man, that's so amazing I don't even know how to thank you! Send it to
the povteam right now!
I don't know if a povsymbol aperture is that realistic, but as artistic
license it's wonderful. :) and the hexagon and circular one are spot-on!
let's workout a syntax extension for it:
aperture .02 blur_samples 60 shape circular | hexagon | image
how's it?
> "triple_r" <rre### [at] hotmail com> wrote:
>> I think it would require a direct patch into
>> POV-Ray to fix the problem.
> So with very little effort, here's the result of my patched POV. It's hardly
> fair to call it that since it's only a couple lines and there's no SDL
> interface for it. It just reads a grayscale ppm file and varies the density of
> the sample grid according to the image. You can even tell the difference
> without the strong highlights which makes me wonder why the default is a square
> aperture. Not quite sure when that would be preferable, but maybe people don't
> use strong focal blur too often.
Did you base your patch on 3.6 or 3.7 code?
> > square
> > aperture.
> I suppose it's faster to calculate a random location inside a square than a
> random location inside a circle. Might not be much of a difference for 1 pixel
> and 1 sample, but it could add up to a lot for 1024x786 pixels and 10 samples
> per pixel.
Well that's the interesting part. It seems to use something like a grid with
jitter, but it's all precalculated before the render. So it doesn't matter
what shape you choose - as best as I can tell, it's just a list of points when
rendering.
- Ricky
"C. Cappai" <nomail@nomail> wrote:
> Wow!
> I want so much that all this was implemented in the next beta of POV-Ray!
It's nothing POV-Ray can't do already, it's just square and ugly by default.
Trivial to change.
- Ricky
"nemesis" <nam### [at] nospamgmail com> wrote in message
news:47c092e1$1@news.povray.org...
> man, that's so amazing I don't even know how to thank you! Send it to the
> povteam right now!
> camera {
> how's it?
there's a bokeh-patch for povray that accepts any pigment as shape. I think
that's actually the best way to do it. (it's the bokeh_pigment_patch that's
referenced on the MegaPOV-website, but that's the only hit on google, so I
suppose it's not available anymore)
cu!
_(0x+y.5+y/2x)_(0x-y.5+y/2x) // ZK http://www.povplace.com
Ooh, lovely! Will it do the same with light sources? I'm thinking of a
street scene at night.
- Nekar X -
Probably not, but it probably would work if the lights had a really
bright looks_like object.
William Tracy
afi### [at] gmail com -- wtr### [at] calpoly edu
It occurred to him that now he was going to be not only the first
man on Mars, but the first detective. He grinned at the thought, and the
last action of the omegendorph set his nerves aglow.
-- Kim Stanley Robinson, _Red Mars_
web.47bfa2bb806ad5e4ae42298f0@news.povray.org...
> You'll notice in these images that the bokeh are just below a comfortable
> noise
> threshold, but the rest of the scene is extremely oversampled. That fix
> might
> not be so easy, but if it could be accomplished, would make the focal_blur
> much
> more powerful.
> - Ricky
Here's a link to Mael's POV-Ray patch with the bokeh feature (and other cool
stuff)
http://pov.monde.free.fr/mael/mlpov081.html
G.
http://www.oyonale.com
- Graphic experiments
- POV-Ray, Cinema 4D and Poser computer art
- Posters
> stuff)
Hey thanks! I'm content with the status quo right now -- which requires
recompiling POV-Ray if I want to change the pattern -- but it's interesting to
see what someone else has done. Recompiling is really not as much of a pain as
it sounds. Doesn't need changing too often. But it seems like the pattern
solution would be useful enough to make it into more than a little-known
patched version now that computers are actually powerful enough to take
advantage of it. Looks like the current render will take about four hours.
Roughly speaking,
4 hours * (2.4 Ghz/120MHz) * (4 Cores/1 CPU) ~= two weeks (and hard times for
the last computer on which I played with focal blur).
- Ricky
> - Ricky
Sweet! it even inverts the aperture shape properly. Nice :) Now, if you
could add a parameter to the camera SDL to grab a bokeh map, or define
blades, curvature for aperture, you'd really have something.
