The same with a higher sun.
Download 'sky_28.png' (540 KB)
Preview of image 'sky_28.png'
This one is not bad too.
Download 'sky_33.png' (149 KB)
Preview of image 'sky_33.png'
I know this is a very long time ago thread, but if it can be responded I want to
know what is the pattern (density) of the cloud. I'm doing some effort in a
program which need generate cloud shape. And this... I admire its pattern.(and
with its cloud thickness)
I also like some other ones by different person. But It would be great if ... I
can imitate its fluffy feature.this image.
Have you looked at
http://www.f-lohmueller.de/pov_tut/backgrnd/p_sky1.htm
yet?
Mosty I use the granite pattern for fluffy clouds:
density{ granite scale 5
turbulence 0
color_map {
[.5 rgb 0.0]
[1 rgb 1.0]
For single clouds, you can use the spherical pattern, scaled to the
desired proportions, and add some turbulence.
For a group of clouds, you can use the bozo/bumps pattern and modulate
it with a granite or agate pattern, also with a fair amount of turbulence.
You can use several wrap{turbulence...} at various scales to get the
fine details. You can also increase the octaves and use larger omega
parameter to get a similar effect.
For stratus clouds, a simple plane with some pattern can do the trick.
Those are high altitude, thin clouds.
For the cloud shape itself, I use turbulence (and its 'omega' value) in the
media's density statement, to get the broken-up wispy look; although,
Kontemplator's use of the granite pattern (and no turbulence) is an interesting
way to do it too. The correct amount of turbulence/omega is really an artistic
decision-- whatever looks pleasing. It's difficult to say what the 'correct'
cloud shape should be.
Kirk Andrews' clouds in his original image posts here look quite sophisticated--
probably a *combination* of media types (scattering and absorption, maybe) as
well as scattering media for the overall atmosphere, to cast light-shadow rays.
His clouds look like they are scaled smaller in the y-axis (in other words, the
original spherical cloud shape was squashed down slightly) to make them look
more realistic.
This code is for one of my own typical clouds-- although I usually change
*something* every time I make one!
sphere{0,1
hollow on
texture{
pigment {rgbt 1}
finish {ambient 0 diffuse 1}
interior{
media{
scattering{1, 3.0 extinction 1.0}
absorption 1.0
method 3
intervals 1
samples 20
density{
spherical
color_map{
[0.22 rgb 0]
[0.32 rgb 1]
[1.0 rgb 1]
scale 2.5
warp{turbulence .8 omega .7}
scale 1/2.5
scale <1,.6,1>
> Have you looked at
> yet?
I ever browsed this but I don't noticed here is a solution of what I ask.
> turbulence 0
> color_map {
> [.5 rgb 0.0]
> [1 rgb 1.0]
Oh well
