POV-Ray : Newsgroups : povray.binaries.images : Victoria Import Server Time
18 Feb 2025 17:21:45 EST (-0500)
  Victoria Import (Message 1 to 10 of 32)
Subject: Victoria Import
Date: 25 Sep 2007 14:50:01
Message: <web.46f95767f4c2bcc0bc2a012a0@news.povray.org>
Sent her to make-up for brows and hair before shooting the close up
No normals, just low light and ambient 1.0
Done with OBJuvPOV and DAZ free downloads, and some persistence of vision
If you saw the hair map, looks like UVs are off. Map edited.
Download 'v3lo2a.png' (496 KB)
Preview of image 'v3lo2a.png'
Subject: Re: Victoria Import
Date: 26 Sep 2007 03:53:05
Message: <46fa0fe1$1@news.povray.org>
"alphaQuad" <alp### [at] earthlinknet> schreef in bericht
news:web.46f95767f4c2bcc0bc2a012a0@news.povray.org...
About the hair: looks like the transparancy map is missing... (maybe the
bump map too?)
Date: 26 Sep 2007 23:45:00
Message: <web.46fb23decc37018fd091d5c70@news.povray.org>
> bump map too?)
> Thomas
there is UpDoTr.jpg - negative of the hair on black.
cant find an example of transparency or filter by map-file
or I just didn't read that part of the help file yet?
I see filter and transmit within image_map{} by numbers.
"filter   5, 1.0 // Make color 5 100% filtered transparent"
is the "5" a color index?
as I look at pigment I dont see where transparent map fits in:
PIGMENT:
        [PIGMENT_IDENTIFIER]
        [PIGMENT_TYPE]
        [PIGMENT_MODIFIER...]
PIGMENT_TYPE:
    PATTERN_TYPE | COLOR |
    image_map {
        BITMAP_TYPE "bitmap.ext" [IMAGE_MAP_MODS...]
PIGMENT_MODIFIER:
    PATTERN_MODIFIER | COLOR_LIST | PIGMENT_LIST |
    color_map { COLOR_MAP_BODY } | colour_map { COLOR_MAP_BODY } |
    pigment_map { PIGMENT_MAP_BODY } | quick_color COLOR |
    quick_colour COLOR
but I am a victim of dental work right now so, ya an example would help
Date: 27 Sep 2007 03:26:46
Message: <46fb5b36$1@news.povray.org>
I have not been too familiar with Daz|Studio for the last year or so. I much
prefer Poser. However, I shall try to provide an example.
The UpDoTr.jpg looks like a transparancy map to me...
news:web.46fb23decc37018fd091d5c70@news.povray.org...
>> bump map too?)
>> Thomas
> PIGMENT:
>    pigment {
>        [PIGMENT_TYPE]
> PIGMENT_TYPE:
>    image_map {
> PIGMENT_MODIFIER:
>    quick_colour COLOR
Date: 27 Sep 2007 03:57:52
Message: <46fb6280@news.povray.org>
Hi alphaQuad,
This is a quick 'n dirty render of Victoria 3. Took me about 5 minutes.
1) export as .obj file in DS
2) import in Poseray
3) export as POV-Ray file
4) render in POV-Ray
I attach here also the material file generated for POV-Ray by Poseray (I
just edited out the non-relevant folder paths) so you can see what
image_maps were used for this particular figure. Note that Poseray has
extensive possibilities to adapt the textures to your needs. If you plan to
export often from DS, then consider seriously the use of Poseray!
I think this will help you along. Don't hesitate to ask though, when in
doubt  :-)
Download 'Victoria3_test.jpg' (35 KB) Download 'Victoria3_test_POV_mat.inc.txt' (19 KB)
Preview of image 'Victoria3_test.jpg'
Date: 27 Sep 2007 10:55:00
Message: <web.46fbc372cc37018fac60c46d0@news.povray.org>
please advise on multiple attachments, thank you
Date: 27 Sep 2007 11:15:11
Message: <46fbc8ff@news.povray.org>
alphaQuad nous apporta ses lumieres en ce 2007/09/27 10:51:
You can't have multiple attachments if you are using the web interface.
If you use any news reader, it's very easy. It could be just as easy as draging
the files to the message as you compose it.
I use Mozilla Thunderbird.
Adult, n.: One old enough to know better.
Date: 27 Sep 2007 12:00:01
Message: <web.46fbd107cc37018fac60c46d0@news.povray.org>
I dont expect Poseray to run very well on Win98SE and my old Geforce2
that helps alot as it shows how to make the "material" but alas all OBJuvPOV
did was create a texture_list.
Bangs the MATERIAL
#declare p_map15=pigment {image_map{jpeg "UpDoMBr.jpg" interpolate 2
transmit all 0 filter all 0} }
#declare p_map16=pigment{image_map{jpeg "UpDoTr.jpg" interpolate 2 }}
#declare Bangs__opaque=
texture{ pigment{ p_map15}
        finish{specular 0.5902353 roughness 0.03641292 ambient rgb <0,0,0>
diffuse 0.6  reflection{0 metallic} conserve_energy}}
#declare Bangs_=
material{
texture{  pigment_pattern{ p_map16}
texture_map{[0 pigment{Clear}]
            [1 Bangs__opaque]
and now seems an impossible monument to achieve materials applied the
correct parts of the mesh from a texture_list and texture indexed to each
face.
texture != material
looked for material_list - not found
Date: 27 Sep 2007 12:20:43
Message: <46fbd85b$1@news.povray.org>
"alphaQuad" <alp### [at] earthlinknet> wrote in message
news:web.46fbd107cc37018fac60c46d0@news.povray.org...
   Time for an upgrade? There are some *good* PC's out there for not a lot
of money now.
    But, if you don't want to do that, just upgrade your graphics card, you
will actually need to if you want to progress further with your art. XP is
great! (Really, I haven't had one Blue Screen in nearly two years (that I
can remember)). I had win98SE before XP, and I had never-ending trouble with
it.
     ~Steve~
Date: 27 Sep 2007 13:10:01
Message: <web.46fbe26acc37018fac60c46d0@news.povray.org>
removed material_indices and face index numbers
all materials were the same, so it follows...
object {
hair
material{Bangs_}
now at the bottom of blupdo_v3.inc we find OBJuvPOV wrote:
mesh2{
uv_mapping
uv_mapping with no parameters and doesnt seems right even though I am lost
at this point.
someone throw a floater, I'm drowning
Download 'v3lo004.jpg' (101 KB)
Preview of image 'v3lo004.jpg'
