"Chris B" <nom### [at] nomail com> wrote:
> "Chris B" <nom### [at] nomail com> wrote in message
> news:485feae7$1@news.povray.org...
> > "Tim Attwood" <tim### [at] comcast net> wrote in message
> > news:485eec4c$1@news.povray.org...
> >>> Just to inflict interest, here a poor man's attempt:
> >>> Needs so much work. Like building a model, argh. Crude bumped disk so
> >>> far.
> >> The inner ring has all the interesting glyphs (39?), I think you could
> >> save those out as heightfield images, it's probably most of the detail
> >> of the stargate. There's some ribs between the glyphs, more
> >> crenellation on a lip, and a tapered inner edge.
> > I reckon I can do the Glyphs for the Milky Way stargate pretty quickly
> > because there's an SVG by Max Willis on the Wiki, so I can convert them
> > into
> > prism objects using Inkscape and cut them out of the inner disk using CSG.
> I've posted the 39 Glyphs as prism objects on povray.binaries.scene-files
> along with this very crude scene file that cuts them out of segments of a
> ring and assembles the segments into a circle. If anyone wants to use them
> to make a stargate I'd be happy to go through and scale and centre them as
> needed.
> Regards,
> Chris B.
Here's my WIP from a while back. Maybe you can take it farther than I did.
http://news.povray.org/povray.binaries.images/thread/%3Cweb.43efa50f2b248055dff42daa0%40news.povray.org%3E/?mtop=2
I don't recall if I ever posted an animation or not, but I'll see if I can dig
something up and post a scene in scene-files. I'd love to see more, now that
SG-1 is off the air I'm a bit nostalgic about it.
Mike
Download 'stargate_04.jpg' (96 KB)
Preview of image 'stargate_04.jpg'
"Mike Sobers" <mcn### [at] msn com> wrote in message
news:web.486063afcd5f2f2f4363abf40@news.povray.org...
> did.
> dig
Or it would make a good addition to the object collection if you're ok with
the LGPL license.
Chris B.
"alphaQuad" <alp### [at] earthlink net> wrote:
> http://blenderartists.org/forum/archive/index.php/t-103776.html
> Freekin 30 meg StarGate.blend file. Doh.
> Spent like 10 minutes trying write a Wavefront file with Blender,
> gave up at around a 150meg obj file thinking I could make my own in less time!
> http://en.wikipedia.org/wiki/Stargate_%28device%29
> http://en.wikipedia.org/wiki/Image:Milky_way_stargate_with_very_detailed_glyphs2.svg
> Any skilled ideas out there?
> Something more like this, only not 30 or 150 megabytes:
> http://en.wikipedia.org/wiki/Image:SG1stargate.jpg
> or even like this:
> http://www.stephenmeli.net/images/irisopen.jpg
> Needs so much work. Like building a model, argh. Crude bumped disk so far.
Any way I could gt the OBJ file?
www.scifi-meshes.com has low-res and high-res versions of the stargate and dhd.
you have to create a log-in to download, but if that doesn't work, I think I
have them on my HD.
> > >>> far.
> > > into
> > needed.
> > Regards,
> > Chris B.
> Mike
Mike,
Would like to take a look a your stargate model. I've been working on my own,
using CSG and converted meshes using POVRay and Moray but have not been getting
to far with work demands. I've completed (to my own satisfaction anyway) a
proportional chevron model, if you care to see it. Is on my home computer so I
will upload tonight.
I would like to see your source/code/file, if you don't mind.
I also currently have a 3ds low-res and hi-res version downloaded from
scifi-meshes.com (see previous posts)
-Jeff
stbenge <stb### [at] hotmail com> wrote:
> http://lib.povray.org/collection/hfarch/sam%201.0/stbhfarch.jpg
> http://lib.povray.org/collection/hfarch/sam%201.0/stbhfarch.html
Hmm ... I see a pic and a discussion:
I *was* lost, then I was found:
search: stbhfarch = dlbutton
Looks like Sam is gonna teach me a thing or two, will take a look.
> Sounds like a perfect collaborative project for the object collection.
> So does the inner ring have a wedge shaped cross-section?
You know as much or more than I about the cross-section shape.
"perfect collaborative project" are exciting words to me, wishing I could claim
a part.
My part will be to educate myself so I am worth something to future projects and
to do anything that doesnt get done on this, one way or another.
thanks to everyone,
aQ
Not currently considering I gave up on it, not to mention size.
I am not sure "lordso'ringsjunkie" (stephen) file is available in low res:
http://www.scifi-meshes.com/meshes/index.php?ACT=search
search: stargate
Event horizon: 2meg
http://www.scifi-meshes.com/meshes/index.php?dlid=239
> have them on my HD.
Blender files you make available I'll convert to .obj and .mtl if you need.
aQ
Yeah, there was no direct download link, but you seemed to have found it
just fine :)
Hmm, if you are referring to the large help file, sorry about that. I
wanted to document every feature. The feature list was originally small,
but I kept of finding logical additions that no complete inc file could
be without. So, it's a little bloated, but it does what it's meant to! ;)
Sam
The mesh was added to Chris' stargate glyph post, over in
povray.binaries.scene-files,
The event horizon has become another exercise in pulling out true map colors
(again)
The planets were looking like all was needed was radiosity and array lighting.
Now I'm washed out again.
#declare event =
disc { <0, 0, 0>, -z, 1
normal {
waves 0.2
rotate z*45
frequency 5000
scale 180
phase clock*-.5
image_map {
png "eventtex.png"
once
transmit all .5 filter all 0
scale <1,1,1>
finish {
ambient 0
brilliance 2
diffuse 1.2
metallic
specular 0.1
roughness 1/80
reflection 0.5
scale 2
translate <-1,-1,0>
results in 20-30 more minutes
Download 'eventtex.png' (636 KB)
Preview of image 'eventtex.png'
A mistake in event texture for this render caused reflection to skew off right
but I caught it before posting the previous event object.
If you can get true colors from a map, feel free to show us, it is a recurring
issue.
Download 'gate03.png' (413 KB)
Preview of image 'gate03.png'
check those 2 posts again, dare I speak, heh.
whenever synchronicity occurs, Archetypes at play, magic afoot
