POV-Ray : Newsgroups : povray.binaries.images : Real Clouds with Real Problems Server Time
14 Apr 2026 02:58:21 EDT (-0400)
  Real Clouds with Real Problems (Message 29 to 38 of 38)
Subject: Re: Real Clouds with Real Problems
Date: 15 Jan 2018 03:45:01
Message: <web.5a5c694f91cbe459ecbf4b3e0@news.povray.org>
> > "Bruno Cabasson" <bru### [at] alcatelaleniaspacefr> wrote:
> >> The same with a higher sun.
> > I know this is a very long time ago thread, but if it can be responded I want to
> > know what is the pattern (density) of the cloud. I'm doing some effort in a
> > program which need generate cloud shape. And this... I admire its pattern.(and
> > with its cloud thickness)
> For single clouds, you can use the spherical pattern, scaled to the
> desired proportions, and add some turbulence.
> For a group of clouds, you can use the bozo/bumps pattern and modulate
> it with a granite or agate pattern, also with a fair amount of turbulence.
> You can use several wrap{turbulence...} at various scales to get the
> fine details. You can also increase the octaves and use larger omega
> parameter to get a similar effect.
> For stratus clouds, a simple plane with some pattern can do the trick.
> Those are high altitude, thin clouds.
It seems most of people using turbulence doing the trick
Date: 15 Jan 2018 04:00:01
Message: <web.5a5c6d0391cbe459ecbf4b3e0@news.povray.org>
> For the cloud shape itself, I use turbulence (and its 'omega' value) in the
> media's density statement, to get the broken-up wispy look; although,
> Kontemplator's use of the granite pattern (and no turbulence) is an interesting
> way to do it too. The correct amount of turbulence/omega is really an artistic
> decision-- whatever looks pleasing. It's difficult to say what the 'correct'
> cloud shape should be.
> Kirk Andrews' clouds in his original image posts here look quite sophisticated--
> probably a *combination* of media types (scattering and absorption, maybe) as
In fact I mean  Bruno Cabasson's image.
> well as scattering media for the overall atmosphere, to cast light-shadow rays.
> His clouds look like they are scaled smaller in the y-axis (in other words, the
> original spherical cloud shape was squashed down slightly) to make them look
> more realistic.
> This code is for one of my own typical clouds-- although I usually change
> *something* every time I make one!
> sphere{0,1
> hollow on
> texture{
>     pigment {rgbt 1}
>     finish {ambient 0 diffuse 1}
>     interior{
>         media{
>             scattering{1, 3.0 extinction 1.0}
>             absorption 1.0
>             method 3
>             intervals 1
>             samples 20
>             density{
>                 spherical
>                     color_map{
>                             [0.22 rgb 0]
>                             [0.32 rgb 1]
>                             [1.0 rgb 1]
>                    scale 2.5
>                    warp{turbulence .8 omega .7}
>                    scale 1/2.5
>           scale <1,.6,1>
I will try
Date: 15 Jan 2018 08:40:01
Message: <web.5a5caef691cbe459ecbf4b3e0@news.povray.org>
> > more realistic.
> > sphere{0,1
> > hollow on
> > texture{
> >     pigment {rgbt 1}
> >     interior{
> >         media{
> >             absorption 1.0
> >             method 3
> >             intervals 1
> >             samples 20
> >             density{
> >                 spherical
> >                     color_map{
> >                             [0.22 rgb 0]
> >                             [0.32 rgb 1]
> >                             [1.0 rgb 1]
> >                    scale 2.5
> >                    scale 1/2.5
> >           scale <1,.6,1>
> I will try
I'm surprised at the result, it's good enough. I composed it with a scene.
Download 'scene finish.png' (1370 KB)
Preview of image 'scene finish.png'
Date: 15 Jan 2018 08:50:00
Message: <web.5a5cb0ae91cbe459ecbf4b3e0@news.povray.org>
It is rich of detail.
Date: 17 Jan 2018 06:41:13
Message: <5a5f3659$1@news.povray.org>
And wrote on 15/01/2018 14:46:
And the scene is very nice.
Paolo
Date: 17 Jan 2018 08:40:01
Message: <web.5a5f513891cbe459ecbf4b3e0@news.povray.org>
> Paolo
Thank you, when I was a child, I liked draw pictures with small elves. But now
when I want to draw some pictures like that with 3d, I feel hard.
Date: 17 Jan 2018 12:25:30
Message: <5a5f870a$1@news.povray.org>
>> Paolo
I, like Paolo, like this scene. :-)
By the bye, the last clause in your post has multiple meanings in
English. One of them, aggressive and another has sexual connotations.
I just thought I would mention, in case you say it in mixed company. ;-)
Regards
Date: 17 Jan 2018 20:30:01
Message: <web.5a5ff81791cbe459adc76a290@news.povray.org>
> >> Paolo
> Regards
>      Stephen
What? I don't know. I fact, I still save the pictures.
Download 'img_0009.jpg' (1745 KB)
Preview of image 'img_0009.jpg'
Date: 22 Jan 2018 03:19:07
Message: <5a659e7b$1@news.povray.org>
And wrote on 18/01/2018 02:27:
>>>> Paolo
>> Regards
>>       Stephen
The elves are very cute ;-) your drawing is like a videogame screenshot.
They doesn't seem too difficult to realize in POV-Ray, you can use them
to populate your scene.
Paolo
Date: 23 Jan 2018 08:20:00
Message: <web.5a6735e091cbe459f0a449000@news.povray.org>
> >>>> Paolo
> >> Regards
> >>       Stephen
> Paolo
I almost can't treat the pictures as mine. It's too long time. But it still give
me something. Characters in the pictures.
