POV-Ray : Newsgroups : povray.binaries.images : Victoria Import Server Time
20 Mar 2026 09:33:59 EDT (-0400)
  Victoria Import (Message 11 to 20 of 32)
Subject: Re: Victoria Import
Date: 27 Sep 2007 14:04:09
Message: <46fbf099@news.povray.org>
alphaQuad wrote:
> I dont expect Poseray to run very well on Win98SE and my old Geforce2
> that helps alot as it shows how to make the "material" but alas all OBJuvPOV
> did was create a texture_list.
> Bangs the MATERIAL
> #declare p_map15=pigment {image_map{jpeg "UpDoMBr.jpg" interpolate 2
> transmit all 0 filter all 0} }
> #declare p_map16=pigment{image_map{jpeg "UpDoTr.jpg" interpolate 2 }}
> #declare Bangs__opaque=
> texture{ pigment{ p_map15}
>         finish{specular 0.5902353 roughness 0.03641292 ambient rgb <0,0,0>
> diffuse 0.6  reflection{0 metallic} conserve_energy}}
> #declare Bangs_=
> material{
> texture{  pigment_pattern{ p_map16}
> texture_map{[0 pigment{Clear}]
>             [1 Bangs__opaque]
> and now seems an impossible monument to achieve materials applied the
> correct parts of the mesh from a texture_list and texture indexed to each
> face.
> texture != material
> looked for material_list - not found
Although PoseRay was not tested with Win98 you can download it and try
it. Most likely it will work as long as you have the latest drivers for
your card.
I do not understand why do you have to edit the materials and use it on
another mesh. PoseRay exports a complete scene with geometry, lights and
camera. It exports materials because they allow transparency effects.
Cannot define a glass texture and expect the light to bend inside of the
mesh surface.
FlyerX
Date: 27 Sep 2007 15:05:00
Message: <web.46fbfde2cc37018fac60c46d0@news.povray.org>
THen suddenly a whale swam under me and carried me to shore humming a tune.
Said the name of it was "put the material in a different place"
so I did
mesh2 {
uv_mapping
material{Bangs_}
and the results have been made possible by Thomas.
Thank you Thomas!
now that still leaves the problem of the head/eyebrows using different
materials.
with all body data listed as one. (except for texture-indexed faces)
so should the mesh-parts/indices/materials be listed separately in mesh2{}?
Download 'v3lo004a.jpg' (106 KB)
Preview of image 'v3lo004a.jpg'
Date: 27 Sep 2007 16:15:00
Message: <web.46fc0e8acc37018fac60c46d0@news.povray.org>
> mesh surface.
> FlyerX
ok Poseray is running, thank you FlyerX
but doing things the hardway one can learn so very much.
And much more code should be revealed with this app.
cool FlyerX rox
aQ
Date: 27 Sep 2007 16:43:12
Message: <46fc15e0@news.povray.org>
"alphaQuad" <alp### [at] earthlinknet> wrote in message
news:web.46fc0e8acc37018fac60c46d0@news.povray.org...
  > cool FlyerX rox
      :o)  Welcome to the club!
       ~Steve~
> aQ
Date: 27 Sep 2007 19:30:01
Message: <web.46fc39a8cc37018fe18054de0@news.povray.org>
>   > cool FlyerX rox
>        ~Steve~
> > aQ
thanx steve,
a simple pov output of my v3.obj she was 180 reverse so I matrixed her back
around
hair tilted 2 degrees because of what seemed a high forehead
merged Thomas' material and up'd the ambient
alot needs setup in Poseray to achieve this image it seems.
and perhaps I need to experiment with daz exports, but I boot to another
drive to run directx8 which is a bit unstable here.
program closes, and no error messages appear.
Seems trace level was needed for hair to work
global_settings {
  //This setting is for alpha transparency to work properly.
  //Increase by a small amount if transparent areas appear dark.
   max_trace_level 10
big improvement in the skin hair and eyebrows
Download 'v3lo007.jpg' (256 KB)
Preview of image 'v3lo007.jpg'
Date: 28 Sep 2007 01:04:50
Message: <46fc8b72$1@news.povray.org>
news:web.46fc39a8cc37018fe18054de0@news.povray.org...
    Oh, well done. She's looking much better! I haven't really played with
hair yet, but what I see is encouraging.
       ~Steve~
Date: 28 Sep 2007 02:15:01
Message: <web.46fc9bb2cc37018f653fab8a0@news.povray.org>
well suddenly DAZ export doesnt crash and does NOT list all map files in the
..mtl export file, ARGH! it only listed the hair maps.
I still had to use Thomas's material.
I checked daz advanced export options to export everything but no maps for
her body appear in the mtl.
Thomas: tell me again all the steps you took to get a .mtl file exported
from DAZ with all the body maps.
Download 'victoria002_pov.jpg' (152 KB)
Preview of image 'victoria002_pov.jpg'
Date: 28 Sep 2007 03:03:10
Message: <46fca72e$1@news.povray.org>
"alphaQuad" <alp### [at] earthlinknet> schreef in bericht
news:web.46fc9bb2cc37018f653fab8a0@news.povray.org...
> the
Hmm... let me see...
In the Export|Advanced section, I checked Collect Maps. I suppose that
should do the trick.
Date: 28 Sep 2007 03:17:01
Message: <46fcaa6d$1@news.povray.org>
news:web.46fbfde2cc37018fac60c46d0@news.povray.org...
> materials.
> mesh2{}?
If you use Poseray, you do not need to move anything in the ..._geom.inc and
..._mat.inc files.
What is the problem? Eyebrows have their own material and that is used by
the mesh.
Date: 28 Sep 2007 03:45:02
Message: <web.46fcafc1cc37018f3ffee9290@news.povray.org>
> ..._mat.inc files.
> the mesh.
> Thomas
there was a problem until PoseRay was running and it wrote a mesh2 for every
object and materials were applied:
 #declare victoria001_=
union {
object{victoria001_SkinTorso_  uv_mapping material{SkinTorso_}}
etc .......
and OBJuvPOV had a single mesh2 for everything and texture-indexed faces,
was the logic problem in my head. that is all water under the bridge thanx
to PoseRay! um, flyerX that is
