POV-Ray : Newsgroups : povray.binaries.images : Playing with Photons Server Time
21 Mar 2026 03:48:12 EDT (-0400)
  Playing with Photons (Message 11 to 20 of 32)
Subject: Re: Playing with Photons
Date: 20 Mar 2008 10:01:28
Message: <47e27c48$1@news.povray.org>
It seems that: radiosity + photons - media = no artifacts.
I used more detailed radiosity settings and turned normal to off.:
global_settings {
  assumed_gamma 1.0
  #if (RadiosityOk = on)
    radiosity {
      pretrace_start 0.1
      pretrace_end   0.0025
      count 500
      error_bound 0.5
      nearest_count 8
      recursion_limit 1
      brightness .8
      normal off
  #if (Photons)      // global photon block
    photons {
      spacing 0.03   // specify the density of photons
Does this mean that media needs more precise settings in conjunction with
the photons?
Date: 20 Mar 2008 13:20:38
Message: <47e2aaf6$1@news.povray.org>
Kirk Andrews nous apporta ses lumieres en ce 2008/03/19 17:28:
There is a problem with that media.
> #if (MediaOk = on)
> sphere {0,500
>   hollow
>   pigment {rgbt 1}
>   interior {
>     media {    // atmospheric media sample
>       intervals 4
This should stay at 1. With sampling method 3 (default) lager values can cause
artefacts. It's also much faster.
>       scattering { 1, rgb 0.01 }
>       samples 1, 10
Not enough samples, must be at least 3. The value after the comma is always
ignored. This is beter:
samples 10
// samples 100 would be about as fast as your settings, for a beter quality.
>       confidence 0.9999
>       variance 1/1000
>       ratio 0.9
>       density {
>         planar
>         //poly_wave 1/4
>         scale 10
>         translate -5*y
>         turbulence .2
>   photons {collect off pass_through}
> #end
The documentation text is about the former default of method 1. Greatly missleading.
You know you've been raytracing too long when you prefer bald romatic partners,
because they're easier to model.
John VanSickle
Date: 20 Mar 2008 16:25:01
Message: <web.47e2d5cef97379da5d4a01d0@news.povray.org>
Thanks Alain.
You know, I hadn't been messing with media for a long time because I had become
frustrated with it.  But back before I quit using it, I think you had told me
the same thing.  :)
I'll try this again and post it when I get the chance.
Date: 22 Mar 2008 01:20:01
Message: <web.47e4a34cf97379d78dcad930@news.povray.org>
I ran some test images, to see what might be going on.
Running your code the first time, POV's messages returned an isosurface
max_gradient of 57(!). So I upped it to 60, just to add a little bit of
"headroom." I also added global{max_trace_level 25}, as the "water box" light
reflections were going way past your default value of 5.
Once that was done, I ran the basic scene with radiosity, but no media or
photons--just to make sure that the isosurface was solid. (I upped the
radiosity brightness to 3.5, to show better detail.) Here's the result--quite
nice, just by itself!!  I feel like I'm actually standing there
within the sandstone chasm. You've done a really nice job with
the isosurface, the texture and the lighting.
So far, no problems (as you mentioned.)
I'll post another image, using photons only.
Ken W.
Download 'newsgroup_rad_scene_1.jpg' (102 KB)
Preview of image 'newsgroup_rad_scene_1.jpg'
Date: 22 Mar 2008 01:50:01
Message: <web.47e4aa2cf97379d78dcad930@news.povray.org>
Here's a render using just photons, no radiosity or media. The rest of the
values are the same as in my previous image post--except that I changed the
reflection of your "water box" to reflection{1.6} to brighten up the sandstone
walls, to see the detail there.
Some strange things are going on!
Those multiple, ragged dark patches *could* be the main reason for the problem
you're having, although I'm not absolutely sure of that. Looks like the photons
aren't hitting certain areas(?). I would try and concentrate on getting the
photon coverage worked out, before pointing the finger at media
or radiosity.
I tried monkeying around with photon spacing, but that didn't help. You might
want to try a different photon scheme, using count rather than spacing.
I'll continue working on this photon problem--it's a nice challenge! I'd like to
see this overall problem *solved*, as I have a similar scene of my own in
the planning stages.
Ken W.
Download 'newsgroup_rad_scene_2.jpg' (219 KB)
Preview of image 'newsgroup_rad_scene_2.jpg'
Date: 22 Mar 2008 02:20:00
Message: <web.47e4b2b4f97379d78dcad930@news.povray.org>
"Kenneth" <kdw### [at] earthlinknet> wrote:
> ...The rest of the
> reflection of your "water box" to reflection{1.6}...
Oops, that's incorrect; I didn't alter the reflection. Instead, as the image
itself says, I changed the terrain isosurface's finish to diffuse 2.5 ambient
0,  to brighten up the walls.
KW
Date: 22 Mar 2008 10:27:08
Message: <47e5254c$1@news.povray.org>
Kenneth nous apporta ses lumieres en ce 2008/03/22 02:46:
> or radiosity.
> Ken W.
The ragged patches seems to be a result of the normal in the rock's texture.
Here's the relevant statement:
   normal {crackle turbulence .5 scale <.2,.05,.2>*2 }
The photons react much more to the normals than the radiosity, even with normals on.
WARNING: The consumption of alcohol may cause you to think you can sing.
Date: 22 Mar 2008 12:50:00
Message: <web.47e545f0f97379d5bd27ba40@news.povray.org>
> Alain
Here's a render with everything on, but no normals on the terrain.  I also
increased the max_gradient to 60.
Download 'pillarcanyonc.png' (443 KB)
Preview of image 'pillarcanyonc.png'
Date: 24 Mar 2008 16:45:10
Message: <47e820e6$1@news.povray.org>
> missleading.
Post in povray.documentation.inbuilt about it.
Date: 24 Mar 2008 18:55:01
Message: <web.47e83eaaf97379de22cf3300@news.povray.org>
Alain <ele### [at] netscapenet> wrote:
> He clearly say the the effect *ONLY* apears when using *BOTH* radiosity AND photons.
> NO effect using only radiosity.
> NO effect using only photons.
Here's one without photons, media, or radiosity.  Is there a problem with the
isosurface?
Mike
Download 'canyon_none.png' (81 KB)
Preview of image 'canyon_none.png'
