POV-Ray : Newsgroups : povray.binaries.images : Bored Server Time
15 Apr 2026 01:00:50 EDT (-0400)
  Bored (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Bored
Date: 24 Aug 2007 15:35:00
Message: <web.46cf327d6d4f464a852a77190@news.povray.org>
Jim Charter <jrc### [at] msncom> wrote:
> And so how did you get the size of the pebbles to vary in scale like
> that?  It looks not quite random but interpolated.
Pretty simple actually - it's a bozo-based isosurface trace()ed with 20,000
spheres from its centre.
Subject: Re: Bored
Date: 25 Aug 2007 03:38:18
Message: <46cfdc6a$1@news.povray.org>
news:web.46cf327d6d4f464a852a77190@news.povray.org...
> 20,000
Oooh! That's smart!!!
Subject: Re: Bored
Date: 26 Aug 2007 01:30:01
Message: <web.46d10e916d4f464a85de7b680@news.povray.org>
> Argh, I'm very bored at work, so here's a random Friday afternoon glob of
> chrome-finished expanded polystyrene. Watch out, it's heavier than it
> looks!
Wow, how'd you get the expanded polystyrene to hold up in those acidic
electroplating baths?  I've seen orange juice eat through that stuff.  Good
job!
Subject: Re: Bored
Date: 26 Aug 2007 11:20:00
Message: <46d19a20$1@news.povray.org>
Cousin Ricky nous apporta ses lumieres en ce 2007/08/26 01:26:
>> looks!
> job!
That must be REALY cheap polystyrene! Or your orange juice was contaminated with
acetone or toluene... I have drank orange juice and limonade in styrofoam cups
without any problem. It can also hold wine, but, it give it a bad taste.
You know you've been raytracing too long when you try to compress a mandelbrot
landscape made of spheres just to 4 lines of pov code.
Warp
Subject: Re: Bored
Date: 29 Aug 2007 09:25:00
Message: <web.46d572f86d4f464a731f01d10@news.povray.org>
> > job!
> with acetone or toluene... I have drank orange juice and limonade in styrofoam
> cups without any problem. It can also hold wine, but, it give it a bad taste.
I'd be very worried if acetone contamination were a common problem.
Hmm, electroplating with Ni in a Watts bath needs a temperature of about
never mind dissolve. I agree about the orange juice though. :)
Subject: Re: Bored
Date: 29 Aug 2007 17:40:42
Message: <46d5e7da$1@news.povray.org>
I saw a guy being interviewed on a car show who chromes
restored plastic, even glued together bits. He paints it with
some sort of expensive silver paint, then electro-plates with
copper, then nickel, then chrome.  I think the copper may
help dissipate the heat.
Subject: Re: Bored
Date: 29 Aug 2007 20:05:40
Message: <46d609d4$1@news.povray.org>
Tim Attwood nous apporta ses lumieres en ce 2007/08/29 17:40:
>> 60-70ºC... I don't know about Cr. That would probably melt polystyrene,
The copper holds well on the silver paint, but nether the nickel nor the chrome
will. The copper plating is to thin to help protect from the heat.
Then the nickel makes an exellent bond with the copper, while the chrome will
peel from it.
Then the chrome will perfectly fuse onto the nickel. Also, the nickel makes an
harder, more resilient, substrate.
You go from "soft" (the plastic) to prety hard (nickel then chrome).
You know you've been raytracing too long when you downloaded and printed the
Renderman Interface documentation, so you'd have a little light reading to take
on holiday.
Alex McLeod a.k.a. Giant Robot Messiah
Subject: Re: Bored
Date: 30 Aug 2007 05:10:00
Message: <web.46d689306d4f464a731f01d10@news.povray.org>
Quite the opposite, probably - Cu is an excellent thermal conductor.
> peel from it.
Having had a quick peek at the binary phase diagrams, this seems to be
because Cr is soluble in Ni at low concentrations, and both Cu and Ni are
soluble in each other to a small degree, whereas Cr and Cu appear totally
immiscible.
The silver paint is probably just to give the substrate all-over electrical
conductivity so it can act as an electrode during the plating process.
Anyway, that's not how I made my styrofoam blob; I used a magic chrome corn
kernel in a giant popcorn maker. ;-)
Subject: Re: Bored
Date: 30 Aug 2007 09:06:21
Message: <46d6c0cd$1@news.povray.org>
Bill Pragnell nous apporta ses lumieres en ce 2007/08/30 05:09:
Sure is. And, for exactly that reason, it won't protect the plastic from the
heat, as in the plating vat, heat comes from all around. Cu will transmit that
heat quite effeciently to the plastic!
>> peel from it.
> immiscible.
So Ni will bont to Cu, then Cr will bond to Ni, but Cr will not bond to Cu, nor
will it bond to Ag.
Only plausible explanation. The paint's cost comes fron the silver dust it contains.
You know you've been raytracing too long when your personal correspondence to
friends starts out with #Dear Linda =
Ken Tyler
Subject: Re: Bored
Date: 30 Aug 2007 16:33:03
Message: <46d7297f$1@news.povray.org>
>>> chrome
> the heat, as in the plating vat, heat comes from all around. Cu will
> transmit that heat quite effeciently to the plastic!
I was thinking about the heat, they guy did say that other platers
were trying to do plastic but wern't getting as good of results.
He probably didn't share his "secret".  I'd guess that he uses a
heatsink on the electrodes, that would transfer the heat up off
the copper layer and out of the bath. Silver is also a better heat
conductor than copper, which may be why he was using
paint with silver in it instead of just iron or copper in the paint.
