POV-Ray : Newsgroups : povray.binaries.images : Bug in Supercone()? Server Time
11 Aug 2025 23:01:53 EDT (-0400)
  Bug in Supercone()? (Message 1 to 2 of 2)
Subject: Bug in Supercone()?
Date: 21 Mar 2008 14:35:01
Message: <web.47e40ce72d3a644685de7b680@news.povray.org>
I get very odd results with the parameters that follow.  Am i doing something
wrong?
_________________________________________________
#include "shapes.inc"
#declare R1 = 0.05;
#declare R2 = 0.25;
#declare Test1 = Supercone (0, R1, R1, y, R1, R2)
#declare Test2 = difference
{  box { <0, -0.1, 0>, <R1, 0.9, 0.5> }
   object { Test1 }
union
{  object { Test1 translate <-0.5, -0.5, 0> }
   object { Test2 translate <0.5, -0.5, 0> }
   pigment { rgb y }
   finish { specular 0.2 }
camera
{  look_at 0
   location <-3, 2, -5>
   angle 15
light_source { <-2, 3, -1> * 10000, rgb 1 }
plane { y, -1 pigment { checker rgb 0.5 rgb 1 } }
Download 'stuporcone.png' (28 KB)
Preview of image 'stuporcone.png'
Subject: Re: Bug in Supercone()?
Date: 21 Mar 2008 15:45:40
Message: <47e41e74$1@news.povray.org>
"Cousin Ricky" <ric### [at] yahoocom> wrote in message
news:web.47e40ce72d3a644685de7b680@news.povray.org...
>something
> wrong?
> #declare R1 = 0.05;
> #declare R2 = 0.25;
Hi Cous.,
I think you're just going a bit small. If you look at the quartic for the
Supercone macro it's using the products of the squares of the radii in
places which means it's working with very small numbers. I'd guess you're
just a victim of rounding errors.
If you use:
 #declare Test1 = object {Supercone (0, 10*R1, 10*R1, 10*y, 10*R1, 10*R2)
scale 0.1}
you should avoid the problem.
Chris B.
