POV-Ray : Newsgroups : povray.binaries.images : A bit of greenery Server Time
14 Apr 2026 02:58:28 EDT (-0400)
  A bit of greenery (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: A bit of greenery
Date: 9 Apr 2008 12:30:01
Message: <web.47fced44f86d0881b555cae70@news.povray.org>
"Andris R" <nomail@nomail> wrote:
> First post and first larger povray image
> I can not get rid of several dark spots no mater how ambient and diffuse in
> finish are changed.
> Leaf is done in wings and so is the grass stem, the rest is povray
Very nice!  I don't see any mischievous dark spots, myself.  I would suggest
that the realism could be quite improved if you used radiosity and turned off
ambient lighting (as has already been suggested).  Just be prepared for 10x the
render time, but it'll be worth it.
For outdoor scenes, I usually boost the sunlight strength to 3 or beyond (rgb
<1,.9,.5>*3).  Also, try adding double_illuminate to your leaf texture.
I look forward to your next post!
Date: 10 Apr 2008 04:10:00
Message: <web.47fdcaccf86d0881608a67600@news.povray.org>
Nice pic, I like the wall effect of the leafs.
The two puddles are very similar, substracting realism in the image, in addition
the floor looks too flat outside of the puddles... the ground gaps looks like
someone intentionally turn over the stones.
Very likely, a few more natural disposition of the elements in the scene (the
stone path along a curve or in S-shaped) could contribute to improve the
picture.
Date: 10 Apr 2008 09:45:01
Message: <web.47fe1947f86d08812686924d0@news.povray.org>
Thank you all for comments and I`m glad you liked the image.
Will try out your suggestions and, if result will be worthwhile, will post it
here.
Right now (in fast renders) double_illuminate gives some promising results.
Yes, I use radiosity, image took 10 hours :). Will try to increase
max_trace_level.
I use very small value for ambient, but probably it is useless.
Water has not received much attention yet and looks frozen to me.
Date: 10 Apr 2008 15:34:34
Message: <47fe6bca@news.povray.org>
Andris R napsal(a):
> here.
> max_trace_level.
Ambient harms radoisity. It makes the objects _emit_ rather than
rebounce light.
Date: 10 Apr 2008 21:58:59
Message: <47fec5e3@news.povray.org>
It strikes me as being a little too reflective.
William Tracy
Amnesia's where you forget something, right?
     -- overhead in a parking lot
Date: 11 Apr 2008 12:42:55
Message: <47ff950f$1@news.povray.org>
Andris R nous apporta ses lumieres en ce 2008/04/10 09:42:
> here.
> max_trace_level.
When using radiosity, you should change any ambient in any texture to zero, not
a small or very small value. The only exeption is for objects that are *suposed*
to emit light.
You know you've been raytracing too long when you think 80s movies have the
funniest special effects.
Aaron Gage a.k.a Slartibartfast
Date: 17 Apr 2008 04:35:01
Message: <web.48070abaf86d08812686924d0@news.povray.org>
Ok, there is another try.
All ambients are off now :)
Thanks all for comments and help
As for the flattness and randomness in pavement ...
currently one trace is used to position a tile.
On a more bumpy surface it would be insufficient, because a normal vector,
such that most of the tile`s surface lies flat on ground, must be found,
else pavement looks awfull.
I`m still thinking on that.
Now off to learn better texturing ...
Download 'greenery_e.jpg' (510 KB)
Preview of image 'greenery_e.jpg'
Date: 17 Apr 2008 09:59:08
Message: <480757ac@news.povray.org>
Andris R napsal(a):
It looks much better now.
Date: 18 Apr 2008 12:09:03
Message: <4808c79f$1@news.povray.org>
en ce 2008/04/17 04:30 :)   ->
Nice improvement. Any "dark" spots are where I "expect" things to be darker,
like where I can see deeper into the bushes.
BACHELOR: A man who never makes the same mistake once.
Date: 18 Apr 2008 16:27:43
Message: <4809043f@news.povray.org>
"Andris R" <nomail@nomail> wrote in message
news:web.48070abaf86d08812686924d0@news.povray.org...
   Looks much better imo. I like the addition of the new hill/mountain and
trees/bushes in the distance. Good work. :)
     ~Steve~
