POV-Ray : Newsgroups : povray.binaries.images : Tracing an object through a soft-edged mask; or objects as airbrush 'spray' Server Time
30 Mar 2026 15:11:16 EDT (-0400)
  Tracing an object through a soft-edged mask; or objects as airbrush 'spray' (Message 4 to 13 of 33)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Tracing an object through a soft-edged mask; or objects as airbrush 'spray'
Date: 12 May 2008 22:26:22
Message: <4828fc4e@news.povray.org>
"Kenneth" <kdw### [at] earthlinknet> wrote
> BTW, in working with this technique (and running some other experiments),
I've
> found that rand() doesn't actually HIT zero or one.
A pseudo random generator should in practice not hit *any* given number, not
just 0 and 1, unless you cover its period at least a few times. Further, in
practice again, some (or many) numbers in range will simply be "unhittable".
Subject: Re: Tracing an object through a soft-edged mask; or objects as airbrush 'sp=
Date: 13 May 2008 02:35:00
Message: <web.48293172dace545278dcad930@news.povray.org>
> I've found that rand() doesn't actually HIT zero or one.
Not sure I understand what you mean by *period*.  Would that be *all* the
possible numbers between 0 and 1 that can conceivably be found in Pov_Ray? In
one test I did--looking for a 0 or 1 hit --I used a #while loop that iterated
10,000,000 times. No "hits"--though, admittedly, that's not 2^32 tries. I
thought of actually going "to the limit," but demurred because of the quite
lengthy parse time involved. Is it possible that I just
haven't tried hard enough? So by the same reasoning: If I chose some value
between 0 and 1 at random--say, .0005674836--and actually TRIED to hit that
with rand(), would the possibility of success be the same as trying to hit 0 or
1--i.e., practically nil? I'm beginning to see some light here--that "0" and "1"
constitute just two of a huge range of possible hits...and I can't expect to
pick JUST those two exact values out of such an ocean of numbers--without
searching the entire ocean, so to speak (and multiple times!) BUT, I still
harbor the sneaking thought that 0 and 1 may *in fact* be out-of-range. Hard to
prove or disprove, I suppose. As a practical matter, they just don't ever
seem to pop up. But I suppose you could say the same thing about .0005674836!
Thanks for your comment; it has made me think about this situation in depth.
As to some values being unhittable--can't say I understand why, unless it has
something to do with underlying computational processes that I don't understand
(and I don't understand plenty, when it comes to such things! :-)
Ken W.
Date: 13 May 2008 02:50:00
Message: <web.482939d38a21c37b78dcad930@news.povray.org>
"Mike the Elder" <nomail@nomail> wrote:
> Very clever indeed. Thanks for sharing this. "Irfanview", a freeware program,
> has radial and zoom blur functions that might lead to some interesting masks.
I appreciate the nice comments. (I've actually been sitting on this technique
for about six months, and finally got off my arse to post it.) Thanks also for
the Irfanview link; I hadn't heard of that app before.  Will try it out.
KW
Date: 13 May 2008 03:00:44
Message: <48293c9c$1@news.povray.org>
Thank you indeed, Kenneth!!!
What a perfect and simple idea! And so many applications come to mind! Can't
wait to experiment with this.
Date: 13 May 2008 04:34:10
Message: <48295282@news.povray.org>
Just a very rapid example, taking a random photograph I had, without
particular blurring I must say, but still a nice result.
Thanks again, Kenneth!!
Download 'Kenneth airbrush.jpg' (103 KB)
Preview of image 'Kenneth airbrush.jpg'
Date: 13 May 2008 04:38:32
Message: <48295388@news.povray.org>
...and using  pow(rand(S2), .333)....
Download 'Kenneth airbrush2.jpg' (67 KB)
Preview of image 'Kenneth airbrush2.jpg'
Date: 13 May 2008 04:59:46
Message: <48295882@news.povray.org>
...and increasing the number of objects (x10 Kenneth's example).
And now I stop!  :-)
Download 'Kenneth airbrush3.jpg' (103 KB)
Preview of image 'Kenneth airbrush3.jpg'
Date: 13 May 2008 05:15:25
Message: <48295c2d$1@news.povray.org>
"Kenneth" <kdw### [at] earthlinknet> wrote in message
news:web.48293172dace545278dcad930@news.povray.org...
experiments),
not
in
"unhittable".
Correction, I was mixing two things. With a pseudo-rng, you need to only
cover the period once (after that, it starts repeating). With a
physical/hardware rng, you can of course never be sure, but in practice, if
you cover the domain of possible values a few times over, you can develop
enough confidence. I don't know what POV uses for rng.
has
understand
That happens if the period of a rng is smaller than the domain of generated
numbers (ie a rng with period 2^30 returning 32 bits won't hit 75% of the
numbers in the domain).
Date: 13 May 2008 06:13:35
Message: <482969cf$1@news.povray.org>
Cool, but you don't need the height_field, just use eval_pigment.  That way,
you can use any pigment as a mask
something like this:
--- begin code ---
#include "functions.inc"
#local TraceObject=plane {y,0}
#local Mask=pigment {granite poly_wave 2}
#local Number=100000;
#local Seed=seed(123);
union {
    #while (Number>0)
        //trace from a random value ranging from <-2,..,-2> to <2,..,2>
        #local
TracePosition=<rand(Seed)-rand(Seed),500,rand(Seed)-rand(Seed)>*<2,1,2>;
        #local Position=trace(TraceObject,TracePosition,-y);
        //Two ways: use the mask as a 2D mask, using only the X and Y values
        #local
Probability=eval_pigment(Mask,<Position.x,Position.z,0>).gray;
        //or... use it as a 3D mask
        #local Probability=eval_pigment(Mask,Position).gray;
        #if (rand(Seed)<=Probability)
            sphere {
                Position,.01
        #local Number=Number-1;
    pigment {red 1}
object {TraceObject pigment {rgb 1}}
//camera and light_source
    location <-3,5,-10>
    look_at 0
light_source {
    <500,500,-500>
    rgb 1
--- end code ---
cu!
Date: 13 May 2008 07:27:39
Message: <48297b2b$1@news.povray.org>
You had the same idea as me :-)
I changed Kenneth's code to use eval_pigment instead of a height_field, I
noticed that parsing was much longer, and also that POV was faster 'out of
memory' with a large number of objects. I don't know if this is a
significant difference due to the different methods, but there it is.
