POV-Ray : Newsgroups : povray.binaries.images : Challenging radiosity Server Time
2 Apr 2026 10:24:46 EDT (-0400)
  Challenging radiosity (Message 11 to 19 of 19)
Subject: Re: Challenging radiosity
Date: 4 Apr 2008 11:05:55
Message: <47f651e3$1@news.povray.org>
Mike the Elder wrote:
> I, cannot, however endorse your admonition to stay away from blinds. Our very
> survival depends on window blinds.  Without them, it would be curtains for
> everyone!  ;-)
This panes me deeply.
This is drape. Just drape.
You shade know better.
William Tracy
Who could pollute the entire world?
     -- Nausicaa
Date: 4 Apr 2008 11:20:01
Message: <web.47f653ebfe9c4eea5a8888d90@news.povray.org>
I see you've mustard up some puns that you think
will make you the wiener of this contest.
Although I relish the challenge, I fear you will
never ketchup.
Boast Regards,
Mike C.
Date: 5 Apr 2008 02:46:04
Message: <47f72e3c$1@news.povray.org>
"triple_r" <rre### [at] hotmailcom> schreef in bericht
news:web.47f62829fe9c4eeaae42298f0@news.povray.org...
> "Thomas de Groot" <t.d### [at] internlDOTnet> wrote:
>> we should need to see your radiosity settings...
> Sorry.  Of course.  Here are the settings for the high quality render:
> radiosity {
>  normal off
>  count 300
>  recursion_limit 2
>  error_bound 0.35
>  pretrace_start 0.08
>  pretrace_end 0.02
Like Bill said, you could decrease error_bound to 0.2, but I would increase
count to 1000 at least. Also pretrace_end should be much lower for better
results.
I post below the settings I have used for an indoor scene, using 2-pass
radiosity. Maybe you could try that.
//--- start code ---
    radiosity {
      //saving radiosity data:
      #if (RadSave)
        save_file "DG1.rad"
        pretrace_start 0.1           // start pretrace at this size
        pretrace_end   0.0025           // end pretrace at this size
        always_sample on            // turn sampling in final trace off [on]
        count 1000
        error_bound 0.2
        recursion_limit 2
      //reading radiosity data:
      #else
        load_file "DG1.rad"
        pretrace_start 1
        pretrace_end 1
        always_sample off            // turn sampling in final trace off
[on]
        count 100
        error_bound 1.8
        recursion_limit 1             // how much interreflections are
calculated (1..5+) [3]
      //common settings:
      brightness 1                  // brightness of radiosity effects
(0..1) [1]
      nearest_count 8               // higher -> higher quality (1..10) [5]
can go up to 20. little effect on render time higher is better
      adc_bailout 0.005
      low_error_factor 0.8           // reduce error_bound during last
pretrace step
      minimum_reuse 0.015           // reuse of old radiosity samples
[0.015]
      gray_threshold 0            // increase for weakening colors (0..1)
[0]
      normal off                    // take surface normals into account
[off]
      media off                     // take media into account [off]
      //max_sample 1.0              // maximum brightness of samples
//--- end code ---
good luck! And by the way, you have there a nice image/scene!
Date: 6 Apr 2008 06:13:14
Message: <47f8a23a@news.povray.org>
triple_r wrote:
> I have to confess I cheated.  This is a combination of two renders.
Nice image! The sad part is that it takes just too much effort to render
it accurately - and still you get errors/can't be sure when the result
is correct. You should ask if fidos could make a reference render of it
with his path tracing Pov.
Date: 6 Apr 2008 21:56:21
Message: <47f97f45$1@news.povray.org>
Well, Triple, I couldn't help you with the artifacts. But I can give you
another great advise: replace the dog on the couch with a naked, very curvy
girl laying on the couch, and see full of excitement, how the stripes of
light play on her curvy back...
"triple_r" <rre### [at] hotmailcom> schrieb im Newsbeitrag
news:web.47f617807305684bae42298f0@news.povray.org...
>I have to confess I cheated.  This is a combination of two renders.  The
>low
> quality render has fewer artifacts on the blinds because it just smoothes
> them
> over, but lots of artifacts around the ceiling.  The higher quality render
> cuts
> down on artifacts around the ceiling, but causes a lot of artifacts on the
> blinds.  I went all the way up to count=1600 without any improvement.
> Wherever
> there's a gap there are a lot of artifacts.  Does this mean I have not
> balanced
> count and error_bound correctly, or does anyone have other ideas on how I
> might
> improve or fake the rendering quality?  Either way, my tip for the day?
> Stay
> away from blinds.
> - Ricky
Date: 8 Apr 2008 19:02:34
Message: <47fbf989@news.povray.org>
> low quality render has fewer artifacts on the blinds because it just
> smoothes them
> cuts down on artifacts around the ceiling, but causes a lot of artifacts
> on the
> Wherever
> balanced count and error_bound correctly, or does anyone have other ideas
> on how I might
> Stay away from blinds.
Nice :)
Will you share the source perhaps?
There are afair patches to have over 1600 samples, and/or have them better
distributed
Date: 9 Apr 2008 11:20:00
Message: <web.47fcdddafe9c4eeaae42298f0@news.povray.org>
=?UTF-8?B?UmFmYcWC?= Maj <no.### [at] invalidcominvalid> wrote:
> Nice :)
I would be glad to, but it's a little big.  In the interest of time I went with
image maps and meshes rather than the purist POV way.  Don't have time at the
moment, but maybe I'll scale down the images, save some lower-resolution meshes
and post it.
 - Ricky
Date: 22 Apr 2008 23:10:00
Message: <web.480ea7eefe9c4eea989e735d0@news.povray.org>
"triple_r" <rre### [at] hotmailcom> wrote:
> I have to confess I cheated.  This is a combination of two renders.  The low
> quality render has fewer artifacts on the blinds because it just smoothes them
> over, but lots of artifacts around the ceiling.  The higher quality render cuts
> blinds.  I went all the way up to count=1600 without any improvement.  Wherever
> there's a gap there are a lot of artifacts.  Does this mean I have not balanced
> count and error_bound correctly, or does anyone have other ideas on how I might
> improve or fake the rendering quality?  Either way, my tip for the day?  Stay
> away from blinds.
>  - Ricky
You might want to consider, if you haven't done it, adding some ambient value to
the drapes and the rooms materials. I've had some success in eliminating those
artifacts without having to ramp up the radiosity quality levels to extremes.
Date: 23 Apr 2008 00:35:00
Message: <web.480ebc4cfe9c4eeaae42298f0@news.povray.org>
Indeed there is about 0.1 or 0.15 for ambient on the blinds, if I recall.  Adds
some 'translucency' too.  Seems to be one of those scenes where low quality
radiosity is worth the tradeoff of fewer artifacts.  Actually the best luck I
had was with the pseudo-path-tracing method (change reflection to randomly
diffuse reflection).  Worked great with just a few minutes for setup, although
it sure took a while--and no textures, of course.  Thanks for the suggestion.
 - Ricky
