POV-Ray : Newsgroups : povray.binaries.images : Motecarlo path tracing with MegaPov 1.2.1 Server Time
15 Mar 2026 22:07:10 EDT (-0400)
  Motecarlo path tracing with MegaPov 1.2.1 (Message 12 to 21 of 161)
Subject: Re: Motecarlo path tracing with MegaPov 1.2.1
Date: 3 Feb 2008 03:37:40
Message: <47a57d54$1@news.povray.org>
fidos wrote:
> It gives me the idea to patch the source code of MegaPov 1.2.1 in order to
> handle Montecarlo Path Tracing.
  So you basically do the exact same thing that the current radiosity
code does, but without the optimizations? (The current radiosity method
*uses* the monte-carlo method, with optimizations.)
  I really fail to see the advantage.
Date: 3 Feb 2008 06:55:01
Message: <web.47a5ab67dcec6a9fce60c5620@news.povray.org>
"fidos" <fid### [at] wanadoofr> wrote:
> > Yes, here it is, a wonderful scene to test lighting schemes full of nice
> > geometry and materials:
http://news.povray.org/povray.binaries.scene-files/thread/%3C453f8a68%40news.povray.org%3E/?ttop=260158&toff=50
> Funny because I arready used it to play. Here a pure result at low res ans
> stopped after a few iteration.
hah!  I deserve it... :P
Date: 3 Feb 2008 07:15:00
Message: <web.47a5af61dcec6a9fce311500@news.povray.org>
Everything is solve at the rendering time (no pretrace for radiosity). It is the
integration of the different light paths from the eye to the emissive lights
that produce the image (no shadow ray, fong models, etc.).
The main advantage is that the image is more accurate. Moreover, the radiosity,
costic, soft shadow and antialising is build in without any parameter tuning.
The main disavantage is the cpu cost and the residual noise in the picture.
Fidos
Date: 3 Feb 2008 07:20:00
Message: <web.47a5b07fdcec6a9fce311500@news.povray.org>
Hello,
A different light setting with the same scene : a reduce the hemisphere power
and add a sphere with ambiant to 25.
Any comment wellcome.
Regrads,
Fidos.
Download 'prep4company_low_test_3.01.jpg' (114 KB)
Preview of image 'prep4company_low_test_3.01.jpg'
Date: 3 Feb 2008 07:35:00
Message: <web.47a5b3e1dcec6a9fce60c5620@news.povray.org>
dropping the classic algorithms... tsc, tsc... have your mother never teached
you to respect the elderly? :)
yes, to tell the truth, since povray has clipping problems with too high light
values, my efforts so far to produce such smooth AA in the windows as seen in
your picture are worthless...
and surely when pov4 comes out, we'll be all running 8GHz quadcores... :D
Date: 3 Feb 2008 09:00:02
Message: <web.47a5c7b3dcec6a9fce311500@news.povray.org>
nemesis,
Sorry for this affront... Here a more carefull rendering of the scene. The bunny
on the floor is interesting with the 2 soft shadows due to the 2 windows.
Fidos
Download 'radiosity_and_bunnies.01.jpg' (90 KB)
Preview of image 'radiosity_and_bunnies.01.jpg'
Date: 3 Feb 2008 09:55:01
Message: <web.47a5d4c7dcec6a9fce60c5620@news.povray.org>
hey, no problem.  I was just kidding.  I put the source there for anyone to play
with.  You dropped the main light_source, right?  But if I remeber correctly, I
used about 5 for recursion_limit.  Your front walls seem too dark, which lead
me to wonder if there is too low bouncing steps going on...
yes, well, it's really not visible in the original scene because I'd put a big
point light right before the doors/windows/whatever.  But the double shadows
from radiosity calculations is visible in the wall dividing the scene, which is
in shadow alone.
BTW, I think there's no way around it:  path tracing gets noise, radiosity gets
patches... :P
Date: 3 Feb 2008 12:25:00
Message: <web.47a5f7dcdcec6a9f232fb4930@news.povray.org>
Yes. Only objects with an ambiant term > 0 are the possible light sources in a
scene.
>But if I remeber correctly, I used about 5 for recursion_limit. Your front walls
>seem too dark, which lead me to wonder if there is too low bouncing steps going on...
You are right. The recursion limit for the montecarlo paths is 3. I think it is
equivalent to a value of 2 for the recursion_limit parameter.
Date: 3 Feb 2008 15:37:02
Message: <47a625ee$1@news.povray.org>
No, more probably 3gHz hexacores :)
Anyway, isn't this essentially radiosity w/o the pretrace, and unlimited
count?
...Ben Chambers
www.pacificwebguy.com
Date: 3 Feb 2008 16:45:01
Message: <web.47a63501dcec6a9fce60c5620@news.povray.org>
> count?
well, whatever what he is doing, I hope we don't disencourage him.  Keep going
that we eventually may all be thankful for your effort.
The technique shows promise, if not for things other than the much better
handling of anti-aliasing against very bright surfaces (see the windows against
the white ambient sky or the metal surfaces) and also for not having to lose
nights after nights tweaking radiosity settings that never quite get right --
either are too patchy or too smooth to show correct shadows...
So far, I've not been able to do with radiosity what he's done with path
tracing.  Not to mention the stinking AA clipping problems... after several
hours testing and retesting, I'd surely feel glad to drop all the tweaking
altogether.  Leaving the assembly behind in favor of a compiler... ;)
