POV-Ray : Newsgroups : povray.binaries.images : Motecarlo path tracing with MegaPov 1.2.1 Server Time
15 Mar 2026 08:18:08 EDT (-0400)
  Motecarlo path tracing with MegaPov 1.2.1 (Message 51 to 60 of 161)
Subject: Re: Motecarlo path tracing with MegaPov 1.2.1
Date: 7 Feb 2008 07:36:08
Message: <47aafb38@news.povray.org>
>> I started with the untextured version (normally used for radiosity pass).
> Here the same scene but with texture.
> Any comments wellcome.
   Impressive! I hope you end up with success this patch, because it would
be great for this kind of scenes. Here you seem to have a problem with the
max_trace_level?
   Indeed, it would be very nice if it can be saved-loaded as the radiosity
or photons data.
   Thanks for using the kitchen!
Jaime
Date: 7 Feb 2008 07:50:00
Message: <web.47aafdc8dcec6a9f289345970@news.povray.org>
Hi fidos.
What you made is great man!!
These kind of rendering is really in front of doing raytracing and I like to see
those results.
There was a lot of work in the last year I had to made with bruteforcer and I
couldn't use PovRay for it..
I'm on the indigo page as Pippi Longsleeves. Here the Pictures I'll made with
Indigo:
http://www.indigorenderer.com/joomla/index.php?option=com_gallery2&Itemid=26&g2_itemId=15699
I really looking forward for this. And I hope to make such things in PovRay in
the near future.
:) holger
Date: 7 Feb 2008 07:56:51
Message: <47ab0013$1@news.povray.org>
> radiosity or photons data.
I have only ever used one renderer of this "kind" (WinOSi). That one is
probably quite feature-less compared to others. And it lets me not only
save the data, but also, *merge* files.
Process two hours on two different computers, merge the files, and
you'll get half the noise in the same time, just as if you had processed
it for four hours.
Date: 7 Feb 2008 08:35:01
Message: <web.47ab083bdcec6a9fa9518f020@news.povray.org>
man, this is incredibly damn good-looking!
http://www.indigorenderer.com/joomla/index.php?option=com_gallery2&Itemid=26&g2_itemId=15723&g2_GALLERYSID=a2f8515b5ca9
f551b0d34672acf6aceb
Date: 7 Feb 2008 09:05:00
Message: <web.47ab0fe5dcec6a9fa9518f020@news.povray.org>
> it for four hours.
how about processing it for 1 hour and removing the noise in Photoshop/Gimp? ;)
Date: 7 Feb 2008 09:20:00
Message: <web.47ab130edcec6a9f289345970@news.povray.org>
The process is similar to a normal Photo process: You let light throe the
objective and the photons rain down onto your image plane. The longer the
objective is open the more photons you have - the finer the detail.
By having less detail no filter (what ever it is) will give it to you.
By using a film with higher light sensitivity (to get shorter exposure times)
the exposer dots became very big. Maybe, this is a way to come closer to
photographic results: The first dots have to be bigger and getting smaller in
time. (just an idea..)
-holger-
Date: 7 Feb 2008 09:40:00
Message: <web.47ab17efdcec6a9fa9518f020@news.povray.org>
hmm, true.  But suppose the detail is almost good enough, but there's still
noise which won't truly go away if not for another 20 hours on a quadcore.
Wouldn't it be nice to simply replace those extra render hours in favor of 2
seconds on a bitmap noise reducer?
Seems it was exactly what Enrico Cerica, a famous Blender artist, did for this
impressive render with Indigo:
http://enricocerica.cgsociety.org/gallery/578040/
http://features-temp.cgsociety.org/gallerycrits/208213/208213_1199047047_large.jpg
11 hours on a core 2 duo plus 2D noise reduction...
his also famous for his impressive yafray renders:
http://yafray.org/sec/8/common/show_img.php?file=177_EnricoCerica.jpg
http://yafray.org/sec/8/common/show_img.php?file=159_Enrico_Cerica.jpg
http://yafray.org/sec/8/common/show_img.php?file=161_Enrico_Cerica.jpg
http://yafray.org/sec/8/common/show_img.php?file=168_EnricoCerica.jpg
http://yafray.org/sec/8/common/show_img.php?file=144_EnricoCerica.jpg
yay!  kinda like radiosity pretrace steps with smaller and smaller mosaic
previews? :)
Date: 7 Feb 2008 15:15:00
Message: <web.47ab665adcec6a9f311a53270@news.povray.org>
Thank you all for the positive reply to this thread.
I'm now thinking to the implementation of a portal like feature (the target is
for the user to guide the flow of ray shooting in order to reduce quickly the
noise). It should cut the rendering time.
Regrads,
Fidos.
Date: 7 Feb 2008 17:30:00
Message: <web.47ab85fcdcec6a9fdddf88110@news.povray.org>
> Regrads,
> Fidos.
All of these renders you are doing are fantastic. Would it be possible to get a
windows binary from you to play with. I have a chess set that I created and I
would love to see it using this, even if it takes a few days of rendering. :)
p.s. Attached is a sample of my chess set. By the way, does anyone know how I
get it included as a sample in the next version of POV-Ray. :D
Thanks,
Ian
Download 'glass_chess.png' (246 KB)
Preview of image 'glass_chess.png'
Date: 7 Feb 2008 17:50:00
Message: <web.47ab8ae2dcec6a9f5b359dfa0@news.povray.org>
a render is only as fantastic as the scene it depicts...
why not first play with light_source fade_power, light_source area_light and
radiosity?  as well as camera aperture?
I think there is already a chess set in the examples.  It's one of the first
things every povray geek does after the RSOCP... ;)
