POV-Ray : Newsgroups : povray.binaries.images : any ideas what these black patches are.. Server Time
3 Nov 2025 16:21:07 EST (-0500)
  any ideas what these black patches are.. (Message 31 to 40 of 42)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: any ideas what these black patches are..
Date: 18 Mar 2008 17:45:01
Message: <web.47e04444d387c88678dcad930@news.povray.org>
"s.day" <s.d### [at] uelacuk> wrote:
> Wow! thanks for all the replies.
> No media in the scene to be causing any issues...
A beautiful scene, and very complex (which makes it difficult to nail down the
problem, I'm sure.)
In looking at your scene code, I see that there are lots of spotlights that
actually DO make use of media in some way. In the current version of POV-Ray,
there are *multiple* problems associated when using media, radiosity and
spotlights, which can cause really strange visual aberrations to appear in
places you wouldn't expect. So far, I've only posted info about one such
problem (not using radiosity). But there are others.
Here's the link...
http://news.povray.org/povray.general/thread/%3Cweb.45125ba9d84b4b77cc29cf380@news.povray.org%3E/
and the link to the associated image...
http://news.povray.org/povray.binaries.images/thread/%3Cweb.45125e6ed84b4b77cc29cf380%40news.povray.org%3E/?ttop=267426
&toff=900
Another problem is that radiosity illumination from media does not show up on
any objects (or parts of objects) that are inside a media-filled spotlight
cone. Said another way, the media IN the cone doesn't generate radiosity
illumination on objects that are embedded in it. I think that's a problem with
the spotlight itself.
My suggestion would be to run your complete scene--radiosity and all-- with
UseTestTex=1 rather than 0 (which will turn off your media) and see if the
black spots still appear. A long and laborious testing process, to be sure!
Ken W.
Date: 18 Mar 2008 17:50:21
Message: <47e0472d$1@news.povray.org>
Wow!
Date: 18 Mar 2008 18:05:00
Message: <web.47e049b1d387c88678dcad930@news.povray.org>
"Kenneth" <kdw### [at] earthlinknet> wrote:
> Here's the link...
26
> &toff=900
Sorry, the link to my original post brings up a "bad request." But the image
link still works (which will refer you back to the original post.)
Ken
Date: 18 Mar 2008 18:20:01
Message: <web.47e04d21d387c88678dcad930@news.povray.org>
OK...here's a WORKING link back to my original post. (I must have missed
something while cutting and pasting...)  Sorry!
http://news.povray.org/povray.general/thread/%3Cweb.45125ba9d84b4b77cc29cf380%40news.povray.org%3E/
Date: 19 Mar 2008 16:45:00
Message: <web.47e188c4d387c8867eb3d110@news.povray.org>
> problem, I'm sure.)
> Here's the link...
26
> &toff=900
> Ken W.
Hi Ken,
Thanks for taking the time to download/read the code, it must be almost as much
of a challenge as finding the cause of this problem with my lack of comments. I
had forgotten about the media used with the spotlights (that's the problem with
re-rendering 3 year old scenes). However, for the renders I have posted I was
using useTestTex=1 so media would not have been used/affected this.
I have done several more tests but so far have not found the cause. My first
tests were to revert to the default radiosity settings then go through and
adjust each item one at a time to the settings that caused the problem. All
these renders were OK (and much quicker).
I have also managed to complete a render with reasonably high quality settings:
    pretrace_start 0.08
    pretrace_end   0.01
    count 500
    nearest_count 10  // was 20
    error_bound 1     // was 0.08
    recursion_limit 4
    low_error_factor .5 // was 0.9
    gray_threshold 0.0
    minimum_reuse 0.015
    brightness 0.8
    adc_bailout 0.01/2
which rendered fine, I am using the saved data from this trace to render at
5250x3500 with focal blur/isosurfaces and spotlights with media etc.. So far
the estimate for this render is about 5 months so I hope I am happy with it at
the end!!
As the PC still has several cores sitting their idle I am trying a smaller
render with the settings that caused the problem to see if image size has an
effect. I am still hoping to track down the cause of this even if the current
render is OK (I can't stand a mystery) I just wonder if I will manage to find
the cause before the other render has finished..
Sean
Date: 19 Mar 2008 16:45:01
Message: <web.47e18959d387c8867eb3d110@news.povray.org>
Eero Ahonen <aer### [at] removethiszbxtnetinvalid> wrote:
> s.day wrote:
> > I forgot to add that the machine is only running XP 32 bit and 32 bit POV which
> > is why I wondered if approaching the 2GB memory limit may be causing the
> > problem.
> > Sean
> Start XP with /3GB -switch and it'll be able to allocate 3G for one process.
> Eero "Aero" Ahonen
>     http://www.zbxt.net
Thanks Eero,
I will add this to my list of things to try.
Sean
Date: 20 Mar 2008 08:10:00
Message: <web.47e2610dd387c88678dcad930@news.povray.org>
> > Eero "Aero" Ahonen
> >     http://www.zbxt.net
> Thanks Eero,
> Sean
That's a really interesting work-around to the 2GB limit, that I didn't even
know about until this post. Thanks.
In researching this, the Microsoft website doesn't specifically mention that it
will work with Windows XP Home Edition SP2 (which is what I use.) They list
others, but not this particular version of the OS. But hey, it's worth a try.
Now, if I could only figure out what a /3GB-switch is and how to implement it...
Ken
Date: 20 Mar 2008 13:03:08
Message: <47e2a6dc@news.povray.org>
Kenneth nous apporta ses lumieres en ce 2008/03/20 09:05:
>>> Eero "Aero" Ahonen
>>>     http://www.zbxt.net
>> Thanks Eero,
>> Sean
> Ken
Open the "boot.ini" file in the root of the drive where windows is installed.
Find this:
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS=...
Add " /3GB" at the end of the first line, and ONLY that line.
If you encounter a problem when booting, restart in safe mode and undo the change.
Scientology: If shit happens, see "Dianetics", p.157.
Date: 21 Mar 2008 11:14:55
Message: <47e3deff$1@news.povray.org>
> the change.
Or easier, duplicate the first line pre-change and give it a different
label, so you can pick whether to boot with that flag when you start. :-)
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 21 Mar 2008 13:12:34
Message: <47e3fa92$1@news.povray.org>
> installed.
> Find this:
> [operating systems]
> the change.
You'll have to un-hide "protected operating system files" first to see boot.ini:
In Windows Explorer, uncheck the box:
Tools>Folder Options>View>Hide protected....
When I installed XP Pro (SP2) on machines with 4GB of memory, the /3GB switch
was automatically added to boot.ini. You should only have to add it if you
increase your memory after installation.
