Kirk Andrews wrote:
> 2400x900? Should be done rendering in a couple hours.
2560x1024, but that'll work too. :) Thanks!
"Ouch ouch ouch!"
"What's wrong? Noodles too hot?"
"No, I have Chopstick Tunnel Syndrome."
> "Ouch ouch ouch!"
Close enough, right?
Download 'palace2400x900.jpg' (432 KB)
Preview of image 'palace2400x900.jpg'
Awesome. The 3-point perspective even works with the dual-monitors. :-)
"Ouch ouch ouch!"
Kirk Andrews escreveu:
> I know I said I didn't have more time to work on it at present, and it's true, I
> don't. But sometimes my distractions overpower my focus.
> I think this is a significant improvement over the previous images.
It's friggin' beautiful!
Now go back to work. ;)
BTW, what kind of technique did you use to ensure you didn't have (for
example) balconies without doors leading to them, or something like that?
(Other than the one that looks like it needs a trap door... :-)
I.e., what does the top-level loop look like, in general terms?
"Ouch ouch ouch!"
> "Ouch ouch ouch!"
Well, it basically works like this:
1. Determine the number of stories of each block and store in an array
2. Determine the type of roof for each block depending on info from the first
array, and store these in an array.
3. Run the loop. If there's an exit at the current level and direction, make a
door; if not, make a window. If you're at the top, make the appropriate roof.
Unfortunately, I do end up with lots and lots of nested #if statements.
I see. So you make a door on any side where you've already drawn a flat
roof. That makes sense. Cool. Thanks!
"Ouch ouch ouch!"
It's one of the nicest images I've seen in awhile.
In addition to the wonderful architecture and lighting, it has an undefinable
soft 'glow' to it, which is quite magical. Was there any special technique you
used to get that effect? Or is it just a result of the light direction and
radiosity?
Ken W.
A magical atmosphere!
Bravo!
Carlo
Thanks!
> radiosity?
> Ken W.
Ok, I'll tell my secrets. For almost all my renders, I take them into
Photoshop. I duplicate the image so I have two identical layers, and then I
set the top layer's blending mode to "overlay." I then apply a very slight
blur and adjust the opacity to taste. It's a simple technique that goes a long
way to add depth and mode to a scene.
