POV-Ray : Newsgroups : povray.binaries.images : Learning about Proximity patterns Server Time
17 Mar 2026 18:32:23 EDT (-0400)
  Learning about Proximity patterns (Message 1 to 7 of 7)
Subject: Learning about Proximity patterns
Date: 7 Dec 2008 13:05:01
Message: <web.493c1033b62e41ea198b63d90@news.povray.org>
Thanks to Sam for introducing me to the concept.  I had wanted to do something
like that before, but had never thought of using averaging an object pattern.
Some initial results:
Download 'columnprox.jpg' (68 KB)
Preview of image 'columnprox.jpg'
Subject: Re: Learning about Proximity patterns
Date: 7 Dec 2008 17:59:44
Message: <493c5560@news.povray.org>
Kirk,
That looks nice! It definitely has an aged appearance :) Is the object
CSG? I'm guessing it is, since you averaged object patterns together to
get the proximity effect. This would look even better in a complete scene ;)
I have an array of 251 points set in a regular spherical/cubic fashion
that I use for this very purpose. It effectively distributes the object
pattern in 3D space, thus reducing any inefficiencies arising from
complete randomization. A little randomization, though, helps avoid
other artifacts associated with such a regular pattern. Attached is a
pic showing how the elements are placed.
Sam
Download 'pts_sphere.jpg' (21 KB)
Preview of image 'pts_sphere.jpg'
Date: 7 Dec 2008 18:20:00
Message: <web.493c59b791f0b832ea3236f00@news.povray.org>
Ooh yes, this is a lovely technique. Thanks for the hint guys, I would never
have thought of using object patterns in this way. I must play with this in
future projects. Attached is my best experiment of the day, nowhere near as
believable as that column but it's just proof-of-concept for me!
I'm using a pure random distribution. I guess you could just jitter your points
in that illustration to keep a random element if it was ending up too regular.
This is interesting stuff. :)
Bill
Download 'shaded2.jpg' (36 KB)
Preview of image 'shaded2.jpg'
Date: 8 Dec 2008 18:10:40
Message: <493da970$1@news.povray.org>
/me wonders if this could be combined with a greeble macro. :-D
William Tracy
I disapprove of what you say, but I will defend to the death your right
to say it.
     -- Evelyn Beatrice Hall, frequently mis-attributed to Voltaire
Date: 8 Dec 2008 19:01:49
Message: <493db56d@news.povray.org>
> Bill
Though I already replied so second reply:
Yes Bill, with your mesh macros you can do the same averaging in certain
cases before applying the pattern to the mesh to get some similar
weathering effects.  Here I jitterd and averaged the radial pattern that
was used to get the fluting in the column to get a weathered look, then
applied it to the mesh.
http://tinyurl.com/5oqr7u
Date: 9 Dec 2008 04:10:00
Message: <web.493e356091f0b832d5b77e4a0@news.povray.org>
Yes, of course. I remember thinking this looked good but I couldn't immediately
see why (compared with my experiments). Once I know what to look for, I can see
it. I hadn't thought of jittering the source pattern either, my quick test above
is derived from just the base shape, which is why it doesn't quite look right.
For even greater realism, I must also experiment with Sam's fastprox macro,
since it appears to only require a simple patch to make it work with meshes.
*rubs hands with enthusiasm*
Date: 9 Dec 2008 08:14:20
Message: <493e6f2c@news.povray.org>
news:web.493e356091f0b832d5b77e4a0@news.povray.org...
> macro,
> meshes.
It does. This is a rapid test of Sam's macros using a mesh2.
From left to right:
  fastProx()
  fastProx2()
  fastProx3()
  fastSSS2()
Download 'SB_fast_prox_test.jpg' (70 KB)
Preview of image 'SB_fast_prox_test.jpg'
