POV-Ray : Newsgroups : povray.binaries.images : Motecarlo path tracing with MegaPov 1.2.1 Server Time
15 Mar 2026 11:30:56 EDT (-0400)
  Motecarlo path tracing with MegaPov 1.2.1 (Message 72 to 81 of 161)
Subject: Re: Motecarlo path tracing with MegaPov 1.2.1
Date: 10 Feb 2008 08:14:44
Message: <47aef8c4$1@news.povray.org>
nemesis wrote:
> Warp <war### [at] tagpovrayorg> wrote:
>> karpov wrote:
>>> could you provide the patch ??
>>   I would be more interested in the implementation details and the
>> algorithm used.
> here you go:
> http://en.wikipedia.org/wiki/Path_tracing
> http://graphics.stanford.edu/courses/cs348b-02/lectures/lecture15/
  No. What I meant was details about how he implemented those things
into the POV-Ray code, and exactly which details did he implement and how.
>> That way developers could brainstorm a good way of
>> perhaps implementing it in pov3.7.
> more likely povray 4?
  Why? I don't see any reason why it couldn't be implemented in pov3.7
if it's good.
Date: 10 Feb 2008 10:20:00
Message: <web.47af1525dcec6a9f3d753190@news.povray.org>
Hello,
I made some changes to the source, mainly :
- handling of the max_trace recursion separetly of the max diffuse reflexion
limit.
- shoot first pixel with noise.
- use of portals to orientate the ray shoot.
In the following scene, I put a max trace level of 10, a max diffuse reflexion
limit of 3 and 2 portals (one on the glass ball in order to speed up the
caustic resolution and one on the emitting sphere in order to speed up the
smooth shadow resolution).
Any comments wellcome.
Fidos.
Download 'test_01.05.jpg' (62 KB)
Preview of image 'test_01.05.jpg'
Message: <web.47af15f3dcec6a9f3d753190@news.povray.org>
Attached the pov source of the previous scene.
Download 'test_01.pov.txt' (2 KB)
Date: 10 Feb 2008 10:59:16
Message: <47af1f54@news.povray.org>
I can't help wondering what the hdr_environment.pov from the Mega Pov
samples would look like with your patch =)
-Nekar
Date: 10 Feb 2008 11:50:00
Message: <web.47af2a38dcec6a9f48af2500@news.povray.org>
nice scene you've come up!  Transparency, check!  Caustics, check!  Reflections,
check!
and that mirror is actually casting back light rays!  It's interferring with the
shadows of the balls, look!
Date: 10 Feb 2008 14:45:00
Message: <web.47af5346dcec6a9f48af2500@news.povray.org>
hi, fidos!  I modified it a bit to work with current povray methods, radiosity
and photon mapping.  Just a couple of minutes to render.  Main difference to be
seen is the glass ball caustic on the floor, which seems to just render the
pointlight source...
If anyone is playing with it, I suggest to put FINAL off and render GI 1 and
PHOTONS 1 at separate passes.  When going to the final render, just turn FINAL
on.
#local FINAL = on;
#local GI = 0;
#local GIgather = 1;
#local PHOTONS = 0;
#local PHOTONSgather = 1;
// don't touch!
#if (FINAL)
 #declare GI = 1;
 #declare GIgather = 0;
 #declare PHOTONS = 1;
 #declare PHOTONSgather = 0;
global_settings {
  assumed_gamma 1.0
  max_trace_level 10
 #if (GI)
 radiosity {
  #if (GIgather)
  save_file "pt.rad"
  brightness 2.6
  minimum_reuse .02
  count 40*6
  error_bound .6
  low_error_factor .8
  adc_bailout .01
  recursion_limit 3
  pretrace_start .08
  pretrace_end .02
  nearest_count 10
  normal off
  #else
  load_file "pt.rad"
  always_sample no
  brightness 2.6
  count 1
  error_bound .6
  pretrace_start 1//.04
  pretrace_end 1//.002
  nearest_count 1
  normal off
 #if (PHOTONS)
 photons {
  #if (PHOTONSgather)
  save_file "pt.phm"
  count 20000*4
  //radius .4
  #else
  load_file "pt.phm"
  count 20000*4
  location  <3, 5, -5>
  direction z
  look_at   <-1, 1, 0>
sphere {
  0,1
   pigment { color rgb 1 }
   finish { diffuse 0 ambient 0 }
  hollow on
  no_shadow
  scale 10000
plane {
  y, 0
  texture
   finish { diffuse .5 ambient 0 }
  photons { collect on }
sphere {
  0,1
   pigment { color rgb <0.5,0.5,1> }
   finish { diffuse .6 ambient 0 }
  translate y*1-x*3
//box {
//  -0.5,0.5
sphere {
  0,0.5
    pigment { color rgbf 1 }
    finish { ambient 0 diffuse 0 }
  scale <1,1,1>
  interior {
    ior 1.33
  photons { target on reflection on refraction on }
  translate y*1
box {
  -1,1
    pigment { color rgb <1,1,1> }
    finish { reflection {1.0} ambient 0 diffuse 0 }
  photons { target on reflection on refraction off }
  scale <2,2,0.1>
  translate y*2+3*z
box {
  -0.5,0.5
   pigment { color rgb <1,0.5,0.5> }
  translate -x+0.75*y-2*z
#if (0)// (!PHOTONS)
sphere {
  0,1
   finish { diffuse 1 ambient 5 }
  translate y*3+x*3
#if (1) //(PHOTONS | FINAL)
light_source
  y*3+x*3, 1 fade_power 2 fade_distance 3
  #if (FINAL)
  area_light x,y,5,5 jitter adaptive 0 circular orient
  photons { reflection on refraction on }
  looks_like {
 sphere { 0,1
    finish { diffuse 0 ambient 1 }
Download 'pt.png' (129 KB)
Preview of image 'pt.png'
Date: 10 Feb 2008 15:35:01
Message: <web.47af5f88dcec6a9f3d753190@news.povray.org>
nemesis,
Impressive results. Clearly with practice PovRay is a great tool.
I'm fighting now with the use of spotlight in order to have sharp shadow.
Brute force rendering is clearly not raytracing...
Fidos
Date: 10 Feb 2008 15:38:17
Message: <47af60b9@news.povray.org>
Well, it involves tracing rays too :) (unlike stuff like scanline rendering)
Date: 10 Feb 2008 16:10:01
Message: <web.47af67a1dcec6a9f3d753190@news.povray.org>
Hello,
In order to test the improvement in speed of the use of portal, I rendered again
the Kitchen scene of Jaime Vives Piqueres (the untextured version). I put a
sphere emitting light in the room and render it for 1h (on the 4 cores of a
Q6600 with SMPOV). A portal was superposed to the light.
Any comment wellcome.
Fidos
Download '1st-pass.07.jpg' (356 KB)
Preview of image '1st-pass.07.jpg'
Date: 10 Feb 2008 18:55:00
Message: <web.47af8e49dcec6a9fa8d805710@news.povray.org>
oh, a night snack! :)
could you give more details about this "portal" feature?
