POV-Ray : Newsgroups : povray.binaries.images : Yet more boulders Server Time
18 Sep 2025 16:16:09 EDT (-0400)
  Yet more boulders (Message 11 to 16 of 16)
Subject: Re: Yet more boulders
Date: 29 Feb 2008 06:45:01
Message: <web.47c7eeeee40b9a04731f01d10@news.povray.org>
> Seems an interesting method. If you have time to port
> that out to the community, I (at least) would be very grateful. I can
> imagine a lot of applications.
Here you go. It should be quite self-explanatory. If you don't want a smooth
finish then use triangle instead of smooth_triangle.
// begin code
#macro ballpoint(vangle, rangle, rad)
  #local yp = rad*cos(vangle);
  #local locrad = rad*sin(vangle);
  #local xp = locrad*sin(rangle);
  #local zp = locrad*cos(rangle);
  (<xp, yp, zp>)
#macro meshball(obj, res)
  mesh {
  #local vang = 0;
  #local ang  = 0;
  #local dvang = pi/res;
  #local dang = 2*pi/res;
  #local n1 = <0,0,0>;
  #local n2 = <0,0,0>;
  #local n3 = <0,0,0>;
  #local n4 = <0,0,0>;
  #while (vang < pi)
    #while (ang < 2*pi)
      #local v1 = trace(obj, <0,0,0>, ballpoint(vang, ang, 1), n1);
      #local v2 = trace(obj, <0,0,0>, ballpoint(vang+dvang, ang, 1), n2);
      #local v3 = trace(obj, <0,0,0>, ballpoint(vang, ang+dang, 1), n3);
      #local v4 = trace(obj, <0,0,0>, ballpoint(vang+dvang, ang+dang, 1), n4);
      smooth_triangle { v1, n1, v2, n2, v3, n3 }
      smooth_triangle { v2, n2, v3, n3, v4, n4 }
      #local ang = ang + dang;
    #local ang = 0;
    #local vang = vang + dvang;
  #end }
// end code
Just call meshball(obj, res) where obj is your pre-declared object (centred on
the origin) and res is the triangle resolution (it's pretty fast with 100-200
and looks ok).
Bill
Date: 1 Mar 2008 03:22:38
Message: <47c9124e$1@news.povray.org>
news:web.47c7eeeee40b9a04731f01d10@news.povray.org...
> smooth
Excellent! Thanks a lot Bill!
Date: 2 Mar 2008 08:05:19
Message: <47caa60f$1@news.povray.org>
Bill Pragnell wrote:
> Yeah, well, I don't care that much, it's just nice to know roughly what's
> slowing things down. :) Anyway, preview is useful, I don't have to wait for a
That kind of nice-to-know -information is also provided by official
Windows -version of POV-Ray, while it shows the PPM (pixels per minute?)
-value at bottom right corner.
Just a FYI :).
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 2 Mar 2008 09:57:58
Message: <47cac076@news.povray.org>
>> wait for a
Problem is the PPM is an average over the whole rendered image, so it's
a bit hard to tell if a certain part takes longer.
Date: 3 Mar 2008 06:55:50
Message: <47cbe746@news.povray.org>
Mmm... have you noticed that in the left lower corner there is a profile
   of a boulder-ish face? Your works is becoming alive...
Paolo
> Here we go again. Not much variation in these rocks, sorry, I promise to post
> something more interesting soon!
> In the end I gave up using the isosurface approximation macro, it was producing
> far too many sharp angles and the smoothing was suffering. So I wrote a quick
> and dirty mesh approximator that just shoots rays in a spherical polar grid
> from the center of the object. Obviously, if the object occludes its own centre
> anywhere then this won't work properly, but I'm just after a basic rocky shape
> so what the hell. This saves loads of parsing time and still looks pretty good
> up close; a little less craggy than previous versions maybe.
> So, this image rendered in 7 hours, a bit steep but the bushes and trees in
> cahoots with the antialiasing were the main culprits (that's the nice thing
> about MegaPOV, you can see exactly which pixels are slowing you down). The
> boulder itself renders really quick, even with radiosity. I'm really happy with
> the (relatively simple) bozo pigment on the rock, it hints at surface texture
> that isn't there, even really close up (thanks to partial tests without
> radiosity at 3000x3000).
> The triangular gaps in the plant life are deliberate; that's where the buildings
> will be.
> njoy
> Bill
Date: 3 Mar 2008 07:05:00
Message: <web.47cbe917e40b9a04731f01d10@news.povray.org>
So there is! I hadn't noticed, but it is quite conspicuous. A very elongated
chin, he probably has a dastardly handle-bar moustache...
