POV-Ray : Newsgroups : povray.binaries.images : Coffee's On - again Server Time
10 Apr 2026 19:47:03 EDT (-0400)
  Coffee's On - again (Message 1 to 10 of 10)
Subject: Coffee's On - again
Date: 17 Jul 2007 08:30:03
Message: <web.469cb5e5742d527c150d4c10@news.povray.org>
I decided to render a wallpaper version of my Coffee's On CGSphere entry.
I fixed the switch and added some coffee stains (pot and burner are still
relatively new and clean...)
Also find it at my deviantART gallery:
http://www.deviantart.com/deviation/59992168/
-tgq
Download 'coffee's on - wp.jpg' (267 KB)
Preview of image 'coffee's on - wp.jpg'
Subject: Re: Coffee's On - again
Date: 17 Jul 2007 09:40:01
Message: <web.469cc618487a5d69be7bfb550@news.povray.org>
"Trevor G Quayle" <Tin### [at] hotmailcom> wrote:
I have nothing to say but that it is photorealistic!!! congratulations, very
impressive.
Date: 17 Jul 2007 11:35:02
Message: <web.469ce0f2487a5d6940d56c170@news.povray.org>
AWSOME!!
Date: 17 Jul 2007 11:50:02
Message: <web.469ce46f487a5d695bd364bc0@news.povray.org>
It's on my desktop.  Thank you!
Date: 17 Jul 2007 12:10:01
Message: <web.469ce974487a5d69c150d4c10@news.povray.org>
Thanks! No problem.
-tgq
Message: <web.469ce9cc487a5d69c150d4c10@news.povray.org>
> impressive.
Thank you.
-tgq
Date: 18 Jul 2007 03:06:29
Message: <469dbbf5@news.povray.org>
Funn is going to be very happy with this free advertisement  :-)
Excellent work indeed!!!
Date: 19 Jul 2007 18:50:03
Message: <viqv93tsppjkervhk102lpicpe7oc9b6jq@4ax.com>
Hey Trevor,
How did you make the coffee stains?
Date: 20 Jul 2007 08:20:01
Message: <web.46a0a7af487a5d69c150d4c10@news.povray.org>
Kyle <hob### [at] gatenet> wrote:
> Hey Trevor,
It is just a simple cylidrical-based pigment function. I map it to a disc
object and place it very slightly above the surface of the base object.  I
could put it directly into an object's material, but it is easier to work
with this way.
Actually the most difficult part was getting the right colouration.  I ended
up having to use both transmit and filter to get what I thought looks right.
 First time I've used both...
See code below.  Coffee cup ring is similar, with appropriate colour
mapping.  You can also play with the turbulence and scaling factor to get
various efffects.
-tgq
//CODE
//START
#declare CDRND=seed(0);
#macro CDrop(SIZ)
disc{0,y,1.0
  #local YT=1000*rand(CDRND);
  #local YR=360*rand(CDRND);
  pigment{
    cylindrical
    pigment_map{
      [0.145 rgbt 1]
      [0.15 rgbft <0.5,0.3,0.1,0.1,0.1>]
      [0.25 spotted
        colour_map{
          [0 rgbft <0.5,0.3,0.1,0.50,0.50>]
          [1 rgbft <0.5,0.3,0.1,0.30,0.70>]
        scale 0.1
    warp{black_hole <0.8,-YT,0>,0.75 inverse strength 1}//creates thickened
spot on edge
    #declare SCL=30;
    scale SCL
      warp {
        turbulence 0.25
        octaves 2
        lambda 1
        omega 0.75
    scale 1/SCL
    warp{turbulence 0.1}
    translate y*YT
    rotate y*YR
  finish{
    ambient 0
    diffuse 0.6
    conserve_energy
  scale SIZ
  translate -y*39.9
//END
Date: 29 Jul 2007 13:47:41
Message: <46acd2bd$1@news.povray.org>
Technically awesome.  Love the composition too.  Reminds me
thematically of some early Celmins:
http://www.artmag.com/museums/a_spain/aspmaso/celmins/celmins.jpg
