POV-Ray : Newsgroups : povray.binaries.images : Fall Forest Server Time
14 Apr 2026 19:13:55 EDT (-0400)
  Fall Forest (Message 11 to 20 of 21)
<<< Previous 10 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: Fall Forest
Date: 18 Nov 2007 17:51:26
Message: <2eg1k3l55191mqm01b1u0s2mk6h73ogpib@4ax.com>
On Sun, 18 Nov 2007 07:15:25 +0100, Jan Dvorak
<jan### [at] centrumcz> wrote:
>Kirk Andrews napsal(a):
>> Here's another view, closer to the river.  Rendered in 10 hrs.
>Perfect.
>If you've got plenty of time try to add a focal blur :-)
Please don't do that it always looks like you are just trying to copy
a photo not render a realistic scene.
John
Date: 18 Nov 2007 18:56:00
Message: <4740d110@news.povray.org>
I think it depends. Some focal blur *is* realistic after all, but only
if you're actually taking a photo of something in the foreground or such
where you'd need a lense. Try looking at various Photographer's sites
and check their "focal blur". Depending on the scene, it might really add.
But on this one, I agree. Landscape images seldomly have focal blur.
It's most common on extreme close-ups that something in the background
gets blurred. Or on miniatures, because those are close-ups as well, but
don't look like it from the setting. ;-)
Tim
aka "Tim Nikias"
Date: 18 Nov 2007 20:10:00
Message: <web.4740e23d30e052ea82e15b410@news.povray.org>
Date: 18 Nov 2007 21:30:00
Message: <web.4740f45930e052eadd21a49b0@news.povray.org>
Thanks, everyone!
Based on your suggestions, I think I would like to add leaves on the forest
floor (and maybe some flying through the air).  If I wanted to do it right, I
would need to figure out a way to get those eroded banks.  There is a slight
"glow" done in post-processing.  I had thought about adding a watchtower--I
made a couple of tower models last year, and they might look pretty good here.
Unfortunately, these additions will probably have to wait until I've got a bit
more time.
Thanks again,
Kirk
Date: 18 Nov 2007 21:56:29
Message: <tmu1k3h95g8voa6s2023ph32mna5eevnpt@4ax.com>
Kirk,
These look really nice.  I think what's missing for more realism is ground clutter.
There should be
some fallen leaves and branches on the ground and in the water.  It'd be tough to do
well, but I
think it'd add a nice touch of realism.
Just my opinion.
Kyle
Date: 19 Nov 2007 02:47:31
Message: <47413f93$1@news.povray.org>
"Jan Dvorak" <jan### [at] centrumcz> schreef in bericht
news:473fd8b8@news.povray.org...
> Perfect.
No! No! No focal blur in this image! There is nothing in the foreground that
needs 'focus'!
PS Great images, Kirk!!
Date: 19 Nov 2007 06:25:00
Message: <web.4741720730e052eadd21a49b0@news.povray.org>
> > Perfect.
> needs 'focus'!
> Thomas
Focal blur can be neat in some images, as has been said, but not in this image
as it currently is.  For it to work in this picture, I would either need some
twigs or some kind of detail in the foreground to be blurry and the landscape
in focus, or I could perhaps place some very detailed autumn leaves (blowing in
the wind) right next to the camera, focusing on those and have the forest
blurry.  But either way, I would have changed the image drastically.
Thank you!
Date: 19 Nov 2007 14:07:20
Message: <4741dee8$1@news.povray.org>
Kirk Andrews wrote:
> Here's another attempt at landscapes.  I feel that there is still something
> missing from the image to make it feel the way I want it to, but I'm not sure
> what it is yet.  I want to add genuine media to get a nice, moist, morning
> mist.  I generally stay as far away from media as possible, so if someone with
> some experience might suggest a good starting place, I'd be much obliged.
I have been thinking of and trying to create images like these 'bout 2
years, and you go and create what, three or four in a week?!?!
That's just not fair..
Otherwise, this and all those previous island-images all look great!
-- Arttu "Blizzara" Voutilainen
Date: 19 Nov 2007 14:21:57
Message: <q9o3k3dh1h46t3sfav1404408klodddp0a@4ax.com>
On Mon, 19 Nov 2007 00:56:01 +0100, Tim Nikias
>Regards,
>Tim
I well understand focal blur.  If I say it myself I am quite a good
photographer.   With my macro photography I try as much as possible to
get rid of it.   As far as I am concerned the only time that focal
blur is realistic is when you are trying to simulate a photograph.
If you are trying to simulate what your brain "sees" then there is no
place for focal blur.
(In my opinion trhat is <grin>)
John
Date: 19 Nov 2007 16:25:00
Message: <web.4741fec530e052eadd21a49b0@news.povray.org>
Well, you have to understand that the reason I have created several of these all
in a row is because after trying for years and failing, I have finally started
producing landscapes that I am proud of!  But thank you.
Honestly, these images are not so very complex.  They all use the same basic
structure and there's just a few key elements:
My terrain is an isosurface using a wrinkles pigment with poly_wave 4.
Poly_wave 4 is essential since it better simulates the effect of erosion
filling in the valleys and actually creating reasonably flat places at times.
There always must be some type of fog, whether you use simple fog or actual
media (I just use a simple ground fog).  The fog needs a bluish tint to be
realistic (or pinkish for sunrise or sunset).
The water is more complicated:
#declare Water =
plane {y,0
  hollow
    average
    texture_map {
      #local i = 0;
      #while (i < 10)   //  This loop creates a blurred reflection
        pigment {rgbt 1}
        finish{
          conserve_energy
          diffuse 0.0
          ambient 0
          reflection{0 .7 fresnel on metallic 0}
        normal {bumps .125 turbulence .1 scale 1 rotate (rand(R1)/1)*y }
      #local i = i + 1;
  interior {
    ior 1.31                // index of refraction
    fade_power 1001         // values larger than 1000 give realistic
    fade_distance 0.75      // distance where light reaches half intensity
    fade_color <.2, .9, .6> // color for fading
      media{
        absorption rgb 1-WaterColor //declared earlier
        density{rgb 1}
I hope that helps.
