b0@news.povray.org>
> > > isosurfaces?
Any shape whose surface is completely visible from the specified centre-point
(so make sure CSG is a merge!). It suffers a little from stretch artifacts for
long shapes, so I should probably try to improve the grid shape...
Date: 25 Feb 2009 07:30:00
Message: <web.49a538ddfa6cf65cbdc576310@news.povray.org>
Hum... then it might actually not work with my brick w/ holes?
Are the mesh generation and distortion separate steps, so that I might be able
to adapt the mesh generation algorithm to use those macros on my bricks?
Date: 25 Feb 2009 08:05:00
Message: <web.49a540ecfa6cf65c6dd25f0b0@news.povray.org>
It wouldn't work completely. You'd have to make the holes via a difference.
It perturbs each mesh point as it goes, so it'd be a bit of a rewrite I'm
afraid. But the technique is sound, as long as you could create your bricks as
meshes, all the perturbation needs is a normal and a pigment function.
Look at the code; it's in the object collection.
