POV-Ray : Newsgroups : povray.binaries.images : an Escher-like image Server Time
6 Apr 2026 06:18:46 EDT (-0400)
  an Escher-like image (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: an Escher-like image
Date: 24 Jan 2008 22:21:04
Message: <479955a0$1@news.povray.org>
jhu wrote:
> There's still some problems with the render, such as those strange black
> splotches  on the table adjacent to the clear sphere
Oddly enough, those splotches could pass for part of the wood texture.
I like this image. :-)
William Tracy
You know you've been raytracing too long when your wife walks into the
room wearing only a smile and you start thinking of Colefax's fur macro.
    -- Ken Tyler
Date: 24 Jan 2008 22:24:02
Message: <47995652$1@news.povray.org>
jhu escreveu:
> Thanks! My global settings are listed below. What do you suggest I change?
hmm, no photons for caustics?  It seems radiosity is creating some weird
kind of caustics by its own, except it's black!
Now, count 1000 and error_bound .05?!  whew!  Took a few days to render,
huh? ;)
In my radiosity scenes I like more fine-grained radiosity shading so I
generally go for pretrace_start 0.04 and pretrace_end 0.008 or something
like that.  But I go with error_bound .2:  it's acceptably slow and
gives good results for the blending of blotches, specially coupled with
nearest_count of about 16.  Count is about right, though I first try
with lower counts, like 200 to 600...
As for the dark spots, the correct way to get caustics in povray is with
photons.  Radiosity has problems with black spots and glass surfaces.
Use a first radiosity pass without the reflective or transparent
surfaces, save that rca file and then render the final image with
photons and the reflective/transparent surfaces back.  Test without
photon first, then good luck. :)
Date: 24 Jan 2008 23:45:00
Message: <web.4799686138a94e697bcf5ca50@news.povray.org>
OK, thanks. Never played around with photons before. I'll give it a shot. BTW,
it's "only" a 16 hour render at those settings...
nemesis <nam### [at] gmailcom> wrote:
> jhu escreveu:
> huh? ;)
Date: 25 Jan 2008 05:18:04
Message: <4799b75c$1@news.povray.org>
Did you use sky_sphere? Radiosity doesn't
play well with infinite distance backgrounds,
it can cause dark spots. Use an inverted sphere
for the sky...
Date: 25 Jan 2008 05:30:42
Message: <dhejp3pqh6k54fopu8u0q9at6sqm43jquh@4ax.com>
I do like this very much. The level of detail is very good, I am sure that I can
see texture on her sweater. Is she the sort of person who holds a mug and puts
her fingers through the handle?
I' getting lost in this :)
And I love self referral in anything.
Excellent!
Regards
Date: 25 Jan 2008 06:45:00
Message: <web.4799cab838a94e69731f01d10@news.povray.org>
Very nice, I always like a good Escher tribute. Looks very real. Good wood
texture! It's also quite dark but this works well.
If you solve the blotchiness (looks like radiosity artifacts to me) and
re-render it, then you might also consider using a longer camera angle to
prevent the outer spheres being stretched by perspective (if this means putting
it outside the room then the no_image keyword might come in handy). Just a
thought!
keep it up
Bill
Date: 25 Jan 2008 08:08:36
Message: <4799df54@news.povray.org>
Tim Attwood napsal(a):
> for the sky...
Does it? I'll try it, thanks!
Date: 25 Jan 2008 10:42:32
Message: <479a0368$1@news.povray.org>
nemesis nous apporta ses lumieres en ce 2008/01/24 22:24:
> jhu escreveu:
>> change?
> huh? ;)
In this case, replacing the radiosity with photons don't look feasible. The
caustics are a projection of the sky. You'd need to use a light dome, possibly
composed of many area_light with photons{area_light}. You'll end up with tons of
photons, meaning a photons phase that will be extremely long and a memory use
that may get prohibitive.
You know you've been raytracing too long when you've tried to scan your face for
a texture.
Quietly Watching
Date: 25 Jan 2008 11:15:01
Message: <web.479a0ae438a94e699dc085130@news.povray.org>
It's beautiful.
I thought the black splotches were intentional to make the table looking more
differentiated.
They really fit. :)
             bluetree
Date: 25 Jan 2008 11:15:08
Message: <479a0b0c$1@news.povray.org>
jhu nous apporta ses lumieres en ce 2008/01/24 19:23:
Nice, but it's so dark! Even pushing my monitor brightness to the max I still
loose most of it. Looks good after adjusting gamma by +2.
Maybe increasing the brightness of the sky.
You may try using:
pretrace_end 0.005, 0.0025 or 0.00125 for 1, 2 or 3 more pretraces steps.
nearest_count 20 // ask to average more samples. Maximum value.
count 1600 // Maximum value.
adc_bailout 0.01/5 //increase divider more if needed.
raising error_bound a little, maybe 0.08 to 0.12. This may at least reduce the
contrast of the dark spots.
Unless doing multipass, comment out always_sample 0
No man or woman is worth your tears, and the one who is, won't make you cry.
