POV-Ray : Newsgroups : povray.binaries.images : Part List Images in POV-Ray are Too Large Server Time
10 Oct 2024 04:11:28 EDT (-0400)
  Part List Images in POV-Ray are Too Large (Message 1 to 3 of 3)
Subject: Part List Images in POV-Ray are Too Large
Date: 1 Jan 2007 15:30:01
Message: <web.45996e71ae720297c070f5810@news.povray.org>
When I render building instructions in POV-Ray via LPub, the part list
images are too large. (See attached screen shot, taken from a web page
generated by LPub).
How do I reduce the size of these part list images? The model assembly
pictured can be reduced or enlarged via the camera setting angle in LPub,
but I can't reduce the size of the part list image no matter what I do.
Is there a setting in POV-Ray that would accomplish this?
Thanks,
Download 'building instructions sample.jpg' (46 KB)
Preview of image 'building instructions sample.jpg'
Subject: Re: Part List Images in POV-Ray are Too Large
Date: 1 Jan 2007 17:15:41
Message: <4599880d$1@news.povray.org>
"Railrho" <nomail@nomail> wrote in message
news:web.45996e71ae720297c070f5810@news.povray.org...
> generated by LPub).
> Thanks,
> Rick
Hi Rick,
I've never used LPub, but there's a document at
http://www.users.qwest.net/~kclague/LPub/LPub.html that contains a section
labeled 'PART IMAGE DATABASE' which takes you through how to generate
smaller part list images.
It seems to me to say that if you add a file reference for the part in the
file 'half_size.ldr' and delete the image from the appropriate image file
directory that it will use POV-Ray to regenerate the relevant image at half
the size the next time you use it. It would presumably do this by specifying
command line options.
Otherwise you could reduce the image sizes just for the web pages you've
generated using almost any graphics editor.
A third option (if you're not bothered about minimising download times) is
to edit the generated web pages and add a 'width' attribute to the <img>
tags.
e.g. '<img width=20 src="... etc.'.
Hope one of these 3 alternatives helps,
Chris B.
Date: 1 Jan 2007 17:19:15
Message: <459988e3$1@news.povray.org>
> generated by LPub).
    This seems like a question for this forum:
http://news.lugnet.com/cad/ray/?n=*2654,-20&v=b
      ~Steve~
> Thanks,
> Rick
