POV-Ray : Newsgroups : povray.binaries.images : slice an object Server Time
30 Sep 2024 07:22:20 EDT (-0400)
  slice an object (Message 1 to 3 of 3)
Subject: slice an object
Date: 13 Dec 2007 00:50:00
Message: <web.4760c6f48605ee6f5a73e3b40@news.povray.org>
Download 'sliced_object.png' (77 KB)
Preview of image 'sliced_object.png'
Subject: Re: slice an object
Date: 13 Dec 2007 13:15:01
Message: <web.47617616bef053202a7b15450@news.povray.org>
"Meothuru" <nomail@nomail> wrote:
Very nice.
I was trying to do something like that with a 3-d heart shape. I didn't succeed
and the project was time sensitive.
My idea was to use several 'intersection' statements between the object and
boxes, then be able to make the pieces fly into place. Hmmm, blob might have
been nice too.
Now that you have the method, please use it wisely. No poser characters should
be harmed. ;)
Code would be appreciated.
Leef_me
Date: 14 Dec 2007 00:50:01
Message: <web.476218acbef053205a73e3b40@news.povray.org>
> Very nice.
> been nice too.
> be harmed. ;)
> Leef_me
Heres is the exported SDL-code from the KPOV-modeler (it is machine-generated
code, not handcoded.). Hope it helps ...
//*PMRawBegin
#include "textures.inc"
//*PMRawEnd
global_settings {
   adc_bailout 0.0039216
   assumed_gamma 1.5
   max_trace_level 256
   noise_generator 2
// this is the object you want to slice
#declare myObject = difference {
   union {
      cylinder {
         <1, 0, 0>, <-1, 0, 0>, 0.5
         scale 1
         rotate <0, 0, 0>
         translate y*0.25
      cylinder {
         <-0.75, 0, 0>, <-1, 0, 0>, 0.535
         scale 1
         rotate <0, 0, 0>
         translate y*0.25
      cylinder {
         scale 1
         rotate <0, 0, 0>
         translate y*(-0.25)
      cylinder {
         scale 1
         rotate <0, 0, 0>
         translate y*(-0.25)
   superellipsoid {
      <0.2, 0.2>
      scale <1, 0.5, 1>
      rotate <0, 0, 0>
      translate x*1.2642
   torus {
      0.5, 0.25
      scale <1, 1.15, 1>
      rotate x*90
      translate x*0.7
   cylinder {
      <0, 0.8, 0>, <0, -0.8, 0>, 0.1
      scale 1
      rotate <0, 0, 0>
      translate x*0.5
   box {
      <-1.001, -0.075, -0.5>, <0.5, 0.075, -0.375>
      scale 1
      rotate <0, 0, 0>
      translate <0, 0, 0>
   box {
      <-1.001, -0.075, 0.375>, <0.5, 0.075, 0.5>
      scale 1
      rotate <0, 0, 0>
      translate <0, 0, 0>
      color rgb <0.9, 0.9, 0.9>
   finish {
      //*PMRawBegin
      Dull
      //*PMRawEnd
   scale 1
   rotate z*90
   translate <0, 0, 0>
// this is the definition of the slice (intersection)
#declare Slice = box {
   <-1, -0.05, -1>, <1, 0.05, 1>
   translate y*(-1.06)
   // set the  slice at the bottom(direct under teh object)
sky_sphere {
      color rgb <0.054902, 0.219608, 0.4>
union {
   //*PMRawBegin
   #declare z1=0;          //Init Loop Counter
   #declare scheiben=13;  // Number of slices
   #declare Thickness=0.15;    // Thicknes of the slices
   #declare abstand=-0.15; // Distance between the slices
   #declare versatz1=0;  //Offset of the slice-shift init
   #declare versatz2=0;  //dto.
   #while (z1<=1)
      union {
         intersection {
            object {myObject }
            object {Slice translate <0,versatz1,0>}
     translate <0, versatz2,0>
     #declare versatz1=versatz1+Thickness;
     #declare versatz2=versatz2+Thickness+abstand;
     #declare z1=z1+1/scheiben;
   //*PMRawEnd
   finish {
      //*PMRawBegin
      Dull
      //*PMRawEnd
   scale 2
   translate <-0.75, -1, -0.75>
   rotate <0, 0, 0>
   //*PMRawBegin
   //*PMRawEnd
union {
   //*PMRawBegin
   myObject
   //*PMRawEnd
   rotate y*33
   translate <3, 0, -1>
light_source {
   //*PMName Key-Light
   <4, 10, -15>, rgb <1, 1, 1>
   area_light <6, 0, 0>, <0, 6, 0>, 9, 9
   adaptive 1
   circular
   orient
light_source {
   //*PMName Fill-Light
   <-4, 10, -15>, rgb <0.5, 0.5, 0.5>
   shadowless
   media_interaction off
   perspective
   location <3, 3, -6>
   sky <0, 1, 0>
   direction <0, 0, 1>
   right <1.3333, 0, 0>
   up <0, 1, 0>
   look_at <0, 0, 0>
