POV-Ray : Newsgroups : povray.binaries.images : shiny shiny shiny Server Time
13 Sep 2025 02:35:45 EDT (-0400)
  shiny shiny shiny (Message 4 to 13 of 23)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: shiny shiny shiny
Date: 30 Nov 2007 14:40:00
Message: <web.475065f11bb4a81e3c1e96f10@news.povray.org>
> I thankyou.
> #macro Knot(a)
>   (<sin(a) + 2*sin(2*a), 1.25*sin(3*a), cos(a) - 2*cos(2*a)>)
> #end
> blob {
>   threshold 0.9
>   #local ang = 0;
>   #while (ang < 2*pi)
>     sphere { Knot(ang), 1.5, 0.5 }
>     #local ang = ang + 0.01;
>   #end
>   pigment { color Black }
>   finish { ambient 0 diffuse 0 reflection { 1 } } }
> Enjoy.
Oh, thank you Bill!! You're the best. I made a sculpture a long time ago,
exactly this shape ... started by knotting a piece of dryer hose.
Janet
Date: 4 Dec 2007 07:05:01
Message: <web.475540641bb4a81e943b35b60@news.povray.org>
Thanks Bill, that is a very amazing shape. So amazing, in fact, that I just had
to try it out myself. Being perhaps a little too eager I made it glass, and
added photons, radiosity and a "grid"... ;)
....Unfortunately, I find out too late, I think it slightly intersects the ground
plane. But it took about 2 and a half days to render in 2 threads on a
dual-core 2.4ghz PC so I won't be reattempting this until just before I go away
over Christmas. I would love to try it with an HDR background but I am not sure
how to get photons set up to shoot from a background image.
Anyway I thank you again -- I now have, at the very least, an interesting
wallpaper for my desktop!
sooperFoX
P.S. I have scaled back the quality settings a bit 'cause at high quality it was
still 462kb even as a JPEG (is that too big for this group?). If anyone would
like it though I will post the full version upon request (original render is
+w1280 +h1024 +a0.0 +am2).
> "Janet" <par### [at] attnet> wrote:
> > "Bill Pragnell" <bil### [at] hotmailcom> wrote:
> > > Just playing with HDR probes in MegaPOV.
> > They look really nice. I like that shape - a lot!!
> I thankyou.
> #macro Knot(a)
> #end
> blob {
>   threshold 0.9
>   #local ang = 0;
>   #while (ang < 2*pi)
>   #end
> Enjoy.
Download 'knot800x640.jpg' (115 KB)
Preview of image 'knot800x640.jpg'
Date: 4 Dec 2007 08:52:39
Message: <47555ba7@news.povray.org>
sooperFoX nous apporta ses lumieres en ce 2007/12/04 07:01:
> sooperFoX
To have the object just tangent, #declare the knot and use:
plane{y min_extent.y [your_Pigment]}
There is no way that a HDR will shoot photons. You can use the lights dome
method. It replace the HDRI background with numerous lights. You could also
crank up the radiosity settings.
The last person that quit or was fired will be held responsible for  everything
that goes wrong.
Date: 4 Dec 2007 09:25:01
Message: <web.475562361bb4a81e943b35b60@news.povray.org>
Thanks Alain for the helpful advice, you can be sure I'll give it a go next time
around.
I have to do a few tests and a lot more research into the light dome method. I
have played with an HDR Shop plugin briefly a while back which I think uses a
median cut method, but as it writes a text file as output I am going to have to
find a way to 'massage' that output to POV light source statements. I think I
also remember someone attempted to write an SDL version that does a similar
thing, but if I recall it wasn't very fast.
I'll let you know how it goes anyway. I am still not sure if median cut is the
best way to go since it's better for dividing the distributed ambient (diffuse)
light rather than a few 'representative' bright (specular) light points for
photons.
By the way, did you mean use radiosity instead of the photons, or along-side?
Have you done anything like this before? If so, can you recommend any settings
to use as a guide? Eg good range for error_bound, count and nearest_count
values, etc?
sooperFoX
Date: 5 Dec 2007 10:57:37
Message: <4756ca71$1@news.povray.org>
sooperFoX nous apporta ses lumieres en ce 2007/12/04 09:20:
> around.
> photons.
> values, etc?
> Cheers
> sooperFoX
I made a small error. It should be:
plane{min_extent(Knot).y [Your_pigment]}
   A hooker once told me she had a headache.
   	Rodney Dangerfield
Date: 6 Dec 2007 06:35:00
Message: <web.4757dded1bb4a81e731f01d10@news.povray.org>
I'm glad you found it inspirational. I can't take the credit for formulating it
however; I found the equation on the net somewhere.
Ah, that's not too bad. I've run some large images for a couple of weeks in the
past, sometimes as test renders! Of course, this is slightly inconvenient if
you're using your everyday machine....
With regards to what Alain said about radiosity and photons - I've found that
when using very high quality radiosity with glass objects, you can get caustics
naturally without photons. However, they're not nearly as good as photon-mapped
caustics. If you use the simple scene you posted before then I wouldn't bother
with radiosity, it probably won't add much (although it will clobber your
render time). But the light-dome method, or even just an area_light, would
probably look pretty good!
I tried to make a mesh version of the knot-blob by tracing rays out from its
centre, but sadly it occludes itself in places so it didn't work well enough.
I'll make a mesh version of a non-blobbed knot at some point - this should
render a bit quicker.
Bill
Date: 7 Dec 2007 05:05:00
Message: <web.475919441bb4a81e943b35b60@news.povray.org>
I thought as much, however it is still important that you worked out how to
represent it in POV!
I think you are right. The main reason I had radiosity was because I started out
with something that wasn't glass, and then got over-ambitious ;)
I love the variation in shadow tones only possible with radiosity (for solid
objects) but since it is glass I suspect it will have limited use now, since
the surface itself is completely transparent except for the specular
highlights.
I also thought about this a bit. Have you seen Kevin Loney's mesh approximation
macro?
http://www.econym.demon.co.uk/isotut/approx.htm
(The download link is in the yellow box at the bottom of the page.)
If you could somehow represent the shape as an isosurface you could use Kevin
Loney's (or indeed Jaap Frank's much optimised subdivision version) to save the
isosurface as a mesh and then render that.
Or, maybe it would be possible to get the macro to work on a blob (or any type
of
object).
I'm afraid both are beyond my mathematical understanding! But maybe you know a
friend who knows a friend... :)
- sooperFoX
Date: 7 Dec 2007 18:00:01
Message: <web.4759d0231bb4a81e943b35b60@news.povray.org>
Well, here is another test render. This time it only took 6 and a half hours,
but I rendered at a lower resolution and with less antialiasing. I am using my
everyday PC but it has 2 cpu cores so it doesn't have too much of a detrimental
effect on the other things I am doing. Plus if I leave it going overnight I
don't seem to notice at all...
This render uses no radiosity. I also toned down the phong highlight a bit,
although maybe I didn't need to. The reflection on the ground has not been
changed but now I am using an HDR background so the effect is more pronounced.
I used TGQ's light dome method that I mentioned in an earlier post, to generate
the lights from an image. It is not too slow for parse-time with only 32
lights. If you're interested his post was on 14 May 2007 in p.b.s-f:
http://news.povray.org/povray.binaries.scene-files/thread/%3Cweb.46488bca4e05d400c150d4c10@news.povray.org%3E/
The probe I used was The Kitchen by JVP (available at ignorancia.org). The glass
texture is based off an IRTC entry by Tek in 2005. Many thanks to all you
amazing people!
I still have a few more tweaks before I re-do the final render.
-sooperFoX
Download 'knot840x525.jpg' (123 KB)
Preview of image 'knot840x525.jpg'
Date: 8 Dec 2007 18:05:00
Message: <web.475b21c21bb4a81e78dcad930@news.povray.org>
Hi, all--
I don't know very much about HDR at all, so this might be a very naive question:
Is it possible to apply a HDR image to the inside of a large, hollow sphere in
POV, then use that (with ambient 1) to generate the photons (and reflections in
the glass)?
Ken W.
Date: 8 Dec 2007 18:25:01
Message: <web.475b26601bb4a81e78dcad930@news.povray.org>
> the glass)?
OOPS--sorry. That was a real faux-pas. I was thinking of radiosity.
:-0
***never mind***
Ken
