Just for fun, I let POV render a flyby last night:
http://www.artspeakdesign.com/GlowedC.mov
and a still:
Download 'nowwithtrees.jpg' (145 KB)
Preview of image 'nowwithtrees.jpg'
Both absolutely stunning!
"Ouch ouch ouch!"
"What's wrong? Noodles too hot?"
"No, I have Chopstick Tunnel Syndrome."
Just keeps getting better. Just a few things:
When I last used radiosity with an animation, I did a quick pass with both
load_file and save_file on each frame to accumulate radiosity data. This got
rid of the flickering almost entirely. I'm not sure if this is proper
technique, but it worked anyway.
What about some hazy blue mountains in the background? I know it's a work in
progress, but it feels like it's floating in space without anything to frame
it.
The roofs look like they could use a little structure. The form is great, but
most of the roofs look like a single solid piece, which isn't really practical.
Like this, for example:
http://www.irtc.org/ftp/pub/stills/2002-08-31/golonls2.jpg
Don't worry. By the time someone is critiquing minutiae like this, you know
it's lookin' good.
- Ricky
Better and better. Where will it end? (no pun intended) :-)
Mmmm. The spring begins!
Paolo
> and a still:
"QuickTime is missing software required to perform this operation.
Unfortunately, it is not available on the QuickTime server."
Didn't say what was missing or where I might obtain it.
apple.com/quicktime
If that doesn't work, then maybe it's in divx or something.
divx.com
Isn't there an xvid, too?
xvid.com
When all else fails, MPlayer or VLC usually pull through for me.
- Ricky
H.264:
Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
Dunno where to get it for Windows nor Apple, though.
-Aero
Eero Ahonen <aer### [at] removethis zbxt net invalid> wrote:
> H.264:
Quicktime should be able to play that if it is up to date, but that one should
also be covered under VLC or MPlayer, which you may have better luck with on
Windows.
apple.com/quicktime
http://www.videolan.org/vlc/
- Ricky
Kirk Andrews wrote:
> I know I said I didn't have more time to work on it at present, and it's true, I
> don't. But sometimes my distractions overpower my focus.
Thinking on this, I bet you could do an awesome video with a bit of
planning. Angle the camera down so you can't see the horizon or behind, then
generate the castle as you go rather than all as one static scene, and do a
five-minute never-repeating fly-over. Perhaps even be clever and arrange for
the final bits to merge seamlessly with the initial bits, so you can loop
the video. Then you'd *really* have an endless palace.
My fortune cookie said, "You will soon be
unable to read this, even at arm's length."
