"Kirk Andrews" <kir### [at] tektonart com> wrote:
> If nothing else, it'd be great to have a diffuse reflection option built-in to
> POV. I always thought that it shouldn't be that complicated to do, but I'm no
> programmer myself.
Seems pretty natural. Can't really be faked with a normal either. This method
for path tracing is simple, but it seems perhaps too invasive to properly
integrate it. Now what POV-Ray could really use is email support. Just
remember Zawinski's Law of Software Envelopment:
Every program attempts to expand until it can read mail. Those programs which
cannot so expand are replaced by ones which can.
Therefore I propose we add an email tab to the GUI versions of POV-Ray.
- Ricky
"triple_r" <nomail@nomail> wrote:
> Sorry in advance for just another uninspired post of random spheres. I'll try
> to use more restraint in the future. Few hours to render (after continuing a
> couple times so not exactly sure), meshed with splines in POV-Ray, no light
> sources, and no radiosity. ;-)
> - Ricky
I'd like to know how you created the spheres. I'm afraid my maths isn't up to
creating such neat objects.
Posted to p.t.s-f, with switches for radiosity or path-tracing, and everything
you need to try out the path-tracing.
- Ricky
"triple_r" <nomail@nomail> schreef in bericht
news:web.481370f1dcce95a6dcb320720@news.povray.org...
> which
...and brew coffee! Every program should be able to brew coffee! No version
of POV is complete unless it brews coffee!!
[not really addicted]
> - Ricky
First of all, thanks for the source.
I would like to try both those lines of code for the path-tracing.
But unfortunately I have not found a guide to help ignorant like me (I am stupid
as a goose) to compile POV-Ray.
Should still work fine with radiosity, but as for compiling, just ask. I can
only help if you're on Mac or Linux/Unix, but all you have to know how to do is
tell it to compile. Once that's set up, it doesn't require any manual effort.
It may require some sort of free download from Microsoft, but on a Unix-based
system everything should be set up to go. May take a bit of effort to figure
it out, but it should certainly be possible.
- Ricky
Hey,
Wow...nice man. I can never seem to pull off stuff like that..
But then I paint in abstract and want to do realism...they say an artist can
never produce art of the style they wish..
This has proven true for me. >_<
Well, I like the composition (use of traditional isosceles triangle), the
contrast; both in intensity of brightness and complexity of objects used
versus layout composition. I like as well the (perhaps accidental color
relationship?) missing implicit primary color glow within the foremost
sphere.
The only thing I might do differently is use different spheres for each of
the three, perhaps with a very slightly varied surface normal or texture.
Very good.
Ian
The Root of all Evil.
"triple_r" <nomail@nomail> wrote in message
news:web.4812957293f61de8dcb320720@news.povray.org...
> try
> continuing a
> light
> - Ricky
Looks JUST GREAT!!!!! Kinda beachy, kinda early eveningish.
Sven
"triple_r" <nomail@nomail> schrieb im Newsbeitrag
> try
> continuing a
> light
> - Ricky
By the way, can you e-mail me a large image of this creation, maybe
1600x1200 pixels? Or even the source code? That would be great! Thanks.
Sven
> Sven
Thanks. The whole source, commented to the point that it reads like a book, is
in p.t.s-f under "Fancy sphere with 'Path-tracing'". The trivial modification
to the POV-Ray source for the path-tracing is included, although based on some
quick tests, it should look no different than the radiosity version which is
turned on/off with with the path_tracing_on variable. The radiosity settings
have not been tested very well, so you should be able to render it with those,
but it sure won't be optimal. Hope that works!
- Ricky
