POV-Ray : Newsgroups : povray.binaries.images : Problem with +UA option (Alpha rendering) Server Time
26 Dec 2025 04:56:46 EST (-0500)
  Problem with +UA option (Alpha rendering) (Message 1 to 10 of 12)
Subject: Problem with +UA option (Alpha rendering)
Date: 12 Feb 2007 22:30:01
Message: <web.45d12f3355e01ed18fafdc490@news.povray.org>
Here is the image with normal render.
Download 'earth512.png' (291 KB)
Preview of image 'earth512.png'
Subject: Re: Problem with +UA option (Alpha rendering)
Date: 12 Feb 2007 22:40:00
Message: <web.45d131842a2b82398fafdc490@news.povray.org>
Here it is again when I added only the "+UA" option in the command line.
So.. what's wrong with this?
Download 'earth512-alpha.png' (317 KB)
Preview of image 'earth512-alpha.png'
Date: 13 Feb 2007 11:08:00
Message: <45d1e260$1@news.povray.org>
"EagleSun" <nomail@nomail> wrote in message
news:web.45d131842a2b82398fafdc490@news.povray.org...
I don't know, what is wrong with it? I opened it up in Gimp and it
definately had a transparent "background". The earth itself isn't
transparent.
Date: 13 Feb 2007 15:59:02
Message: <45d22696$1@news.povray.org>
Hash: SHA1
	Looks fine to me... What were you expecting?
		Jerome
+------------------------- Jerome M. BERGER ---------------------+
|    mailto:jeb### [at] freefr      | ICQ:    238062172            |
|    http://jeberger.free.fr/     | Jabber: jeb### [at] jabberfr   |
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.5 (GNU/Linux)
iD8DBQFF0iaWd0kWM4JG3k8RAucBAKCYQwJySuUdHcSXR2WV6Yj4R9xvAACgmaL/
eZ13p1ZQsiNVfanu7uEdRys=
=A6q+
-----END PGP SIGNATURE-----
Date: 13 Feb 2007 21:40:00
Message: <web.45d275d02a2b82392ca695fb0@news.povray.org>
> transparent.
Very strange you don't see a problem.... I see a THICK BLUE circle around
the earth on the version I created with the "+UA" option.  When I tried
converting it to PPM format, the THICK BLUE circle was included.
Date: 13 Feb 2007 23:17:13
Message: <45d28d49$1@news.povray.org>
The atmoshpere looks a bit thick, but it's
only 3 or 4 pixels, and fades opaque.
The atmosphere isn't usually sitting there with
a white backdrop.
Here's a link to an OK moonrise pic.
http://www.space.com/php/multimedia/imagegallery/igviewer.php?imgid=55&gid=4
After looking at that, I'd think the air in your
model should be clearer a bit.
Date: 14 Feb 2007 00:35:47
Message: <45d29fb3$1@news.povray.org>
If you take the +UA version and put it on a black background in Photoshop,
it's nearly identical to the original (some pixels around the edge are off
by a very slight amount (7 or 8 out of 255), which might be caused by how
POV-Ray handles transparency on emissive media). The majority of the visible
difference is caused by the fact that you've displayed the second version on
a grey background, which makes the blue ring around the earth more visible
(probably mostly because of your monitor's gamma.)
 - Slime
 [ http://www.slimeland.com/ ]
Date: 14 Feb 2007 01:08:32
Message: <45d2a760@news.povray.org>
That's called an "atmosphere", and it's present in both versions of the
picture.  Try layering it over a background to see how it acts; the
background will be filtered through it.
...Chambers
Date: 14 Feb 2007 06:25:32
Message: <45d2f1ac@news.povray.org>
use white background
or use green
AND  set you 'right color transparency ' if you use PSP ..
news:web.45d12f3355e01ed18fafdc490@news.povray.org...
Download 'Image1.png' (113 KB)
Preview of image 'Image1.png'
Date: 14 Feb 2007 12:25:00
Message: <web.45d3457b2a2b82392b4445240@news.povray.org>
Hmm... I have GIMP... perhaps you can show me how in GIMP?  (I don't have
Photoshop.)
Grey?  As in Grey and white checkerboard?  How do I change the background?
I didn't modify the source when I re-rendered using the "+UA" option.
And, yes, the atmosphere is very thick by design, so that I'll have plenty
of space to fade away the atmosphere without having any appearance of "hard
cut-off".
In this "game" I was playing, I was hoping to produce 2 identical images,
where 1 would have an alpha channel.  But I'm not convinced that I have 2
identical images.  Would like to see someone take the image with alpha,
remove the alpha and see if it looks identical to the first... and tell me
what software you used to do it (and I hope you mention "GIMP" :) )
Here's what I get when I attempt to remove the Alpha.  I get this using
XnView and NetPBM.  Obviously it's not identical to the original.  Maybe I
need more explanation?
Download 'earth512-alpha-removed.png' (281 KB)
Preview of image 'earth512-alpha-removed.png'
