POV-Ray : Newsgroups : povray.binaries.images : Block coded in PovRay Server Time
15 Nov 2024 18:23:22 EST (-0500)
  Block coded in PovRay (Message 1 to 10 of 23)
Subject: Block coded in PovRay
Date: 4 Feb 2008 13:25:01
Message: <web.47a75855985ffec620776f0@news.povray.org>
A view people ask me how I did this:
http://news.povray.org/povray.binaries.images/thread/%3Cweb.4798a383d450dfce811410630%40news.povray.org%3E/?mtop=259872
Well now I tried to code such a cube in PovRay.
Here it is:
//Take a coffee now!!
global_settings {assumed_gamma 3 radiosity {pretrace_start 1 pretrace_end
0.0000001 count 50 error_bound 0.05 recursion_limit 10 brightness 0.5}}
  ultra_wide_angle
  location  <0.0, 0.1, -1.0>*1.5
  direction 1.5*z
  angle 90
  look_at   <0.0, 0.65,  0.0>
light_source {<-30, 30, -30> color rgb 1}
#declare resolution=60;
#declare densiti=0.125;
#declare chaos=2;
#declare bloks=union{
#declare zet=0;
#while (zet<resolution)
#declare hf=object{height_field {
    function resolution,resolution {
        agate
        color_map {
         [0  color rgb 0]
         [1  color rgb 1]
        turbulence chaos
        scale 1
        translate <0,0,1/resolution*zet>
scale resolution
#declare zet=zet+1;
#declare iks=0;
#while (iks<resolution)
#declare iks=iks+1;
#declare ueps=0;
#while (ueps<resolution)
#declare ueps=ueps+1;
#if (inside(hf,<iks,(resolution/(1/(1-(densiti)))),ueps>))
box{-0.4,0.4 translate<iks,zet,ueps>}
object{bloks
pigment{color rgb 1}
finish{ambient 0 diffuse 1}
scale 1/resolution
translate <-0.5,0,-0.5>
rotate <0,60,0>
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.6,0.7,1.0>]
      [0.5 rgb <0.0,0.1,0.8>]
      [1 rgb 0]
plane {
  y, 0
  pigment { color rgb 1 }
Download 'block.jpg' (259 KB)
Preview of image 'block.jpg'
Subject: Re: Block coded in PovRay
Date: 4 Feb 2008 14:15:01
Message: <web.47a7639f15c6d867fba9d8b70@news.povray.org>
"H. Karsten" <h-karsten()web.de> wrote:
> pretrace_end 0.0000001 count 50 error_bound 0.05
oh, man!
Date: 4 Feb 2008 16:29:26
Message: <47a783b6$1@news.povray.org>
Looks like a neat start for some really awesome spaceship greebling. :-D
William Tracy
:D1ck :u like the site
:D1ck :what wil u give it out of 10
:Sp07 :.654564
     -- script kiddies in an IRC chat
Date: 5 Feb 2008 03:32:15
Message: <47a81f0f@news.povray.org>
Interesting!
...and by playing with the size of the component blocks, one gets this for
instance. Very close to your original one.
by the way, I just used the default values for radiosity.
Download 'HKarsten_GreebleBlock.png' (136 KB)
Preview of image 'HKarsten_GreebleBlock.png'
Date: 5 Feb 2008 07:45:57
Message: <47a85a85@news.povray.org>
Another interesting example. I randomized the individual block sizes and the
pigments; used marble instead of agate; densiti=0.25; chaos=0.5
Download 'HKarsten_GreebleBlock.jpg' (98 KB)
Preview of image 'HKarsten_GreebleBlock.jpg'
Date: 5 Feb 2008 08:30:02
Message: <web.47a863b615c6d86725876e950@news.povray.org>
You can also play with the pattern.
Use wrinkles or leopard instead of agate.
Date: 5 Feb 2008 08:41:34
Message: <srpgq35vc2df9u0bb8lo8i6dp0ogmhhpqo@4ax.com>
On Tue, 5 Feb 2008 13:45:52 +0100, "Thomas de Groot" <t.d### [at] internlDOTnet>
>Thomas
I like that
Regards
Date: 5 Feb 2008 09:50:00
Message: <web.47a8768415c6d867f6bd64af0@news.povray.org>
> Thomas
the smaller preview image makes it look like an iceberg! :)
Date: 5 Feb 2008 11:35:01
Message: <web.47a8902015c6d867715c5f5e0@news.povray.org>
> > Thomas
And the bigger one for an instance like many sugar cubes. Hmmmm. :-)
Looks nice.
Regards
            bluetree
Date: 5 Feb 2008 17:57:54
Message: <47a8e9f2@news.povray.org>
Legos! :-D
William Tracy
    "I don't hink it helps to make analagies between the physical and
social worlds," Sax said primly.
    "Shut up, Sax. Go back to your virtual reality."
     -- Kim Stanley Robinson, _Red Mars_
