POV-Ray : Newsgroups : povray.binaries.images : One more light dome based test image Server Time
12 Apr 2026 07:21:42 EDT (-0400)
  One more light dome based test image (Message 1 to 3 of 3)
Subject: One more light dome based test image
Date: 30 Jul 2008 17:15:00
Message: <web.4890d961cf7eef0fa8993fbc0@news.povray.org>
One more image rendered with a light dome auto-generated from an HDR lightprobe.
This scene has 200 area lights; each just 3x3 with jitter and orient.
The central sphere's dull reflection is simply phong highlights to the 200 light
sources (and microfacets to give it a slightly rougher appearance).
The floor is just a plane with an image, a bump map, and a specular map setting
the variable reflection.
Finally I photoshopped it to give it a slightly more "photographic" appearance
(a glow
effect, a lens distortion, and adding slight noise into the darker areas of the
scene). The impact was minor, but I think helps. People have code to
do those things inside POV, but I just prefer using Photoshop.
Cheers,
Edouard.
Download 'phong-200-lights.jpg' (230 KB)
Preview of image 'phong-200-lights.jpg'
Subject: Re: One more light dome based test image
Date: 30 Jul 2008 19:42:39
Message: <4890fc6f$1@news.povray.org>
Edouard Poor napsal(a):
> (a glow
> Cheers,
> Edouard.
I like the chromatic abberation
Date: 30 Jul 2008 20:35:00
Message: <web.489107dfe8f12e8717e538890@news.povray.org>
> > (a glow
The chromatic aberration is part of the lens distortion in Photoshop. Actually
there is a filter called "Lens Correction", but you can take a clean image
(i.e. ray traced) and apply barrel distortion, chromatic aberration and
vignetting instead of the more usual case of removing them from a photographic
image. The only (slight) limitation with the filter is that it can't work on
32bit (HDR) images, only 16bit ones. In practice it's pretty good.
I got the idea from Tek's amazing RSOCP image:
http://teknof.deviantart.com/art/YARSOCP-53555325 but used Photoshop rather
than doing the effect "in camera".
The other two effects added in Photoshop were done by hand: the glow and adding
noise to darker areas.
Cheers,
Edouard.
