POV-Ray : Newsgroups : povray.binaries.images : Motecarlo path tracing with MegaPov 1.2.1 Server Time
15 Mar 2026 23:54:56 EDT (-0400)
  Motecarlo path tracing with MegaPov 1.2.1 (Message 2 to 11 of 161)
<<< Previous 1 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Motecarlo path tracing with MegaPov 1.2.1
Date: 2 Feb 2008 13:26:20
Message: <47a4b5cc$1@news.povray.org>
> Here the first acceptable results with a scene from Tim Nikias
> (http://www.nolights.de/).
Looks very nice, but it would probably be more useful to compare
it with a conventional render (the version on the website seems
to use very different lighting). Also, to compare the render
times between the two version (I assume introducing some
sort of randomness is intended to speed things up?).
Date: 2 Feb 2008 15:35:00
Message: <web.47a4d36cdcec6a9fce311500@news.povray.org>
Here is a rendering with MegaPov 1.2.1 and with the radiosity settings has
provided in the original scene.
For the rendering time, it is around 6 times longer for the brute force
rendering  but there is a lot of rooms for optimisation...
Fidos.
Download 'prep4company_low_test_normal.02.jpg' (91 KB)
Preview of image 'prep4company_low_test_normal.02.jpg'
Date: 2 Feb 2008 17:02:57
Message: <47a4e891$1@news.povray.org>
The results obtained are quite impressive, especially for a first
'quick' implementation. I hope you will show some other renderings with
different scenes.
Thibaut
> Regards,
> Fidos.
Date: 2 Feb 2008 17:58:46
Message: <47a4f5a6$1@news.povray.org>
fidos wrote:
> The modification was surprisingly easy : 2 days for a quick and dirty
> implementation without optimisation (only a pure Montecarlo Path Tracing).
So you simply shoot rays in random directions once you hit a surface to
generate the lighting?
Yup, I know that scene. ;-)
> The lighting is done with a sky sphere with ambiant set to 20.
How about a different colored skysphere, with a horizon and such? Either
via a photograph, or just a simple gradient along the y-axis, I'd be
curious as to how that'd look if the "ground" wouldn't emit white light
(e.g. just the top dome of the sky-sphere).
> Any comments welcome.
Interesting idea, what are you planning in terms of optimisation? And
how is your current technique working? Are you shooting several light
rays per pixel, or are just reiterating the entire scene again and again
and add up all the results?
Tim
Date: 2 Feb 2008 20:55:00
Message: <web.47a51ebcdcec6a9f856069320@news.povray.org>
BTW, Tim.  I've seen this wonderful scene before, just didn't know you released
the source for it!  You are a horrid marketeer!  Allow me to do the googling.
Yes, here it is, a wonderful scene to test lighting schemes full of nice
geometry and materials:
http://news.povray.org/povray.binaries.scene-files/thread/%3C453f8a68%40news.povray.org%3E/?ttop=260158&toff=50
I know you'll like it, Nicolas... ;)
the file comes with suboptimal radiosity settings, I'm playing with it to see if
I can come up with a scene just like the one with path tracing, except for the
noise and rendertime... ;)
Date: 2 Feb 2008 21:19:36
Message: <47a524b8$1@news.povray.org>
Why? :)
Remember I can't use radiosity on the renderfarm due to the artifacts
that appear on tiled radiosity renders. Two-pass rendering still doesn't
make it perfect, and wouldn't be a good idea anyway if the radiosity
file is too big.
So I tend to just stay away from radiosity here.
Date: 2 Feb 2008 21:25:01
Message: <web.47a525f5dcec6a9f856069320@news.povray.org>
well, I guess we're all waiting for it coming out of alfa quality in pov3.7...
Date: 2 Feb 2008 22:24:11
Message: <47a533db@news.povray.org>
I'd just like "deterministic" radiosity. Which means, radiosity that
doesn't change brightness when rendering in tiles, or resuming a render.
Maybe that will be improved in 3.7, since the multi-threading uses tiles
internally :)
Date: 3 Feb 2008 03:05:00
Message: <web.47a5755bdcec6a9fce311500@news.povray.org>
Yes
A good optimisation for a quicher noise reduction is to sample the lights after
projection on the hemisphere surrounding a hit point. An other one is to shoot
in priority on pixel with noise.
> And how is your current technique working? Are you shooting several light
There is no light ray. At each object surface hit, I shoot n x n ray to sample
the hemisphere. When a ray hit a emmisive surface, I return the emmisive value.
The process is recursive and is stopped by the maximum allowed recursion depth
is reached (for the moment the max_trace_level). So only ray that hits a light
source contribute to the pixel color (it is the reason for such noise and so
long rendering time of this technique). The scene is rederered again and again
and the pixel values are accumulated. It is slowly converging, starting with a
very noisy picture.
> Regards,
> Tim
Date: 3 Feb 2008 03:10:01
Message: <web.47a5766edcec6a9fce311500@news.povray.org>
Funny because I arready used it to play. Here a pure result at low res ans
stopped after a few iteration.
Fidos
Download 'radiosity_and_bunnies.jpg' (51 KB)
Preview of image 'radiosity_and_bunnies.jpg'
