POV-Ray : Newsgroups : povray.binaries.images : Just in time for Christmas, Hopefully Server Time
14 Mar 2026 07:32:08 EDT (-0400)
  Just in time for Christmas, Hopefully (Message 11 to 19 of 19)
Subject: Re: Just in time for Christmas, Hopefully
Date: 17 Dec 2007 06:13:12
Message: <476659c8$1@news.povray.org>
> I've tried everything that's been suggested, so far, but nothing - aside
> from
> decreasing the number of control points - had any effect.  And decreasing
> the
> number of control points messed up my uv_mapping.
> I'm posting the code for the bulb, if anyone can help me, I'd be grateful.
The problem is too many control points in a small space.
This is similar to other floating point accuracy issues, because
of floating point errors some of the points in your lathe are
doubling back, or coincident. A work-around is to scale up your
lathe's control points, then scale down the lathe to the desired size.
#macro ChristmasBulb(bulbMaterial, capMaterial, isMapped, Transform)
// These parameters control the size of the bulb.
// The cap translation is linked to these parameters
#local r = 125;
#local r2 = 50;
#local T = 3.125;
/* !--- DO NOT CHANGE THESE EQUATIONS. ---! */
#local h = sqrt(pow(r,2) - pow(r2,2));
#local s = degrees(atan(h/r2));
merge {
   lathe {
      linear_spline
      3338,
      #local a = 0;
      #while(a < s+90)
         #local P = vrotate(-r*y, a*z);
         <P.x, P.y>
        #local a = a + (s+90)/1500;
 #local b = s ;
 #while(b > 0)
 #local P = vrotate(-r2*x, b*z);
      <(r2+(r2*cos(radians(s))))+P.x,
       (r*sin(radians(s)))+(r2*sin(radians(s)))+P.y>
 #local b = b - s/169;
 #local c = 0;
 #while(c < s)
 #local P = vrotate(-(r2+T)*x, c*z);
  <(((r-T)*cos(radians(s)))+((r2+T)*cos(radians(s))))+P.x,
   ((r-T)*sin(radians(s)))+((r2+T)*sin(radians(s)))+P.y>
 #local c = c + s/169;
 #local d = s+90;
 #while(d > 0)
 #local P = vrotate(-(r-T)*y, d*z);
  <P.x, P.y>
 #local d = d - (s+90)/1500;
 #if(isMapped)
  uv_mapping
  hollow on
  material { bulbMaterial }
   scale 1/100
   transform { Transform }
// A plain, silver Bulb cap.  Not parameterized.
difference {
 union {
  cylinder { -0.15625*y, 0.0 0.25 }
  cylinder { -0.15625*y, 0.03125*y 0.21875 }
  torus { 0.21875, 0.03125 }
  torus { 0.21875, 0.03125 translate -0.15625*y }
  torus { 0.125, 0.0078125 rotate 90.0*x translate 0.109375*y }
 cylinder { -0.21875*y, 0.0 0.21875 }
  material { capMaterial }
   photons { target reflection on refraction off }
   transform {
    translate ((r/100*sin(radians(s)))+(r2/100*sin(radians(s))))*y
    Transform
#debug concat("Max Height: " str((r*sin(radians(s)))+(r2*sin(radians(s))),
0, 6)
"\n")
Date: 17 Dec 2007 19:30:02
Message: <web.4767136833ad2e2927b32be90@news.povray.org>
Thanks, Tim, that works a treat.
A.D.B.
Download 'ornaments4.png' (467 KB)
Preview of image 'ornaments4.png'
Date: 18 Dec 2007 02:45:01
Message: <web.476779d133ad2e29892adb1d0@news.povray.org>
> A.D.B.
Hey Anthony,
Congrat on the nice bulbs.
I tried to use an image for the bulb material, but I cannot scale it.
Here is my code, can you point out what I am doing wrong?
Thank you.
Leef_me
//start
#include "xmas_bulb.inc"
#version 3.6;
global_settings {
  assumed_gamma 1.0
  location  <0.0, 0.5, -8.0>
  direction 1.5*z
  look_at   <0.0, 0.0,  0.0>
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.6,0.7,1.0>]
      [0.7 rgb <0.0,0.1,0.8>]
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <1, 1, 1>  // light's color
  translate <-30, 30, -30>
#declare bulb = material {
        pigment { image_map { jpeg "Dime_front.jpg" map_type 1
        } scale 0.01
#declare capq2 = material {
        pigment { rgb <1,1,0>
#declare place = transform {
        translate <0,0,0>
        rotate y*360*clock
ChristmasBulb(bulb, capq2, 0, place)
//end
Date: 18 Dec 2007 11:01:50
Message: <4767eeee$1@news.povray.org>
Leef_me nous apporta ses lumieres en ce 2007/12/18 02:42:
>> A.D.B.
> Hey Anthony,
> Thank you.
> Leef_me
> //start
> #version 3.6;
> global_settings {
>   assumed_gamma 1.0
> camera {
>   direction 1.5*z
> sky_sphere {
>   pigment {
>     gradient y
>     color_map {
> light_source {
>              texture {
>         } scale 0.01
>              texture {
>         translate <0,0,0>
>         rotate y*360*clock
> //end
When you scale a spherical pattern, all points move acording to the origin.
What you need is to use a warp{spherical} after the scaling.
Your image_map become:
         pigment { image_map { jpeg "Dime_front.jpg" map_type 0
//Use a planar maping
         	scale 0.01
warp{spherical} // Wrap it around the sphere
Now, your image get repeated 100 times around the circumference and 50 times
from one pole to the other.
You know you've been raytracing too long when you can recite your high school
Trig book from memory.
Date: 18 Dec 2007 16:40:01
Message: <web.47683d4c33ad2e292a7b15450@news.povray.org>
>               texture {
>           scale 0.01
> Alain
Thanks Alain but, that doesn't compile; the following does:
          scale 0.7
I didn't ask very well, but what I really wanted to do was a a single copy of an
image, scaled as desired, but still showing the 'bulb' similar to the bulb that
is closest to the camera.
Leef_me
Date: 18 Dec 2007 19:25:00
Message: <web.4768642f33ad2e29e2b1ffa00@news.povray.org>
A little secret:
The bulb closest to the camera is clear glass.
The image is a planar mapping onto a disc_object disc { <0, 0, 0>, z, 1.234375,
0.0 } - contained within the bulb.
A.D.B.
>               texture {
>           scale 0.7
> Leef_me
Date: 18 Dec 2007 20:40:00
Message: <web.476875f833ad2e292a7b15450@news.povray.org>
> A little secret:
> Regards,
> A.D.B.
Ahh!  Now a comprehend.
But let's keep the secret; that is you, me and the other 100's of Povray users.
Cheers. And thanks for the info.
Leef_me
Date: 19 Dec 2007 10:51:27
Message: <47693dff@news.povray.org>
Leef_me nous apporta ses lumieres en ce 2007/12/18 16:36:
>>               texture {
>>           scale 0.01
>> Alain
>               texture {
>           scale 0.7
> Leef_me
In that case, just add "once" for the image_map. Now, you use rotate to place
the image where you want it.
EVERYTHING HAS A GENDER
You may not know this but many nonliving things have a gender...
Ziploc Bags are Male, because they hold everything in, but you can see right
through them.
Date: 20 Dec 2007 10:25:01
Message: <web.476a891533ad2e291ee33c1d0@news.povray.org>
> I've been working on a holiday themed offering, and it was going rather well.
> But I've been having problems with a model I made, and I can't figure out why.
> The bulb object is made from a lathe, using a linear_spline.  There are 3600 odd
>  control points, placed with loops.  I used a debug statement to observe the uv
> coordinates around the defect, and they tell me I'm seeing things, but the
> defect remains, no matter what texture I apply.
> Other than that, I'll let the attached image speak for itself.
> Any comments or suggestions would be helpful.
> A.D.B
What happens when you remove the plane?
