POV-Ray : Newsgroups : povray.binaries.images : Just in time for Christmas, Hopefully Server Time
21 Feb 2026 00:42:19 EST (-0500)
  Just in time for Christmas, Hopefully (Message 1 to 10 of 19)
Subject: Just in time for Christmas, Hopefully
Date: 15 Dec 2007 00:00:01
Message: <web.47635f3fd0e9aafab80d39510@news.povray.org>
I've been working on a holiday themed offering, and it was going rather well.
But I've been having problems with a model I made, and I can't figure out why.
The bulb object is made from a lathe, using a linear_spline.  There are 3600 odd
 control points, placed with loops.  I used a debug statement to observe the uv
coordinates around the defect, and they tell me I'm seeing things, but the
defect remains, no matter what texture I apply.
Other than that, I'll let the attached image speak for itself.
Any comments or suggestions would be helpful.
A.D.B
Download 'ornaments.jpg' (253 KB)
Preview of image 'ornaments.jpg'
Subject: Re: Just in time for Christmas, Hopefully
Date: 15 Dec 2007 02:47:03
Message: <47638677$1@news.povray.org>
message de news: web.47635f3fd0e9aafab80d39510@news.povray.org...
 Very nice!
You could use sturm (more accurate root solver) in your lathes.
Marc
Date: 15 Dec 2007 06:30:54
Message: <4763baee@news.povray.org>
  Try 'sturm', or my MeshLathe macro (from http://lib.povray.org/ ).
The latter might even render faster...
Date: 15 Dec 2007 13:40:01
Message: <web.47641f2a33ad2e29b80d39510@news.povray.org>
I tried using Sturm.  It takes longer, and there's no appreciable improvement.
I suppose I could try the macro...
Is it at all possible that the problem comes from having too many control
points?  Current count is 3338 (I'll admit this may be overkill.}  Also, the
defect seems to move upward as the incident angle increases.
Thanks for the input,
A.D.B.
Date: 15 Dec 2007 17:05:05
Message: <47644f91$1@news.povray.org>
  It is. Use a dozen or so control points and a smooth spline.
Date: 15 Dec 2007 18:30:01
Message: <web.4764628b33ad2e29892adb1d0@news.povray.org>
> A.D.B.
You can usually fix that with nail polish. Is it possible to render nail polish
in Povray?
It seems to me that the clear&gold ball with the Nativity scene on it is a
little out of round in some places. Did the glass get too hot and sag?
Leef_me
Date: 16 Dec 2007 09:39:41
Message: <476538ad@news.povray.org>
Could it be that you are seeing the plane through the ornament? All
other ornaments in the picture
don't appear to be as see-through as the one in question.Try to test
just that one ornament in slightly
different places on the plane to see if the defect moves or changes.
Date: 16 Dec 2007 10:35:01
Message: <web.476544da33ad2e29b80d39510@news.povray.org>
> > defect remains, *******no matter what texture I apply.*******
Date: 16 Dec 2007 16:08:22
Message: <476593c6$1@news.povray.org>
>> > the
Sometimes the normals on lathes get flipped, try using an
interior_texture and see if that has an effect.
Date: 17 Dec 2007 01:00:01
Message: <web.47660fa633ad2e29da3f66bb0@news.povray.org>
I've tried everything that's been suggested, so far, but nothing - aside from
decreasing the number of control points - had any effect.  And decreasing the
number of control points messed up my uv_mapping.
I'm posting the code for the bulb, if anyone can help me, I'd be grateful.
#macro ChristmasBulb(bulbMaterial, capMaterial, isMapped, Transform)
// These parameters control the size of the bulb.
// The cap is not linked to these parameters
#local r = 1.25;
#local r2 = 0.5;
#local T = 0.03125;
/* !--- DO NOT CHANGE THESE EQUATIONS. ---! */
#local h = sqrt(pow(r,2) - pow(r2,2));
#local s = degrees(atan(h/r2));
intersection {
 box { -r, <r, (r*sin(radians(s)))+(r2*sin(radians(s))), r> }
 difference {
  union {
   sphere { 0.0, r }
   cylinder { 0.0, ((r*sin(radians(s)))+(r2*sin(radians(s))))*y r2 }
  torus { (r2+(r2*cos(radians(s)))), r2 translate
((r*sin(radians(s)))+(r2*sin(radians(s))))*y }
  difference {
   merge {
    sphere { 0.0, r-T }
   torus { (((r-T)*cos(radians(s)))+((r2+T)*cos(radians(s)))), r2+T
    translate ((r*sin(radians(s)))+(r2*sin(radians(s))))*y }
  cylinder { 0.0, ((r*sin(radians(s)))+(r2*sin(radians(s)))+0.03125)*y
     (((r-T)*cos(radians(s)))+((r2+T)*cos(radians(s))))-(r2+T) }
  #if(isMapped)
   uv_mapping
  hollow on
  material { bulbMaterial }
   transform { Transform }
// Bulb object.
// Constructed out of a single lathe-object.
// Uses loops to determine the positions of the control points.
/* Note: There is a descernable visual flaw, when bulb is viewed straight-on: It
manifests
as a dark line around the equator of the bulb. At present, I do not know if this
is a design flaw,
or a program bug, but I have checked the coordinates of the control points, as y
approaches zero,
for both inner and outer surfaces, and I have not found any errors. - A.D.B. */
merge {
 lathe {
   linear_spline
   3338,
 #local a = 0;
 #while(a < s+90)
 #local P = vrotate(-r*y, a*z);
  <P.x, P.y>
 #local a = a + (s+90)/1500;
 #local b = s ;
 #while(b > 0)
 #local P = vrotate(-r2*x, b*z);
  <(r2+(r2*cos(radians(s))))+P.x,
   (r*sin(radians(s)))+(r2*sin(radians(s)))+P.y>
 #local b = b - s/169;
 #local c = 0;
 #while(c < s)
 #local P = vrotate(-(r2+T)*x, c*z);
  <(((r-T)*cos(radians(s)))+((r2+T)*cos(radians(s))))+P.x,
   ((r-T)*sin(radians(s)))+((r2+T)*sin(radians(s)))+P.y>
 #local c = c + s/169;
 #local d = s+90;
 #while(d > 0)
 #local P = vrotate(-(r-T)*y, d*z);
  <P.x, P.y>
 #local d = d - (s+90)/1500;
 #if(isMapped)
  uv_mapping
 bounded_by { box { -(r+0.015625),
  <(r+0.015625), ((r*sin(radians(s)))+(r2*sin(radians(s))))+0.3125,
(r+0.015625)> } }
  hollow on
// A plain, silver Bulb cap.  Not parameterized.
difference {
 union {
  cylinder { -0.15625*y, 0.0 0.25 }
  cylinder { -0.15625*y, 0.03125*y 0.21875 }
  torus { 0.21875, 0.03125 }
  torus { 0.21875, 0.03125 translate -0.15625*y }
  torus { 0.125, 0.0078125 rotate 90.0*x translate 0.109375*y }
 cylinder { -0.21875*y, 0.0 0.21875 }
  material { capMaterial }
   photons { target reflection on refraction off }
   transform {
    Transform
#debug concat("Max Height: " str((r*sin(radians(s)))+(r2*sin(radians(s))), 0, 6)
"\n")
Cheers,
A.D.B.
