POV-Ray : Newsgroups : povray.binaries.images : Irregular edges - HowTo ? Server Time
14 Apr 2026 09:12:14 EDT (-0400)
  Irregular edges - HowTo ? (Message 11 to 13 of 13)
Subject: Re: Irregular edges - HowTo ?
Date: 8 Dec 2006 04:33:18
Message: <4579315e$1@news.povray.org>
Thomas de Groot wrote:
> "Jim Charter" <jrc### [at] msncom> schreef in bericht
> news:457883e0@news.povray.org...
>>Here is some quick results I got using the mesh displacement capability
>>of Poseray
> Yes this works fairly well in Poseray, although with some limitations
> indeed. Displacement mapping is probably the best option.
> A very exciting tool at this moment is Silo 2.0, currently in beta version,
> which has a powerful displacement painting tool. Drawback is that it is
> currently only available to Silo 1.x owners. However, the price is
> acceptable for what is offered and the learning curve is smooth. See
> http://nevercenter.com/
> Otherwise, as said already above, isosurfaces would do the job, but here the
> object is a mesh so, I don't know how to go from there.
> Thomas
There is no universal solution imho.  As you say for certain effects
this will work and features the flexibility of mesh.  Obviously,
resolution is the huge issue.  The resolution needed to get pockmarks,
for instance, isn't necessary over the whole model but currently there
is no other way  and if you did apply that degree of resolution to the
whole model the data files would be prohibitively large.
Subdivision modelling such as supported in Blender and Silo might be
used to leverage such a situation if used craftily but again it would be
specific to the effect, not a universal solution.
btw, would the Silo displacement painting tool accept a texture, perhaps
like using a custom brush in photoshop?
Date: 8 Dec 2006 07:43:16
Message: <45795de4@news.povray.org>
news:4579315e$1@news.povray.org...
Yes, it does. You can define your own custom brushes. Amongst other things,
an image_map, or pinch, smooth, push, smudge. As you can subdivide only
parts of the mesh, you have full control over over what parts need
displacement (after subdivision) and what others don't.
Silo 2 is also proposing better uv-mapping control with texture unwrapping
possibilities. I have not yet explored those areas, but it looks promising.
Date: 8 Dec 2006 12:48:52
Message: <4579a584$1@news.povray.org>
Florian Brucker wrote:
>>of Poseray
> Eew, the transformed one looks *really* gross :)
> Florian
Thanks, sort of a mix of skullbone and brain tissue.
Both models are transformed btw, the second picture with the larger
scale texture carries some effects from the previously applied small
scall map.  Interesting potential, no?
