POV-Ray : Newsgroups : povray.binaries.images : Translucency 3 Server Time
19 Jul 2025 16:47:04 EDT (-0400)
  Translucency 3 (Message 1 to 10 of 13)
Subject: Translucency 3
Date: 7 Mar 2008 15:35:01
Message: <web.47d1a63f5bfaf533ce5ce3790@news.povray.org>
Hello,
  Still messing around with the simulated translucency, trying out making a
lampshade.  Here's a scene I put around it.  Ironically I found that at this
scale the shades smaller details aren't really visible.  Regardless, as a WIP I
thought I'd share.
-The Mildly Infamous Blue Herring
Download 'lamp_and_mirror_1.png' (402 KB)
Preview of image 'lamp_and_mirror_1.png'
Subject: Re: Translucency 3
Date: 7 Mar 2008 18:50:00
Message: <web.47d1d45f76857e91a5d4a01d0@news.povray.org>
"Blue Herring" <bhe### [at] tinfoilcatcom> wrote:
> Hello,
> thought I'd share.
Looks good.  What method are you using?
Date: 8 Mar 2008 03:50:13
Message: <47d25345$1@news.povray.org>
I think the shade is looking good. I am however, troubled by the focal blur
(?) which made me wonder if something was wrong with my eyes. I have trouble
to see the scene, with the exception of the lamp.
Date: 10 Mar 2008 08:28:32
Message: <47d53780$1@news.povray.org>
> Thomas
No trouble at all here. Must be something with your eyes.
Date: 10 Mar 2008 10:23:45
Message: <47d55281@news.povray.org>
"Hans Fink" <mas### [at] pecosnospamde> schreef in bericht
news:47d53780$1@news.povray.org...
Yes, I forgot my POV-glasses..... :-)
Date: 10 Mar 2008 13:55:00
Message: <web.47d582f776857e91ce5ce3790@news.povray.org>
Thanks.  It uses double illuminate and an area light + radiosity, with patterns
of varying ambient finish on the shade.  Nothing too different than my prior
lights really.
Date: 10 Mar 2008 14:00:02
Message: <web.47d584cd76857e91ce5ce3790@news.povray.org>
Thanks.  Perhaps I was too aggressive with the blur, I don't use it all that
often.  Or possibly its the scale of the scene, its at 1cm = 1 pov unit.  It
uses the standard POV-Ray focal blur:
#declare Focus = <-30, 120, 170>;
  location <-50, 150, -50>
  up y
  right x * image_width/image_height
  look_at Focus
  #if(Use_Focal_Blur)
    aperture 9
    blur_samples 400
    focal_point Focus
    confidence 0.91
    variance 1/2000
Part of the reason for the rather high settings was that I was trying to get rid
of that graininess on the mirror border, which it largely failed to do.
Date: 11 Mar 2008 03:27:24
Message: <47d6426c@news.povray.org>
"Blue Herring" <bhe### [at] tinfoilcatcom> schreef in bericht
news:web.47d584cd76857e91ce5ce3790@news.povray.org...
> get rid
Maybe that would disappear with (higher) radiosity settings? Instead of
focal blur.
Date: 14 Mar 2008 13:30:01
Message: <web.47dac36b76857e91ce5ce3790@news.povray.org>
> focal blur.
Hmm, not sure, I thought I had fairly high settings, but perhaps I'm off
somewhere.  I'm using the two-pass method with the settings:
pretrace_start 0.32
pretrace_end   0.02
count 400
nearest_count 5
error_bound 1
recursion_limit 3
low_error_factor 0.5
gray_threshold 0
minimum_reuse 0.015
brightness 1
adc_bailout 0.01/0.4
normal off
media off
Date: 14 Mar 2008 14:45:27
Message: <47dad5d7$1@news.povray.org>
Blue Herring nous apporta ses lumieres en ce 2008/03/14 14:26:
>> focal blur.
> pretrace_start 0.32
Changing the pretrace_start usualy have little to no effect. Keep the default of
0.08.
Changing by some small value may, in some cases, get rid of some artefacts near
corners.
> pretrace_end   0.02
Default value.
Try reducint this to 0.01, 0.005 or 0.0025
> count 400
Maybe a larger value here? Try 600 or 800.
> nearest_count 5
That's the default value.
You can go up to 20. Low effect on render time, can greatly improve end result.
> error_bound 1
> recursion_limit 3
Default value.
Meybe try a somewhat smaller value. Will take more time on the final pretrace step.
> gray_threshold 0
Default value.
> minimum_reuse 0.015
Default value.
You may need a value larger OR smaler. Don't go over 0.02. Don't go to small, as
smaller values will increase the render time.
> brightness 1
Default value.
That's 0.025, probably to large. Try adc_bailout 0.01/3 or 0.01/4.
> normal off
Default value.
> media off
Default value.
Every time you use a default value, you can skip that option.
Keep your boss’s boss off your boss’s back.
