POV-Ray : Newsgroups : povray.binaries.images : Block coded in PovRay Server Time
12 Mar 2026 23:18:04 EDT (-0400)
  Block coded in PovRay (Message 4 to 13 of 23)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Block coded in PovRay
Date: 5 Feb 2008 03:32:15
Message: <47a81f0f@news.povray.org>
Interesting!
...and by playing with the size of the component blocks, one gets this for
instance. Very close to your original one.
by the way, I just used the default values for radiosity.
Download 'HKarsten_GreebleBlock.png' (136 KB)
Preview of image 'HKarsten_GreebleBlock.png'
Date: 5 Feb 2008 07:45:57
Message: <47a85a85@news.povray.org>
Another interesting example. I randomized the individual block sizes and the
pigments; used marble instead of agate; densiti=0.25; chaos=0.5
Download 'HKarsten_GreebleBlock.jpg' (98 KB)
Preview of image 'HKarsten_GreebleBlock.jpg'
Date: 5 Feb 2008 08:30:02
Message: <web.47a863b615c6d86725876e950@news.povray.org>
You can also play with the pattern.
Use wrinkles or leopard instead of agate.
Date: 5 Feb 2008 08:41:34
Message: <srpgq35vc2df9u0bb8lo8i6dp0ogmhhpqo@4ax.com>
On Tue, 5 Feb 2008 13:45:52 +0100, "Thomas de Groot" <t.d### [at] internlDOTnet>
>Thomas
I like that
Regards
Date: 5 Feb 2008 09:50:00
Message: <web.47a8768415c6d867f6bd64af0@news.povray.org>
> Thomas
the smaller preview image makes it look like an iceberg! :)
Date: 5 Feb 2008 11:35:01
Message: <web.47a8902015c6d867715c5f5e0@news.povray.org>
> > Thomas
And the bigger one for an instance like many sugar cubes. Hmmmm. :-)
Looks nice.
Regards
            bluetree
Date: 5 Feb 2008 17:57:54
Message: <47a8e9f2@news.povray.org>
Legos! :-D
William Tracy
    "I don't hink it helps to make analagies between the physical and
social worlds," Sax said primly.
    "Shut up, Sax. Go back to your virtual reality."
     -- Kim Stanley Robinson, _Red Mars_
Date: 6 Feb 2008 04:37:34
Message: <47a97fde@news.povray.org>
"H. Karsten" <h-karsten()web.de> schreef in bericht
news:web.47a863b615c6d86725876e950@news.povray.org...
Indeed. I started with marble, and experimented with most patterns. Some are
better than others,  of course, but the combination of pattern, resolution,
density, and chaos gives interesting results.
Thanks by the way for providing the code!!! All kind of possibilities come
to mind!!
Date: 6 Feb 2008 09:25:01
Message: <web.47a9c20c15c6d867f4a6b3980@news.povray.org>
//have fun, this tokes 01h53m31s on 24GHz (8 cores) by 1440x600...
global_settings {assumed_gamma 3 radiosity {pretrace_start 1 pretrace_end  0.0
linear1 count 35 nearest_count 5 error_bound 0.1 recursion_limit 3
low_error_factor .05 brightness 0.03}}
#declare S = seed(0);
  ultra_wide_angle
  location  <0.12,0.05,-1.3>*1.5
  direction 1.5*z
  angle 110
  aperture 0.03 blur_samples 128 focal_point <0,1,0> confidence 0.5 variance
1/1280
  look_at   <0,1,0>
light_source {<0,100,-10> color rgb 2.5}
#declare resolution=10;
#declare densiti=0.425;
#declare chaos=5;
#declare h=.3;
#declare high=3;
#declare bloks=union{
#declare zet=0;
#while (zet<resolution*high)
#declare hf=object{height_field {
    function resolution,resolution {
        bozo
        color_map {
         [0  color rgb 0]
         [1  color rgb 1]
        turbulence chaos
        //translate <0.25,0.25,-0.5>
        scale .5
        translate <0,0,1/resolution*zet>
scale resolution
#declare zet=zet+h;
#declare iks=0;
#while (iks<resolution)
#declare iks=iks+1;
#declare ueps=0;
#while (ueps<resolution)
#declare ueps=ueps+1;
#if (inside(hf,<iks,(resolution/(1/(1-(densiti)))),ueps>))
#declare gr=rand(S);
superellipsoid { 0.2+(rand(S)-0.5)/5 scale <1,h,1> scale 0.5 rotate
<rand(S),rand(S),rand(S)>*2.5 translate<iks,zet,ueps>
pigment { color rgb <gr,gr,gr>+0.1 }
finish { ambient 0 diffuse 1 phong 1 phong_size 1}
union{
#declare r=-140;
#while (r<10)
object{bloks scale 1/resolution
translate <-0.5,-0.05,-0.5> rotate <0,-90*r,0> translate <r*0.9,0,0>}
#declare r=r+1;
rotate <0,30,0>
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.7,0.65,0.5>]
      [0.25 rgb <0.0,0.1,0.8>]
      [0.5 rgb <0.0,0.1,0.8>*0.5]
      [1.0 rgb 0]
  turbulence .325*0.35
  scale <1,1.3,1>
  translate <0,-0.15,0>
  octaves 10
  lambda 3
plane {
  y, 0
  pigment { color rgb 1 }
  finish{ambient 0 diffuse 1}
Download '03.jpg' (174 KB)
Preview of image '03.jpg'
Date: 6 Feb 2008 10:05:02
Message: <web.47a9cc0915c6d867f4a6b3980@news.povray.org>
ups, that was the right setting:
global_settings {assumed_gamma 3 radiosity {pretrace_start 1 pretrace_end  0.01
count 35 nearest_count 5 error_bound 0.1 recursion_limit 3 low_error_factor .05
brightness 0.03}}
-holger-
