POV-Ray : Newsgroups : povray.binaries.images : Ruined Server Time
15 Apr 2026 04:14:02 EDT (-0400)
  Ruined (Message 11 to 17 of 17)
Subject: Re: Ruined
Date: 24 Jun 2007 09:34:22
Message: <467e72de$1@news.povray.org>
Beautiful image.
I am following this thread closely because I have been thinking about the
same thing since my image <450bcef5@news.povray.org>. I have no solution to
offer, but the cogs are turning in my brain  ;-)
Subject: Re: Ruined
Date: 24 Jun 2007 15:40:02
Message: <web.467ec797b5692e82798153040@news.povray.org>
"Kirk Andrews" <kir### [at] hotmailcom> wrote:
> Ahhh, there's the goal (and I hadn't thought about bird poop, either!).  The
> trick is getting that grime *just* in the recesses.  Samuel Benge has been
> trying to help me figure out how to do that.  If you have any suggestions
> on how that could be done in POV I'd love to hear it.
> -- Kirk
Hmm, the way I would do it, is with absorbing media applied to a cylinder
with a radius just a little bit smaller than the column's. Its density
might be (emi-)spherical so the vast majority of the grime would be located
near the bottom.
Nice pic, BTW. I really like the sky, it looks like a "simple" procedural
sky, but simple procedural skies are anything but simple to get right, IMO.
Subject: Re: Ruined
Date: 24 Jun 2007 18:50:33
Message: <467ef539$1@news.povray.org>
Alain wrote:
> Kirk Andrews nous apporta ses lumieres en ce 2007/06/24 07:03:
>> By "jitter", do you mean a slight amount of
>> turbulence and
>> rotation/translation each time, averaged together?
>> Thanks,
>> Kirk
> That jitter means some small to medium, relative to the dimentions of
> the object, translation of the object pattern, using many instances all
> averaged together. You need at least 10 averaged patterns for this to
> work, and usualy over 100 to get good results. As you don't use
> reflection, it can still be relatively fast, it become painfuly slow if
> you have any reflection, particularly if you have self reflection.
And the pattern you derive from this will need to be encapsulated in a
pigment_pattern{} block, in order to use pigment_maps with it:
pigment{
  pigment_pattern{ my_predeclared_jittered_object_pigment }
  pigment_map{
   [0 some_pigment]
   [1 some_other_pigment]
~Sam
Subject: Re: Ruined
Date: 24 Jun 2007 22:12:08
Message: <467f2478@news.povray.org>
Bill Pragnell wrote:
> If you're using an isosurface or other pigment function-based perturbation,
> you should be able to use the same pattern to provide texturing - limit
> your grime textures to the same regions of the colour map as are used for
> the erosion.
Agreed.  Pretty much the standard approach.
>The other thing you could try is using the un-weathered base
> object to define an object pattern - only areas inside the object could
> then be textured, i.e. just the weathered sections. I don't know if these
> are practical for your purposes...
I have had some success with this approach also, basically I think I
jittered the object pattern through several minor scale changes.  I used
that approach on this chalice image.  In the test shot the green shows
where the grime colour would fall.
Download 'img.0132.sm.jpg' (106 KB) Download 'img.0210.jpg' (40 KB)
Preview of image 'img.0132.sm.jpg'
Preview of image 'img.0210.jpg'
Subject: Re: Ruined
Date: 25 Jun 2007 16:25:02
Message: <web.46802457b5692e82c9bc32e60@news.povray.org>
> I'm working on a scene of some ancient Greece-style ruins.  It has proved to
> be very difficult to get everything to look sufficiently weathered and
> "ruined".  But here is one of the columns as it stands at the moment.  If
> anyone has experience or suggestions in ruining things in POV, I'd love to
> hear them.
> - Kirk
I once did broken columns by clipping a regular column with an
iso-landscape.  It took some tweaking, but it looked fairly good.
ADB
Subject: Re: Ruined
Date: 25 Jun 2007 18:40:01
Message: <web.468043ccb5692e82d73251260@news.povray.org>
That's a beautiful chalice Jim! Did I miss the original full size image?
Did you use multiple versions scaled differently for the jittered object
pattern, or one version scaled multiple times?
Mark Slone
Subject: Re: Ruined
Date: 25 Jun 2007 23:04:20
Message: <46808234@news.povray.org>
Thanks Mark.  No, nothing missed.  That test render was as far as I took
things.  In fact I don't think the render even includes the grunge
effect, that was going to be for a second cut which would have also had
a nice fabric for the display surface.  But I lost interest as usual.
Funny, Jaime and others have put fabric capabilities into our hands in a
way that it wasn't when I did the model.  Really should finish this one
off. Actually the other necessary component, lighting for such a model,
has also been improved by the efforts of others including Jaime, and I
am learning it on my current project, so maybe I can roll it all
together and make a good final render of that chalice.
That latter I think.
   average
   pigment_map {
     #local I=0;#while(I<90)
       [1
         object {
           object {
             k13_texture_
             #local J = rand(S);
             scale <.9+.2*J,1,.9+.2*J>
           pigment { rgb  CHSL2RGB( <70,.12,.29> ) }
           pigment { rgb  CHSL2RGB( <65,.24,.08> ) }
       [1
         object {
           object {
             k13_texture_
             rotate y*(-10+20*rand(S))
       #local I=I+1;#end
